Audiolab 7000A Integrated Amplifier + Audiolab 6000N Play Wireless Streaming Player
Audiolab 7000A Integrated Amplifier + Audiolab 6000N Play Wireless Streaming Player Empty Audiolab 7000A Integrated Amplifier + Audiolab 6000N Play Wireless Streaming Player
Post by stylelaser.com.my Tue Nov 05, 2024 11:11 am
Audiolab 7000A Integrated Amplifier + Audiolab 6000N Play Wireless Streaming Player Brand New. Now Selling At RM 6,999. Free Shipping Within West Malaysia.
Audiolab 7000A Integrated Amplifier + Audiolab 6000N Play Wireless Streaming Player L192
7000A
Engineered to deliver clean, dynamic, audiophile-quality sound to your home entertainment system, the silver 7000A Stereo 70W Integrated Amplifier from Audiolab is packed with high-quality components that support a wide range of input sources. The ESS ES9038Q2M DAC processes audio using Audiolab's HyperStream architecture and Time Domain Jitter Eliminator, while the Class AB power amp delivers 70W of power at 8 ohms to an optional pair of speakers. Connect your components through an array of RCA, optical, and coax inputs. Stream from smart devices using Bluetooth aptX, play MQA and other hi-res formats over USB, and enjoy TV audio via HDMI ARC. All of this and more is easily managed via an intuitive GUI on the built-in 2.8" IPS full-color interface.
Full-Color Display
Built into the face of the 7000A is a 2.8" full-color IPS LCD screen, which provides detailed information and intuitive control over internal settings, such as the digital phase lock loop of the D/C converter. When not in use, you can select to display working analog or digital VU meters.
Full MQA Decoding
A custom-engineered MQA-certified DAC solution allows the 7000A to complete the full three unfold MQA decoding process internally, which is ideal for subscribers of MQA masters content, such as Tidal's HiFi Plus tier.
Dedicated Amps
Vinyl fans can hook up their turntables using the integrated phono pre-amp that features a low-noise MM phono circuit and precise RIAA equalization. For a more private, but equally dynamic, listening experience, use the dedicated headphone amp with current-feedback circuitry with your favorite pair.
6000N Play
Stream high-quality music to your home audio system via this 6000N Play Network Audio Player from Audiolab. The 6000N comes equipped with an ES9018 SABRE32 Reference DAC chip and support for Hi-Res Audio. The internal circuitry allows you to output content via RCA outputs to a standard amplifier or active speakers, or an optical or coaxial cable can be used to output to an external DAC or amp.
Audio can be transmitted to the 6000N over your home network through a wired Ethernet connection or via dual-band Wi-Fi and the 6000N's dual antennas. Stream from desktop or laptop computers, smartphones, tablets, NAS drives, or music servers. It supports devices running Windows, Mac, and Android operating systems. It's also compatible with DLNA-compatible home media servers. Stream music files or from a wide variety of music services. Integrated Alexa support provides control via voice commands, or you can use the DTS Play-Fi app from a Windows, Android, iOS, or Kindle mobile device.
Streaming Service Support
In addition to files stored on your devices or network, you can stream online audio from a variety of sources, such as Internet Radio, Qobuz, Spotify, TIDAL, Apple Music, Amazon Music, Deezer, QQ Music, KKBox, Pandora, TuneIn, Napster, iHeartRadio, SiriusXM, and SoundMachine.
DTS Play-Fi Whole Home Support
DTS Play-Fi compatibility allows you to use the DTS Play-Fi app to control your audio experience, but it also lets the 6000N integrate into a whole home audio setup by connecting wirelessly to other Play-Fi-equipped devices.
Integrated Presets
A total of 6 preset buttons on the face of the 6000N component operate just like those found on an FM tuner. However, with the 6000N, you can set each preset to an online streaming service or your favorite playlist. All without the need of using a mobile app.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Audiolab 7000A Integrated Amplifier + Audiolab 6000N Play Wireless Streaming Player Trade
7000A Specifications
General Description Integrated Amplifier
Design Philosophy and Core Technology
- 2 x 70W (8 ohms) / 2 x 110W (4 ohms) Class AB
- ES9038Q2M 32-bit DAC
- 2.8" (480x640mm) Full View IPS LCD
- Built in Certified Hardware MQA Full Decoder (PC USB, Coax / Optical)
- Bluetooth 5.0 (aptX / aptX LL) Support
- Low Noise Moving Magnet Phono Stage
- Dedicated Current-Feedback Headphone amp
- Integrated / PRE-POWER / PRE only Modes
- VU Digital / VU Analogue Meter
- USB Upgrade Support
Inputs 3 x Analogue, 1 x Phono (MM), 1 x Power Amplifier,
2 x SPDIF (Coax), 2 x SPDIF (Optical), 1 x HDMI ARC,
1 x PC USB (USB B), 1 x Bluetooth (aptX/aptX LL), 1 x 12V Trigger
Outputs 1 x PRE Amplifier, 1 x Stereo Speaker, 1 x Headphone, 1 x 12V Trigger
Sampling Frequency Optical / Coaxial: 44.1kHz - 192kHz;
PC USB: 44.1kHz-768kHz (PCM) / DSD64, DSD128, DSD256, DSD512
Preamplifier Section
Gain +6dB (Line); +55dB (Phono MM)
Input Sensitivity 820mV (Line, Volume = 0dB); 3.1mV (Phone MM, Volume = 0dB)
Input Impedance 10K (Line); 47K // 100pF (Phono MM)
Total Harmonic Distortion (THD) < 0.0005% (1kHz @ 2V, Volume = 0dB)
Frequency Response 20Hz-20kHz (+/-0.1dB)
Output Voltage 2.3V max. (Volume = 0dB)
Output Impedance 100 ohms
Signal-to-Noise Ratio > 110dB (Line, A-weighted); > 76dB (Phono MM, A-weighted
DAC
D to A Converter ES9038Q2M
Total Harmonic Distortion (THD) < 0.0005% (1KHz @ 0dBFS)
Output Level (0dBFS, 1kHz) 2.1Vrms
Max. Sampling Frequency Optical, Coaxial: 192kHz;
PC USB: PCM768kHz, DSD512
Power Amplifier Section
Gain +29dB
Rated Power Output 2 x 70W (8 ohms, THD<1%); 2 x 110W (4 ohms, THD<1%)
Frequency Response 20Hz-20kHz (+/-0.3dB)
Total Harmonic Distortion (THD) <0.003% (1kHz @ 40W / 8 ohms)
Input Sensitivity 720mV
Signal-to-Noise Ratio (S/N) > 110dB (A-weighted)
Max. Output Current 9A
Headphone Amplifier
Total Harmonic Distortion (THD) < 0.01% (1kHz, 50mW)
Output Impedance 4.7 ohms
Load Impedance 20-600 ohms
General
Standby Power Consumption <0.5W
Net Weight 8.4kg
Gross Weight 10.7kg
Dimensions (mm) (W x D x H) 444 x 340 x 78
Carton Size (mm) (W x D x H) 500 x 455 x 140
Finish Black / Silver
Power Requirements 220-240V ~ 50/ 60Hz;
(depending on region) 100-120V ~ 50/ 60Hz
Standard Accessories Power Cord, Remote Control, User Manual, Antennas, etc.
6000N Play Specifications
Digital Section:
Digital Output Level 500 +/- 50mVpp
Output Impedance 75Ω
Maximum Resolution 192kHz/24bit
Digital Output 1 x coaxial , 1 x optical
Variable Output Voltage 0 – 2.1V
DAC ES9018K2M
Frequency Response +/-0.5dB(20Hz-20kHz,ref.1kHz)
Total Harmonic Distortion (THD) <0.003% (1kHz @0dBFS , BW=20-20kHz)
Signal-to-noise Ratio (S/N) >115dB(A-weighted)
Analogue Output Impedance 100Ω
Requirements (depending on region)
220V—240V~50/60Hz
100V—120V~50/60Hz
Dimensions (LxHxW) 445 x 80 x 330mm. including feet, terminals and controls
Net Weight 4.9kg
Number of posts : 1467
