Onkyo Japan Fully Discrete Class A | Source Direct Technology R-1 P301 Preamplifier w/ Phono Stage
PM Me Directly 直接找我
Audition Location 试听地点 (Watsapp PM / Call when arrived | 到达时请 Watsapp 私信或打电话):
🤩MM Phono Stage in Fully Discrete Class A Operation
🤩"Source Direct" Technology Bypasses Tone Controls
🤩MM 唱放采用全分立纯A类操作
🤩“源直通”技术可绕过音调控制
This preamp delivers clean, clear sound at any volume and works well with a variety of speaker types, providing powerful, open, and full audio quality. It's an excellent choice for a budget-friendly 2-channel stereo system with versatile input options, and while minor noise may appear at very high volumes, the performance is outstanding for the price. ~ audioreviews' Reviewers
NOW ONLY RM 780 w/ Phono Stage!🤯 You CAN HAVE IT on your HIFI RACK!🤩 SHOW IT OFF ~
现在只需 RM 780🤯有黑胶唱头放大功能! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜
CONDITION 品像: 8/10 = Excellent Condition
🤩Can HELP U do 可以帮您:
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
COD to prevent damage 一手交钱,一手交货,避免运送风险
POSTAGE / LALAMOVE - BUT BEAR the RISK & postage FEES 可邮寄,运费与风险买家自己承担
SOUND QUALITY REVIEW(音色评测):🤩
- Clear and clean sound at any volume level, suitable for various speakers.
- Handles simulated stereo for mono sources well.
- Great value at its price point, especially second-hand.
- Simple, open, and high-quality sound with good input variety.
- Consistent performance even at low levels
- Works well with different amplifiers and speaker setups, offering flexibility in sound profiles.
- Solid build quality with a straightforward design
- 在任何音量下都能提供清晰干净的音质,适合各种扬声器。
- 模拟立体声功能处理单声道音源效果良好。
- 在二手市场具有极高的性价比。
- 音质简单、通透,且具备多种输入选项。
- 即使在低音量下也能保持稳定的性能。
- 兼容不同的功放和扬声器设置,提供多样的声音风格。
- 结构坚固,设计简洁明了。
DESIGN & TECHNOLOGY 设计与科技:
- Includes a highly regarded phono stage for superior vinyl playback.
- Provides full control over all connected audio equipment, including dubbing options between Tape-1 and Tape-2, and Video-1 and Video-2.
- Well-designed tone controls with an adjustable loudness control centered around 50Hz and 10kHz, allowing fine-tuning rather than a simple on/off.
- "Source direct" button bypasses tone controls and internal circuitry for a cleaner signal path, enhancing sound purity.
- Motorized potentiometer for volume control, offering a smooth, precise adjustment rather than a VCA.
- EQ controls include an adjustable loudness control, a bass bell at 100Hz, and a treble shelf at 10kHz, adding versatility to sound shaping.
- 配备备受推崇的唱放电路,为黑胶播放提供卓越音质。
- 提供对所有连接音频设备的全面控制,包括在 Tape-1 和 Tape-2 之间,以及在 Video-1 和 Video-2 之间的拷贝选项。
- 精心设计的音调控制,带有可调节的响度控制,中心频率为50Hz和10kHz,允许微调而不是简单的开/关。
- “直通源”按钮可绕过音调控制和内部电路,提供更纯净的信号路径,提升声音纯度。
- 电位器电机控制音量,提供平滑且精确的调节,而非使用VCA。
- EQ 控制包括可调响度控制、100Hz的低音增益以及10kHz的高音棚架设计,增加了声音调节的多样性。
SPECIFICATIONS 规格:🧾
-Frequency response: 15Hz to 30kHz
-Total harmonic distortion: 0.009%
-Input sensitivity: 2.5mV (MM), 150mV (line)
-Signal to noise ratio: 83dB (MM), 100dB (line)
-Output: 1V (Pre out), 5V (Pre out Max)
-Dimensions: 455 x 110 x 312mm
-Weight: 4.1kg
REFERENCES 根据:🫡
1. https://www.hifiengine.com/manual_library/onkyo/p-301.shtml
2. https://www.diyaudio.com/community/attachments/onkyo-p-301-schematic-sim-stereo-question-png.644907/
3. http://www.audioreview.com/product/amplification/a-v-preamplifier/onkyo/p-301.html
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
🤩MM 唱放采用全分立纯A类操作
🤩“源直通”技术可绕过音调控制
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
- 在二手市场具有极高的性价比。
- 即使在低音量下也能保持稳定的性能。
- 结构坚固,设计简洁明了。
SPECIFICATIONS 规格:🧾
-Weight: 4.1kg
REFERENCES 根据:🫡
DISCLAIMER 免责声明:
» NIKKO Japan w/ Phono Stage | Class A Biased Fully Discrete TRM-210 Integrated Amp in Real Wood Case
» Naim Audio OLIVE Pure Class A Fully Discrete NAC 92 Preamp w/ Phono Stage & Remote
» ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage
» Krell KSP 7B Class A Dual-Mono Preamplifier with Phono Stage
» CHORD w/ XLR | UK Transformer & Caps | Pure Class A Fully Discrete CPA2200 Preamp Gold Black
