Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer Empty Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer
Post by HomeSweetAudio98 Mon Nov 11, 2024 11:36 pm
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
🗺 Audition Location 试听地点 (Watsapp PM / Call when arrived | 到达时请 Watsapp 私信或打电话):👇
🤔You seen a speaker design & build like a Cube before? 🤣
🤔你见过像立方体一样设计和制造的扬声器吗?🤣
😍Pure Handcraftsmanship in Italy! w/ Real Wood Veneer
😍Ferrofluid, Back-vented Soft Dome tweeter & Fiberglass Midbass Driver
😍Downward Firing Port as Signature Design & Bass Tuning
🤩I was REALLY ASTONISHED by it's Bass & Scale! In my memory, Most of the Speakers at This Size WONT ABLE TO ACHIEVE THIS LEVEL of Bass Performance & Scale, BUT THIS IS EXCEPTION!
😍纯手工制作,意大利出品!采用真正的木质贴面
😍铁磁流体、后通风软球顶高音单元和玻璃纤维中低音驱动单元
😍向下发射出风口作为标志性设计与低音调谐
🤩它的低音和规模真的让我震惊!在我的印象中,这个尺寸的大多数音箱无法达到这种级别的低音表现和音效规模,但这是个例外!
💥This bookshelf speaker is good in performance and soundstage. Small pair of speakers but big sound. It has a port hole at the bottom. When placed on solid metal stands, the speakers is able to give good low bass.
这书架扬声器在性能和音场表现上都非常出色。虽然是小型扬声器,但声音却很大。底部有一个端口孔。当放置在坚固的金属支架上时,扬声器能够提供良好的低频表现。
✅NOW ONLY RM 1780 w/ Grilles!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~😎
✅现在只需 RM 1780 🤯(有网罩)! 你就可以拥有它,放在你的音响脚架上🤩!炫一炫它〜😎
💎CONDITION 品像: 7/10 = Good Condition | 好
- Balanced sound profile with a slight warmth, versatile across genres.
- Tight, controlled bass with decent extension, but not extreme low-end.
- Smooth, natural midrange with clear vocals and detailed instrument representation.
- Crisp treble with good extension, providing sparkle without harshness or sibilance.
- Wide soundstage with good spatial depth for its size.
- Precise imaging and excellent instrument separation for a clear stereo field.
- Overall engaging and musical, suitable for critical listening and long sessions.
- 平衡的音质,略带温暖,适用于各种音乐类型。
- 紧凑、受控的低频,具有不错的延伸,但没有极端的低频。
- 平滑、自然的中频,清晰的声音和细致的乐器表现。
- 清脆的高频,延伸良好,提供亮度而不刺耳或带有沙哑感。
- 宽广的声场,尺寸上具有良好的空间感。
- 精确的声像和出色的乐器分离,呈现清晰的立体声效果。
- 整体音质引人入胜,适合严谨的聆听和长时间的聆听体验。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- Sleek, compact, and elegant bookshelf speaker design, fitting well in various interiors.
- Available in luxurious finishes like walnut or black ash real wood veneers.
- 2-way design with soft-dome tweeter and woofer positioned for optimal acoustics.
- Minimalistic yet refined appearance that blends well with different setups.
- Built with solid MDF enclosure, ensuring sturdiness and resonance control.
- Well-braced cabinet construction reduces vibrations, enhancing sound clarity.
- High-quality materials, including advanced woofers and fabric or metal dome tweeters.
- Front baffle is smooth for clean design and to minimize diffraction issues.
- Rear features bass reflex port for improved low-end performance.
- Gold-plated speaker wire terminals ensure reliable, high-quality connections.
- 设计简洁、紧凑、优雅,适合各种室内风格。
- 提供豪华的饰面,如胡桃木或黑色灰木真实木纹。
- 2路设计,配备软穹顶高音单元和低音单元,布局优化声学效果。
- 极简主义但精致的外观,能够与不同的音响系统完美融合。
- 采用坚固的MDF外壳,确保稳固性和共振控制。
- 良好的加固结构减少振动,提升声音清晰度。
- 使用高质量材料,包括先进的低音单元和面料或金属穹顶高音单元。
- 前面板光滑,设计简洁,减少衍射问题。
- 后部配有低音反射端口,增强低频表现。
- 金镀音频连接端子,确保可靠的高质量连接。
✅SPECIFICATIONS 规格:🧾
- Low Frequency Load: Bass Reflex NRS
- Configuration: 2 way
- Drivers: One woofer 130 mm in fiberglass, one 25 mm Ferrofluid, back-vented soft dome tweeter
- Sensitivity: 86 dB SPL 2.83V/1m
- Frequency Response (amplitude): 50-20000 Hz ± 3 dB
- THD (non-linear distortion): -50 dB
- Acoustic crossover frequency: 1,950 Hz
- Alignment (litres): 9
- Rated Impedance: 4 Ohm
- Suggested Amplifiers (Sinusoidal Continuous Power): Rated for 50-100 W
- Size (HxWxD) mm: 320x200x270
- Weight: 8 kg
✅REFERENCES 根据:📑🫡
1. http://www.listeninn.com/product/407001-10797/Loudspeaker/
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46555612
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46557011
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46559512
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46642011
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46556111
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46611411
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46613311
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46610411
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46593811
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer 46613011
HomeSweetAudio98
Regular
Regular
Number of posts : 56
Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer Empty Re: Chario Italy w/ Soft Dome Tweeter | Fiberglass Midbass Hiper Mk ii Bookshelf Speaker Wood Veneer
Post by HomeSweetAudio98 Tue Nov 26, 2024 5:13 pm
HomeSweetAudio98
Regular
Regular
