Cyrus FM7.5 FM Radio Player (Used)
Cyrus FM7.5 FM Radio Player (Used) Empty Cyrus FM7.5 FM Radio Player (Used)
Post by choyaudiovisual Thu Nov 07, 2024 10:40 am
Cyrus FM7.5 FM Radio Player (Used) Img_9419
Cyrus FM7.5 FM Radio Player (Used) Img_9420
Cyrus FM7.5 FM Radio Player (Used) Img_9421
Cyrus FM7.5 FM Radio Player (Used) Image133
Description
A top quality FM radio tuner featuring 29 station memory settings, remote control compatibility and a large clear display. Fully compatible with our Master Control System MC BUS, FM 7.5 may also be controlled remotely through our multiroom components.
In spite of the recent explosion in multi-media and audio-visual interests, it is still true to say that radio broadcast continues to offers a great deal of entertainment and pleasure to people. This is a highly interactive median, in that the listener is more intimately involved in and participates mentally in the broadcast program. The FM7.5 is designed to capture the true spirit of the transmitted material with the least amount of alteration to the original signal.
The sensitive, low distortion front-end design of the FM7.5 enables this product to enjoy wide dynamic range and highly linear characteristics, reducing intermodulation artefacts that can be harmful down the line in the demodulation process. The generous front-end Power gain assists in achieving low noise operation at low signal levels.
The triple stage IF strip of the Cyrus FM7.5 is a highly linear design which is substantially responsible for the low distortion behaviour of the tuner as a whole. Complex ground plane design and Power supply topology are key elements in achieving the superior performance of the FM7.5
Close tolerance quartz crystal together with a precision phase-locked-loop (PLL) circuitry is designed to enable stable and accurate tuning to the radio station. The centre frequency adjustment of the tuning system is achieved by computer controlled calibration during the manufacturing phase of the FM7.5 through the MC-Bus.
The instrument level accuracy of the FM7.5 clearly shows up deficiencies in the absolute centre frequency of some commercial radio station and cable transmissions. The FM7.5 is designed to deal with this in a most elegant manner, by fine-tuning stations in steps of 10kHz. This totally compensates for any error of absolute nature in the transmission carrier frequency and may of course be memorised by the unit in a preset.
Technical Information
Electrical
Tuning – Quartz PLL
Display – Custom LCD with subtle green back lighting.
Remote Control – Full function remote control
Inputs – 75 Ohm coaxial
Communications – MC-BUS System BUS
50dB S/N Ratio – 5dBuV (Mono) 30dBuV (Stereo)
Ultimate S/N Ratio – 84dB (Mono) 76dB (Stereo)
T.H.D – 0.05% @ 50kHz deviation (Mono) 0.07% @ 50kHz deviation (Stereo)
Channel separation – >50dB
Pilot tone suppression – 90dB
Output level – 775mV @ 95% modulation
Dimensions – (H x W x D) 73 x 215 x 360 (mm)
Weight – 2.7kg
Finish – Black
Condition : 8/10 (used)
Price: RM 1,350.00 inclusive postage to West Malaysia
Number of posts : 5925
