B&W w/ Yellow Woven Kevlar Driver | Vertical Bracing Cabinet | CDM1 Bookshelf Speaker in Rosewood SOLD
PM Me Directly 直接找我
NOW ONLY RM SOLD!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~
现在只需 RM SOLD🤯! 你就可以拥有它,放在你的音响脚架上🤩!炫一炫它〜
CONDITION 品像: 7/10 = Good Condition
What-Hi*Fi? Best B&W products of all time!🤩
Stereophile ★★★★★ Highly Recommended by John Atkinson !🤩
《What-Hi*Fi?》最佳 B&W 产品!🤩
《Stereophile》★★★★★ 强烈推荐,John Atkinson 认可!🤩
Award-Winning Recognition in 1995
Rosewood Veneer Finish
Innovative Tweeter Mounting Design
Sturdy ¾" MDF Enclosure with Vertical Bracing
Effective Acoustic Damping with 1" Foam Lining
Optimized Flared Reflex Port Design
High-Quality Metal-dome HF Unit from Matrix 801 Lineage
6.5"Yellow Kevlar Woofer Cone with Circular Plastic Molding
Functional Grille Design for Speaker Protection
Precise 3kHz Crossover Placement
Efficient Woofer Low-Pass Filtering w/ Soft-iron-cored Series Inductor
Effective Tweeter High-Pass Filtering w/ Air-cored Inductor & Non-polar Electrolytic Capacitors
Versatile Bi-Wiring Capability
1995 年获奖认可
玫瑰木贴面
创新的高音单元安装设计
坚固的 ¾ 英寸 MDF 外壳,带垂直支撑
使用 1 英寸泡沫衬垫实现有效声学阻尼
优化的喇叭口反射式设计
高质量金属球顶高音单元,传承自 Matrix 801 系列
6.5 英寸黄色 Kevlar 低音锥盘,带圆形塑料成型结构
实用的网罩设计,提供扬声器保护
精准的 3kHz 分频点
低音单元低通滤波采用软铁芯串联电感器
高音单元高通滤波采用空气芯电感器和非极性电解电容器
支持多线分音接线功能
"It is always gratifying for a reviewer to "discover" a component that sounds very much better than you'd expect for its price. B&W's Compact Domestic Monitor 1 is such a product. Used on a high-quality pair of speaker stands and driven by high-performance electronics, this superbly engineered speaker offers a level of neutrality and transparency that I had not previously found to exist in loudspeakers costing less than $2000/pair. Yes, it won't go as loud or as deep as floorstanding speakers in its approximate price range, but if you want quality rather than quantity, the CDM 1 is a winner. Highly recommended!"
by John Atkinson from Stereophile
“对于评论者来说,‘发现’一款远超其价格预期的产品总是令人欣慰的。B&W 的 Compact Domestic Monitor 1 就是这样一款产品。配合高品质的音箱支架并由高性能的电子设备驱动,这款经过精心设计的扬声器展现出一种在售价低于每对 $2000 的扬声器中前所未见的中立性和透明度。没错,它在音量和低频上不及与其价格相近的落地式扬声器,但如果你追求的是质量而非数量,那么 CDM 1 是一个赢家。强烈推荐!”
来自《Stereophile》John Atkinson
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
PERSONAL EXPERIENCES: Listen to Believe! 🤩
- Very Smooth & Sweet Sounding w/ Softness & Refinement
- Laid Back Presentation
- Very Good Bass Extension, can GO DOWN 31 Hz!
- Small Speaker, BIG DEEP BASS !!
- Tall, Wide & Deep Soundstage that will Envelope U!
- Organic & Natural Tone to the Midrange w/ Openness
- Very Attractive Sounding Vocals
- Coherent & Cohesive Sounding, Flawless & Seamless Mids & Highs Integration
- Accurate & Precision Imaging & Instruments Presentation
- Very Detailed & Textured Bass, NOT USUAL 1 NOTE BASS!
- 声音非常顺滑甜美,带有柔和与细腻感
- 表现悠闲从容
- 低音延伸非常好,可下潜至31 Hz!
- 小型音箱,大而深邃的低音!!
- 高大、宽广且深远的音场,令人沉浸其中!
- 中音具有有机自然的音调,带有开放感
- 人声极具吸引力
- 声音连贯和谐,中音和高音无缝衔接
- 精准的成像和乐器呈现
- 低音非常细致、质感丰富,不是普通的单一音调低音!
SOUND QUALITY REVIEW(音色评测):🤩
- The B&W CDM 1 offers a fundamentally neutral tonal balance.
- Voices are clear without lispy or chesty characteristics common in affordable speakers.
- Bass, while not as deep as the Silver Signature, is impressive for its size.
- Upper bass is slightly exaggerated, adding a pleasing bloom to lower-pitched instruments in classical music.
- On rock recordings, this can occasionally make kick drums sound overly rich if not carefully positioned.
- High frequencies are clean, grain-free, and well-balanced with the midrange.
- Treble may sound polite to rock enthusiasts accustomed to more aggressive highs.
- Midrange is clean and transparent, though not as forward as some other speakers like the PSB Stratus Mini.
- Soundstaging is solid and stable, revealing details and spatial reflections effectively.
- The B&W CDM 1 handles complex musical passages well, such as the decaying sounds of piano strings.
- It reproduces instrumental details faithfully, although rock recordings with dense mixes can sound muddy at times.
- Compared to the Silver Signature, the CDM 1 is slightly veiled, less capable of playing loudly without strain, and exhibits more grain in the midrange.
- Despite these differences, the CDM 1 offers excellent value compared to its higher-priced cousin.
- B&W CDM 1 提供基本中性的音调平衡。
- 人声清晰,不带廉价音箱常见的齿音或闷音特征。
- 虽然低音不如 Silver Signature 深沉,但在同类尺寸中表现令人印象深刻。
- 上低音略微夸张,为古典音乐中的低音乐器增添了愉悦的音色。
- 在摇滚录音中,如果未正确定位,可能偶尔会使踢鼓声音显得过于饱满。
- 高频干净无颗粒感,与中音平衡良好。
- 对习惯了更激进高音的摇滚爱好者来说,高音可能显得过于温和。
- 中音干净透明,虽然不如一些其他音箱(如 PSB Stratus Mini)那样突出。
- 音场表现稳固,能够有效展现细节和空间反射。
- B&W CDM 1 能很好地处理复杂的音乐段落,例如钢琴琴弦衰减的声音。
- 它能忠实地再现乐器细节,但在密集混音的摇滚录音中有时会显得模糊。
- 与 Silver Signature 相比,CDM 1 略显朦胧,在高音量下不如其表现从容,并在中音中表现出更多颗粒感。
- 尽管存在这些差异,CDM 1 相比其高价版本仍具有极高的性价比。
DESIGN & TECHNOLOGY 设计与科技:
- Voted "Loudspeaker of the Year" in 1995 by European journalists
- B&W Compact Domestic Monitor 1 (CDM 1) features an attractive mahogany-colored veneer finish
- Tweeter mounted on a sloped cutaway at the top of the baffle is a unique design aspect
- Enclosure constructed from ¾" MDF with a rigid vertical brace at sidewall centers
- Cabinet walls lined with 1" foam for acoustic damping
- Reflex port on the front baffle beneath the woofer, almost 2" in diameter and 6" deep, flared to minimize wind noise
- HF unit is a metal-dome descended from B&W's classic Matrix 801 design
- 6.5" woofer features a yellow Kevlar cone and is surrounded by a circular plastic molding to reduce reflections
- Tweeter covered with a black wire mesh, woofer and port with an elliptical grille of black cloth stretched over a plastic space frame
- Crossover set at 3kHz, mounted on a small PCB attached to the terminal panel
- Woofer low-pass filter with a soft-iron-cored series inductor
- Tweeter high-pass filter is a damped T section with an air-cored inductor and non-polar electrolytic capacitors
- Two sets of gold-plated knurled binding posts for bi-wiring
- Plastic bushes holding the grille in place worked loose after repeated removal and replacement
- 1995年被欧洲记者评为“年度音箱”
- B&W Compact Domestic Monitor 1 (CDM 1) 具有吸引人的红木色饰面
- 高音单元安装在音箱面板顶部的倾斜切角上,是其独特的设计元素
- 外壳由 ¾ 英寸的 MDF 制成,中部侧壁有坚固的垂直支撑
- 箱体内壁衬有 1 英寸厚的泡沫用于声学阻尼
- 反射式低音反射孔位于低音单元下方的前面板上,直径近 2 英寸,深 6 英寸,喇叭口设计可减少风噪
- 高频单元采用金属圆顶设计,源自 B&W 的经典 Matrix 801 设计
- 6.5 英寸低音单元配有黄色凯夫拉锥盆,并用圆形塑料模具包围以减少反射
- 高音单元覆盖有黑色金属网罩,低音单元和反射孔使用覆盖塑料空间框架的椭圆形黑布网罩
- 分频点设置在 3kHz,分频器安装在连接端子板上的小型 PCB 板上
- 低音单元的低通滤波器使用软铁芯串联电感
- 高音单元的高通滤波器是带空气芯电感和无极电解电容的阻尼 T 型电路
- 配有两组镀金带纹螺纹接线柱用于双线分音连接
- 承载网罩的塑料衬套在反复拆卸和安装后变松
SPECIFICATIONS 规格:🧾
- Manufacturer: B&W
- Model: CDM 1
- Years of manufacture: 1995-1998
- Made in: England
- Colour: Ash black, Cherry wood, Ash red
- Dimensions: 370 x 220 x 274 mm (H x W x D)
- Type: 2-way bass reflex, compact speaker
- Chassis:
- Woofer: 1x 165mm Kevlar cone
- Tweeter: 1x 26mm dome tweeter
- Power handling (nominal/music)
- Recommended amplifier power: 30 - 120 W
- Efficiency: 88 dB (2.83V, 1m)
- Frequency response: 64 - 20,000 Hz (±2 dB)
- Crossover frequency: 3,000 Hz
- Impedance: 8 ohms (minimum 4.5 ohms)
REFERENCES 根据:🫡
1. https://www.stereophile.com/standloudspeakers/630/index.html
2. https://www.bowerswilkins.com/on/demandware.static/-/Library-Sites-bowers_northamerica_shared/default/dw691f60f2/archive-manuals/eng_ft00014_cdm1_manual.pdf
3. https://www.soundonsound.com/reviews/bw-cdm1
4. https://www.whathifi.com/features/17-of-the-best-bandw-products-of-all-time
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
1995 年获奖认可
玫瑰木贴面
创新的高音单元安装设计
使用 1 英寸泡沫衬垫实现有效声学阻尼
优化的喇叭口反射式设计
实用的网罩设计,提供扬声器保护
精准的 3kHz 分频点
低音单元低通滤波采用软铁芯串联电感器
支持多线分音接线功能
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
- 声音非常顺滑甜美,带有柔和与细腻感
- 表现悠闲从容
- 小型音箱,大而深邃的低音!!
- 中音具有有机自然的音调,带有开放感
- 人声极具吸引力
- 声音连贯和谐,中音和高音无缝衔接
- 精准的成像和乐器呈现
- 高频干净无颗粒感,与中音平衡良好。
SPECIFICATIONS 规格:🧾
- Manufacturer: B&W
- Model: CDM 1
- Made in: England
- Chassis:
REFERENCES 根据:🫡
DISCLAIMER 免责声明:
» B&W Made in UK | Nautilus Loaded Tweeter | Yellow Woven Kevlar Driver CC6 S2 Center Speaker SOLD
» B&W UK 3 way | Nautilus Loaded Tweeters | Yellow Woven Kevlar FST Midrange | 683 Floorstand Speaker SOLD
» B&W UK 3 way | Nautilus Loaded Tweeters | Yellow Woven Kevlar Midrange | CM4 Floorstand Speaker
» B&W UK w/ Tweeter on Top | Yellow Kevlar Midrange | 4 Driver 3 way 803 Matrix S2 Floorstand Speaker
» FOCUS AUDIO Limited Signature Edition 68SE 10th Anniversary w/ Kevlar Driver | Bookshelf Speaker
