Rega Aura MC Phono Stage Made In England
Rega Aura MC Phono Stage Made In England Empty Rega Aura MC Phono Stage Made In England
Post by stylelaser.com.my Tue Nov 05, 2024 10:59 am
Rega Aura MC Phono Stage Made In England Brand New. Now Selling At RM 24,999. Free Shipping Within West Malaysia.
Rega Aura MC Phono Stage Made In England Rega13
Aura MC Ref
The reference Aura MC stage is the culmination of decades of electronic design development. We have created the ultimate, fully adjustable, three-stage, all symmetrical pre-amplifier designed purely to extract the very best performance from your moving coil cartridge and vinyl playback system.
Rega Aura MC Phono Stage Made In England Aura_mc_%282%29
Design Innovation
Built into a completely re-designed custom case, the Aura is dedicated to moving coil cartridges and stays clear of any compromises. We have avoided including any superfluous functions as they obstruct the signal path and degrade the sound quality. The Aura phono pre-amp incorporates remarkable and innovative design ideas. If you are a vinyl connoisseur, then the Aura MC is an absolute must for demonstration.
Key Features
  • Three stage, all symmetrical pre-amplifier
  • Compatible with all typical low output moving coil cartridges
  • Fully adjustable
Product Details
First Stage
The first stage is a symmetrical, complementary class A amplifier, using parallel connected Linear Systems ultra-low noise FET (Field Effect Transistor) transistors configured as a symmetrical compound pair input stage. The use of FET transistors ensures there is no bias current flowing in the cartridge coil so as not to upset the delicate magnetic geometry of the cartridge. The input circuit configuration also alleviates the use of any coupling components between the cartridge output and the input stage FET transistors, which would degrade the sound. The complementary ultra-low noise FET transistors are carefully graded and matched for optimum performance. This stage drives the passive high-frequency part of the RIAA equalisation stage.
Second stage
The second stage is a symmetrical, class A, differential amplifier with a common base driver stage; this is also used as
Third stage
The third stage inverts the signal to provide the balanced output along with the output of the second stage; the third stage uses the same circuit topology as used in the second stage. The power supply is a symmetrical, discrete tracking power supply using fast diodes and a low noise voltage reference. Each stage has its own localised power supply and LED referenced current generators. To maximise headroom, the Aura has a power supply voltage, which is 60% higher than normally found in such a pre-amplifier. Very high quality, polypropylene capacitors have been used in the signal path. 1% tolerance polypropylene capacitors are used in the RIAA EQ stages and audio grade capacitors are used in the rest of the circuit. Gain, Mute and Mono switching is implemented using high-quality relays.
Rega Aura MC Phono Stage Made In England Module-2-aura-mc
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Rega Aura MC Phono Stage Made In England Trade
Technical Specifications
Input Load ​50, 100, 150, 300 & 400 Ω
Capacitive Load ​1000, 2000, 3200, 4300, 5700 pF
RIAA Accuracy 0.2 dB 100 Hz to 50 kHz
Frequency Response 13.5 Hz (-3 dB) to 100 kHz (-0.2 dB)
THD 0.03%
Input Sensitivity ​69.5 dB (Gain Setting I), 63.5 dB (Gain Setting II)
Dimensions (W x H x D) 350 x 435 x 88 mm
Weight 13 kg
For full technical specifications, download Aura - User Manual Multilingual - Ver 3 below.
Number of posts : 1467
