Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used)
Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used) Empty Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used)
Post by choyaudiovisual Thu Nov 07, 2024 9:02 am
Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used) 1-2-1-26
Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used) Img_8862
Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used) Img_8861
Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used) Img_8863
Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used) Img_8864
Pro-Ject Audio Systems Stereo Box DS (Made In Europe) (Used) Image128
Description
The high-performance integrated amplifier features dual-mono amplification topology using the highest quality PWM amplifier modules (two per channel) for audiophile-grade sound. This amplifier is not only powerful but, is capable of driving difficult speaker loads and is stable down into 2 ohm operation. In addition to four pairs of RCA line level jacks to accommodate a selection of analog inputs, a USB digital input provides easy direct interface with computers.
The built-in D/A converter provides superb sound from your computer files and simplifiesinterface and operation. The large and legible display readout provides status of every operational mode and can be read across the room. The massive metal case shields the internal circuitry form not only detrimental vibrations but also electromagnetic interference. Additionally, the outboard power supply also contributes to the low-noise environment. An IR remote control is supplied.
Specification
Output Power 2 x 40W / 60W at 8 ohms / 4 ohms (both channels driven)
Frequency Response 10Hz – 50kHz (+0dB/-3dB)
Channel Separation > 40dB @ 20kHz
Signal to Noise Ratio > -90dB (IEC -A)
Power Consumption 5A DC, <1W standby
Outboard Power Supply 24V/5A DC
Speaker Connectors 4mm Banana Jacks, Spade Connectors or Bare Wire
Sampling Rates 44.1kHz and 48kHz
Conditions: 9/10 (USED)
Price: RM 1,690.00 inclusive postage to West Malaysia
Number of posts : 5925
