Audio Note Conquest 300B Tube Monoblock Power Amplifier
Audio Note Conquest 300B Tube Monoblock Power Amplifier Empty Audio Note Conquest 300B Tube Monoblock Power Amplifier
Post by peterclting Mon Nov 11, 2024 12:58 pm
In good Condition 8/10
Selling for RM22800
Contact Peter 012-3820333
Parallel Single Ended 300B Monoblock
The conquest is a pair of mono power amplifiers, that is 18 watts per channel.
They are pure Class A Parallel Singled Ended valve amplifiers that use a pair of the highly regarded 300B triode valves per channel.
It is suitable for less efficient loudspeakers because of its higher output levels but still gives its best with high efficiency loudspeakers.
Used in combination with a suitable Audio Note pre-amplifier, results are breath taking.
The tube sockets have been upgraded
Pure Class A operation
Zero Negative Feedback
Single Ended Output Stage
Valve Rectification
Directly Heated Triode operation
Materials and component quality
INPUT IMPEDANCE : 100K Ohm
INPUT SENSITIVITY : 250mV / 3.15V (Low Gain) for full output
MAXIMUM OUTPUT : 18 Watts RMS  per channel into 4 or 8 Ohm loads
CHANNEL BALANCE : +/- 0.3dB
VALVE COMPLEMENT : 2 x 5U4GB (1 per chassis)
                                     4 x 300B (2 per chassis)
                                     2 x 6SN7 / 6J5 Metal (Low Gain) (1 per chassis)
UNIT WEIGHT : 20kg (per amplifier)
UNIT DIMENSIONS : 195mm (h) x 205mm (w) x 500mm (d) (per amplifier)
Audio Note Conquest 300B Tube Monoblock Power Amplifier Img_1624
Audio Note Conquest 300B Tube Monoblock Power Amplifier Img_1625
Audio Note Conquest 300B Tube Monoblock Power Amplifier Img_0648
Last edited by peterclting on Fri Nov 29, 2024 12:19 pm; edited 2 times in total (Reason for editing : info update)
peterclting
Number of posts : 3076
Audio Note Conquest 300B Tube Monoblock Power Amplifier Empty Re: Audio Note Conquest 300B Tube Monoblock Power Amplifier
Post by peterclting Sat Dec 21, 2024 3:48 pm
peterclting
