Zidoo Neo S
Zidoo Neo S Empty Zidoo Neo S
Post by JH Lim Mon Nov 04, 2024 3:52 pm
Zidoo Neo S Neo_s11
* OFFER PRICE RM 2,999.00 *
* LIGHTLY USED *
Specification :-
Model : NEO S
Display : 5-inch OLED HD touch screen
Chassis : Aviation aluminum alloy
CPU : Realtek RTD1619DR ARM Cortex-A55(hexa-core)
GPU : ARM Mali-G51 MP3
Internal SSD : 256G SSD (M.2 SATA 3.0 2280, up to 1TB)
Audio DAC : ESS 9068*2
Wi-Fi : 2.4G+5G dual band WiFi, 802.11 a/b/g/n/AC 2T2R MIMO 867Mbps
Ethernet : RJ-45(10/100/1000Mbps)
HDMI Output : 2.0a (4K@60fps/12Bit/HDR/BT2020/YCbCr 4:4:4 output)
Support audio passthrough
Video Decoding : 4K@60p HEVC/H.265 12Bit HDR10, HDR10+, Dolby Vision
Audio Decoding : Support true-hd HD audio passthrough, stereo PCM decoding, Built-in DAC audio decoding : support up to stereo DSD512, PCM 768KHz 32Bit, MQA
Bluetooth Audio Input : CSR8675 flagship Bluetooth audio module(BT5.0)
Support lossless audio protocols such as SBC/AAC/aptX/aptX LL/aptX HD/LDAC
USB Audio Input : USB audio compatible system: Windows(7,10), Mac, Android, Support up to stereo DSD512, PCM 768KHz 32Bit, MQA
Digital Audio Input : USB DAC IN, AES/EBU input, Coaxial input, Optical input
Digital Audio Output : Coaxial output, HDMI output, USB Audio output, Bluetooth output
Analog Audio Output : Preamp output: XLR(balanced), RCA, Headphone amplifier output: 4.4mm balanced, 6.3mm single-ended
Headphone Impedance : 16-300Ω(low-gain mode: 16-32Ω; high-gain mode: 32-300Ω)
XLR(balanced) Output : Output Level(Vrms): 4.1 Vrms, THD+N: -118dB, Noise: 2uVrms, SNR: 120dB(20Hz-20kHz), Frequency Response ±0.25dB(20Hz-20kHz), Crosstalk: -120dB(1kHz,Fs=44.1kHz), DNR: 119dB
RCA(single-ended) Output : Output Level(Vrms): 2.16 Vrms, THD+N: -116dB, Noise: 2.5uVrms, SNR: 119dB(20Hz-20kHz), Frequency Response: ±0.258dB(20Hz-20kHz), Crosstalk: -130dB(1kHz,Fs=44.1kHz)
, DNR: 118dB
USB Ports : USB3.0*2, USB2.0*2
Control Ports : IR IN, Bluetooth, TCP/IP control(WOL)
Power Supply : AC 110~240V 50/60Hz
Dimensions : 213(L)*292(W)*101(H)mm
Last edited by JH Lim on Mon Nov 04, 2024 3:54 pm; edited 1 time in total (Reason for editing : wrong format)
JH Lim
Number of posts : 16
Registration date : 2016-01-14
