Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used)
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Empty Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used)
Post by choyaudiovisual Fri Nov 08, 2024 11:58 am
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Scree170
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Tempi181
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Tempi178
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Tempi180
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Tempi182
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Tempi179
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Image152
Furutech FI-11M (Cu) US Main Plug
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Furutech_fi-11mcu_square01
RATING
15A/125V
PSE JET: 15PJET090
USL /CNL Listed: 04CA26110
Type: 2-pole+earth
FEATURES
・α (Alpha)-Pure copper Conductor
・Earth (Ground) Jumper System
・Nylon/fiberglass front body
・Polycarbonate shell
SPECIFICATIONS
・Specified for cable diameters of 6.6mm to 16mm
・Wire accommodation: Max 5.5 Square mm 10AWG
・Dimensions: Body length 40.2mm x 39mm diameter x 73mm overall length
・Rated: 15A/125V
http://www.furutech.com/2013/01/26/978/
Furutech FI-11 (Cu) High Performance Power Connector
Furutech FI-11M (Cu) US + FI-11 (Cu) High Performance Power Connector – Pair (Used) Furutech_fi-11-cu_audioteka-1
RATING
15A/125V 10A/250V
< PS >E JET:15PJET086
USL /CNL Listed:04CA26110
FEATURES
・Unplated Phosphor bronze α (Alpha) Conductor
・Nylon/fiberglass front body, polycarbonate shell
SPECIFICATIONS
・Specified for cable diameters of 6.6mm to 16mm (With a longer screw up to 20mm)
・Dimensions: Body length 43.9mm x 39mm diameter x 76.8mm overall length
・Rated: 15A/125V 10A/250V
http://www.furutech.com/2013/01/26/982/
Conditions: 8/10 (USED)
Price: RM 250.00 inclusive postage to West Malaysia
Number of posts : 5925
