Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Empty Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD
Post by HomeSweetAudio98 Sun Nov 03, 2024 4:10 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
🗺 Audition Location 试听地点 (Watsapp PM / Call when arrived | 到达时请 Watsapp 私信或打电话):👇
✅NOW ONLY RM 980!🤯 You CAN HAVE IT on your HIFI RACK!🤩 SHOW IT OFF ~😎
✅Retails at RM 3700++ (USD$ 849) in 29 Years AGO!🤯
✅现在仅售RM SOLD!🤯 您可以把它放在您的HIFI架子上!🤩 好好展示一下~😎
✅29年前零售价为 RM 3700++(约合 849 美元)!🤯
💎CONDITION 品像: 8/10 = Excellent Condition
🤩Can HELP U do 可以帮您:
🎵HiFi Tweaking 调音
🎵900va Power Transformer can do up to 900w MAX Power
🎵6 Capacitors Totaling 46400 µF
🎵Minimal Signal Path Design
🎵Fully Complementary Differential Circuitry
🎵DC Servo Correction w/ BiFet Operating Point Controller
🎵Double-stage Ground Isolation System
🎵Triple-Diffused Planar High-Current Output Devices
🎵900VA 电源变压器最大功率可达 900W
🎵6 个电容器,总容量为 46400 µF
🎵最小信号路径设计
🎵完全互补差分电路
🎵带 BiFet 工作点控制器的直流伺服修正
🎵双级接地隔离系统
🎵三重扩散平面高电流输出器件
🤩We Provide我们提供:
🎵HiFi Tweaking 调音
✅COD🤝 to prevent damage 一手交钱,一手交货,避免运送风险 ⚠
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
- Initially, sound is warm with a coarser, grainier midrange and high end compared to Denon.
- Lacks brightness of Denon, offering a warmer, more relaxed tone.
- After 20-25 minutes of use, sound becomes smoother in mid-to-high frequencies, with improved bottom end.
- Amp seems to need a warm-up period for optimal performance.
- Midrange and bass are solid, reducing need for a subwoofer in 2-channel music.
- Dynamic range and soundstage are wider and more engaging than Denon.
- High volumes sound clear and balanced without becoming harsh.
- For DVDs, surround and center channels sound more vibrant; amp enhances dynamic contrasts in movie audio.
- Overall, a worthwhile upgrade for improved warmth, dynamics, and soundstage.
- 最初,声音温暖,中频和高频相较于 Denon 更粗糙、颗粒感强。
- 缺乏 Denon 的亮度,提供更温暖、更放松的音调。
- 使用 20-25 分钟后,中高频的声音变得更加平滑,低音也有所改善。
- 功放似乎需要一段预热时间以达到最佳性能。
- 中频和低音表现扎实,减少了在两声道音乐中对低音炮的需求。
- 动态范围和声场比 Denon 更宽广,更具吸引力。
- 高音量时声音清晰平衡,不会变得刺耳。
- 对于 DVD,环绕声和中央声道的表现更加生动;功放增强了电影音频中的动态对比。
- 总体来说,这是一次值得的升级,带来了更好的温暖感、动态性和声场。
✅DESIGN &  TECHNOLOGY设计与科技: ⚙ 🛠
- Very heavy, with amp itself weighing around 30lbs; features a large 900va power supply and 6 capacitors totaling 46400 µF.
- Each channel protected by:
  - Individual fusing
  - DC fault sense
  - Short-loaded sense
  - Excess temperature sense
  - Power-on delay
- Minimal signal path design with on-card I/O connectors, eliminating internal interconnect cables
- Precision passive components used in all critical signal paths
- Fully-complementary differential circuitry utilizing low-noise, high-speed transistors
- DC Servo correction with BiFet operating point controller
- Oversized power supply
- Double-stage ground isolation system to prevent ground loops and RF interference
- Triple-diffused planar high-current output devices with a combined output safe operating capability of 400 watts per channel
- Individual calibrated level trim controls for each channel
- 非常沉重,功放本身重约 30 磅;配备大型 900VA 电源和 6 个总容量为 46400 µF 的电容器。
- 每个通道都有保护:
  - 单独保险丝
  - 直流故障检测
  - 短路检测
  - 超温检测
  - 开机延迟
- 最小信号路径设计,带有电路板上的 I/O 连接器,消除内部连接电缆
- 在所有关键信号路径中使用精密被动元件
- 采用低噪声、高速晶体管的完全互补差分电路
- 具有 BiFet 工作点控制器的直流伺服修正
- 超大电源
- 双级接地隔离系统,以防止接地环路和射频干扰
- 三重扩散平面高电流输出器件,具有每通道 400 瓦的安全工作输出能力
- 每个通道都有单独的校准音量调整控制
✅SPECIFICATIONS 规格:🧾
- Power Output: Continuous Average Output Power
- Stereo Operation: 100 watts each channel into 8 ohms from 20Hz to 20kHz with no more than 0.08% THD
- Dynamic Headroom: 1.1 dB @ 8 ohms (all channels driven)
- Frequency Response: 20Hz to 20kHz (+0, -0.2 dB)
- Separation: >70 dB (@ 1 kHz)
- Dampening Factor: > 300 (20Hz to 20kHz)
- Input Impedance: 50K ohms in parallel with 120 pF
- Gain: 29.0 dB (+/- 0.5 dB)
- Input To Output Phase: 0º (+/- 10º) 20Hz to 20kHz
- Distortion: IM - <0.01% CCIF
  - <0.05% SMPTE
  - THD - <0.08% (@ 125W into 8 ohms)
- Signal-to-noise Ratio: >110 dB A-Weighted, referenced to power; >90 dB A-Weighted, referenced to 1W into 8 ohms
- Rise Time: 2.2µS
- Power Consumption: 80W at idle; 500W with musical program; 900W at full power into 8 ohms
✅REFERENCES 根据:📑🫡
1. https://forum.polkaudio.com/discussion/7433/carver-av-405-review
2. https://www.hifiengine.com/manual_library/carver/av-405.shtml
3. https://worldradiohistory.com/Archive-All-Audio/Archive-HiFI-Stereo/SPECIALS/Stereo-Review-1996-Buyers-Guide.pdf
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0114
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0110
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0115
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0116
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0112
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0113
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0111
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0117
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Img_0118
Carver USA by Bob Carver | Max 900W Transformer | 46400 Total Capacitance |DC Servo AV405 Power Amp SOLD Yead3r10
HomeSweetAudio98
Regular
Regular
Number of posts : 66
