Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp Empty Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp
Post by HomeSweetAudio98 Sun Nov 17, 2024 1:26 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥RARE FIND! Limited Production Edition w/ Signature Black Piano Gloss Finish Face Plate 🤩
💥★★★★★ SoundStage! Highly Recommended by Mike Fenech!🤩
💥This Preamp got SO MUCH HEADROOM even u can FELT the SENSE of EASE when music is playing🤯
💥稀有发现!限量生产版,配有签名黑色钢琴光泽面板 🤩
💥★★★★★ SoundStage!由Mike Fenech强力推荐!🤩
💥这款前级放大器提供超强的余量,您能感受到音乐播放时的轻松感🤯
🎵Pure UK Craftmanship w/ ALL UK Components such as Capacitors & 🤯250VA!🤯 Transformers!
🎵XLR Balanced Output
🎵Pure Class A Fully Balanced Differential  Discrete Input Stage
🎵Duo VFET "Tube Sound" Fully Balanced Differential Output Stage
🎵纯正英国工艺,采用全英国组件,如电容器和🤯250VA!🤯变压器!
🎵XLR平衡输出
🎵纯Class A全平衡差分分立输入阶段
🎵双VFET 晶体管 "胆味声音" 全平衡差分输出阶段
✅NOW ONLY RM 4680!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~😎
✅现在只需 RM 4680🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜😎
💎CONDITION 品像: 8.5/10 = LIKE NEW Condition | 新的一样
The Exposure Super 19 preamplifier stands out for its musicality and coherence, akin to other notable British brands like Naim. It imparts a warmth and smoothness, especially in the upper bass and lower mids, while maintaining clarity and dynamic sound. Although its pairing with Proac speakers revealed some limitations, with Epos speakers, the 19 preamp excelled, creating a seamless, lively soundstage with clear instrument separation and dynamic range. Despite some limitations in cable compatibility and detailed highs, the 19 preamp offers an engaging and emotional listening experience, showcasing its potential with careful system matching.
Exposure Super 19前级放大器因其音乐性和连贯性而脱颖而出,类似于其他著名的英国品牌如Naim。它尤其在中低频段表现出温暖和顺滑,同时保持清晰和动态的音质。虽然与Proac音箱的搭配暴露了一些局限性,但与Epos音箱搭配时,19前级放大器表现出色,创造了无缝且生动的声场,乐器分离清晰,动态范围广。尽管在电缆兼容性和高频细节方面有一些限制,但19前级放大器通过仔细的系统匹配,提供了引人入胜和富有情感的聆听体验。
- It shares musical qualities with renowned Brit brands like Linn and Naim but brings unique sonic attributes.
- Delivers musicality that enhances the sense of emotion in music, unlike some more clinical-sounding systems.
- Provides a warm, clear, and articulate midrange with smooth, detailed bass.
- Offers seamless coherency from mid-bass to lower highs, enabling clear musical reproduction.
- Creates a coherent, dynamic soundstage with good instrument separation, although image size may be slightly smaller.
- Less detailed highs compared to more refined setups like Proac/Golden Tube combinations.
- Works well with speakers like Epos ES-11, showing strong synergy and dynamic range.
- Limited compatibility with certain speaker brands such as Proac, which may not match as well.
- Requires speaker cables with specific high capacitance and inductance for optimal performance.
- Utilizes only banana pin connectors, potentially limiting cable options.
- 具有与知名英国品牌如 Linn 和 Naim 类似的音乐特性,但也带来独特的音质特点。
- 呈现出增强音乐情感的音乐性,不像一些听起来较为临床的系统。
- 提供温暖、清晰且清晰的中音,以及平滑而细致的低音。
- 从中低音到较高频段实现无缝一致,使音乐表现清晰。
- 创建连贯且动态的声场,具有良好的乐器分离度,尽管声像尺寸可能略小。
- 与如 Proac/Golden Tube 组合等更精致的设置相比,高音细节较少。
- 与 Epos ES-11 等扬声器表现良好,展现出较强的协同性和动态范围。
- 与某些扬声器品牌(如 Proac)兼容性有限,可能无法很好匹配。
- 需要具有特定高电容和高电感的扬声器电缆才能获得最佳性能。
- 仅使用香蕉插头连接器,可能会限制可用的电缆选项。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- It has a classic, minimalist design with a basic black color scheme.
- It features a compact build with dimensions of 17.25 inches wide, 3.5 inches high, and 12 inches deep.
- The unit includes a large, easy-to-use rocker on/off switch positioned on the left side of the faceplate.
- Equipped with three control knobs on the right side for volume control, source selection (six line-level inputs), and tape selection.
- The preamplifier uses XLR outputs in addition to standard RCA jacks, emphasizing the superior connector quality even though the design is not balanced.
- The build quality facilitates compatibility with various audio setups but highlights the importance of suitable speaker and cable matching.
- 采用经典的极简设计,外观为基本的黑色。
- 体积紧凑,尺寸为17.25英寸宽、3.5英寸高和12英寸深。
- 面板左侧有一个大的、易于使用的摇杆式电源开关。
- 右侧有三个控制旋钮,分别用于音量控制、信号源选择(六个线路电平输入)和录音带选择。
- 前置放大器提供XLR输出和标准RCA接口,强调了连接器质量的优势,尽管设计并非平衡型。
- 设备的构建质量使其适用于各种音频系统,但突出了匹配合适扬声器和电缆的重要性。
✅SPECIFICATIONS 规格:🧾
- Frequency response: 20Hz - 20kHz -/+ 0.5dB
- Input & output connections: XLR & RCA sockets
- Output voltage (impedance): 1V ms, max. 12V (3ohms)
- Power supply: 250VA
- Dimensions: 440 x 90 x 306 (mm)
- Weight: 9.0kg
✅REFERENCES 根据:📑🫡
1. https://exposurehifi.com/archive-area/
2. https://exposurehifi.com/wp-content/uploads/2024/08/Classic_XVIII_18_Super_Amplifier_and_XIX_19_Pre_Amplifier_SoundStage_August_1997.pdf
3. https://exposurehifi.com/wp-content/uploads/2024/08/Classic-IV-XIII-XV-XVII-XVIII-XXI-XXV-Integrated-Pre-Stereo-Mono-Amplifiers.pdf
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp 46274210
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp 46259310
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp 46261010
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp 46262910
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp 46262810
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp 46262911
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp 46276110
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp Screen10
HomeSweetAudio98
Number of posts : 108
Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp Empty Re: Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp
Post by HomeSweetAudio98 Tue Dec 03, 2024 11:01 pm
HomeSweetAudio98
