Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker Empty Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker
Post by HomeSweetAudio98 Sun Nov 17, 2024 3:03 pm
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥★★★★★ Stereophile Highly Recommend 强力推荐!🤩
💥Tweaked & Tuned by John Bau the Founder of Spica!🤩
🎵UK Pure Craftmanship w/ Real Wood Light Cherry Finish
🎵Design Evolution from the TC-50: Taller, Narrower, Angled Baffle
🎵Unique Crossover Topology for Time-Coherent Performance
🎵Increased Internal Volume of the Cabinet
🎵Reflex Port and QB3 Alignment for Enhanced Low-Frequency Response
🎵Port Design: 90° Bend and Placement Considerations
🎵 VIFA Chambered Cloth Dome Tweeter
🎵 Peerless Polypropylene-coned Woofer
🎵Front Baffle Design with 1"-Thick Felt Blanket
🎵Resonance Damping and Radiation Pattern Modification
🎵Grille Frame Integration for Optimal Sound Performance
🎵Internal Felt for Minimizing Woofer Reflections
🎵Bracing for Structural Integrity
🎵Crossover Construction and Components
🎵Bi-Wiring Capability with Modest Internal Wiring
💥HELP FRIEND to SALE🤝
✅NOW ONLY RM3780 w/ Original Grilles!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~😎
✅现价仅 RM3780,附原装网罩!🤯 将它放在您的Hi-Fi音箱架上!🤩 炫耀吧 ~😎
💎CONDITION 品像: 7.5/10 = Great | 很好
💥"Every audio reviewer lives for the moment when he or she hears true high-end sound quality emanating from affordable components. Which is why I got excited by the Spica TC-60. These speakers produce a sound that is much better than anyone with only so much to spend has any right to expect. Yes, there are compromises—the bass lacks a bit of pace, there aren't quite the degrees of detail and transparency offered by the similarly priced Dunlavy SC-Is, and you shouldn't choose these speakers if you want to play your music at rave levels in a large room. But within those limits, the TC-60 produces a big, enveloping sound with more bass and space than you'd believe possible at the price. Recommended." by John Atkinson from Stereophile
“每个音频评论员都渴望在价格合理的组件中听到真正的高端音质。这就是为什么我对 Spica TC-60 感到兴奋的原因。这些扬声器产生的声音远远超出了那些预算有限的人所能期望的水平。是的,确实有一些妥协——低音的节奏感稍显不足,细节和透明度也不如同价位的 Dunlavy SC-I 那样出色,如果你想在大房间里以狂欢音量播放音乐,也不应选择这些扬声器。但在这些限制范围内,TC-60 能够呈现出一个宽广、包围感十足的声音,低音和空间感远超你对这个价格的预期。推荐。” — John Atkinson,Stereophile💥
- Initial impression: Impressive sound but slightly too sweet-toned.
- Placement: Optimized with 24" stands and small cones to tilt the front up for the best axis.
- Overall sound: Inviting, with a lack of top-octave air in absolute terms.
- Bass performance: Surprisingly deep, handling down to 31.5Hz with minimal doubling, but wind noise and pipe tones audible from the port at higher levels.
- Bass extension: Excellent for a small speaker, providing enough bass for musical satisfaction.
- Rock music handling: Good performance, especially on tight bass guitar; some limitations on deep bass.
- Orchestral music handling: No sonic anemia, good power range, clean sound at levels below 95dB, with a laid-back balance.
- High-level performance: Low treble can become biting, emphasizing fizzy edges on some recordings.
- Mid-treble quality: Very clean and detailed, with excellent treble detail from the VIFA tweeter.
- Soundstage: Huge and atmospheric, though not as sharply defined as some higher-end speakers.
- Pace and rhythm: Slightly lacking, making some recordings sound ponderous; not as fast as some more expensive models.
- Midrange: Natural and open, with occasional lower-midrange congestion.
- Overall: Enveloping soundstage and natural midrange, with some minor limitations in bass pace and occasional congestion.
- 初步印象:声音令人印象深刻,但音调略显过甜。
- 放置:使用24英寸音响支架和小型音响垫优化放置,将前端稍微倾斜以获得最佳轴线。
- 整体声音:声音温暖宜人,但在绝对意义上缺乏高频的空气感。
- 低音表现:令人惊讶地深沉,可以处理低至31.5Hz的频率,且双音现象较少,但在较高音量下从端口发出的风噪音和管风琴音色仍然可闻。
- 低音延伸:对于一款小型扬声器来说,低音表现非常出色,提供了足够的低音来满足音乐的需求。
- 摇滚音乐表现:表现良好,尤其在紧凑的低音吉他上;但在处理深层低音时有所限制。
- 管弦乐音乐表现:没有明显的声音缺乏,功率范围适中,低于95dB时声音清晰,整体声音较为温和。
- 高音表现:低音频率的高音可能会有些刺耳,在某些录音中,突出尖锐的细节。
- 中高频质量:非常干净、细致,来自VIFA高音单元的高频细节表现优秀。
- 声场:宽广且富有氛围感,虽然不如一些高端扬声器那样定义清晰。
- 节奏感和律动:略显不足,让某些录音听起来稍显沉闷,速度不如一些更昂贵的型号。
- 中频:自然且开放,但偶尔会出现低中频的拥挤感。
- 总体评价:拥有令人包围的声场和自然的中频,但在低音节奏和偶尔的音频拥挤上存在一些小缺陷。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- Spica's TC-60 design resembles the discontinued TC-50, but is taller, narrower, and features an angled front baffle.
- The speaker cabinet is twice the internal volume of the TC-50.
- A 1.5"-diameter reflex port at the rear base tunes the enclosure to a "QB3" alignment.
- The QB3 port design bends 90° to avoid interference with the front baffle, and terminates near the side wall.
- The cabinet construction includes a brace connecting the front and rear walls.
- Felt is used extensively in the design: covering the front baffle, internal surfaces, and grille frame, reducing resonances and modifying radiation patterns.
- The crossover design uses a fourth-order Bessel low-pass filter for the woofer and a first-order high-pass filter for the tweeter, optimizing time-coherence and flat amplitude response.
- Components in the crossover include ferrite-cored inductors, plastic-film capacitors, and are mounted on a printed circuit board near the rear wall.
- Bi-wiring is supported with two sets of five-way binding posts, though internal wiring is a basic 18-gauge.
- The speaker features a 1" double-chambered cloth-dome tweeter from VIFA and a Peerless polypropylene-coned 6.5" woofer for high dynamic range.
- The speaker performs best with the grille on due to the felt profile and radiation pattern control.
- Spica的TC-60设计类似于停产的TC-50,但更高、更窄,并且具有倾斜的前面板。
- 扬声器的外壳体积是TC-50的两倍。
- 在后面板底部有一个直径为1.5英寸的反射端口,将外壳调谐为“QB3”对齐。
- QB3端口设计弯曲90°,避免与前面板干涉,并且在侧壁附近终止。
- 外壳结构包括连接前后墙的支撑条。
- 在设计中广泛使用了毛毡:覆盖前面板、内部表面和网罩框架,减少共振并改变辐射模式。
- 分频器设计采用了第四阶贝塞尔低通滤波器用于低音单元,第一阶高通滤波器用于高音单元,优化了时间一致性和平坦的幅度响应。
- 分频器组件包括铁氧体核电感器、塑料薄膜电容器,并安装在后墙附近的印刷电路板上。
- 提供了两组五向接线端子,支持双线分频,但内部接线是基本的18号线。
- 扬声器采用VIFA的1英寸双腔布质圆顶高音单元和Peerless的聚丙烯锥形6.5英寸低音单元,具有高动态范围。
- 由于毛毡轮廓和辐射模式控制,扬声器最好配合网罩使用。
✅SPECIFICATIONS 规格:🧾
- Released: 1994
- Description: Two-way, stand-mounted, reflex-loaded (QB3 alignment) loudspeaker
- Drive-units:
  - 1" (25mm) impregnated cloth-dome tweeter
  - 6.5" (165mm) polypropylene-cone woofer
- Measured crossover frequency: 3.4kHz
- Electrical crossover slopes:
  - First-order, 6dB/octave, high-pass to tweeter
  - Fourth-order Bessel, 24dB/octave, low-pass to woofer
- Frequency response: 48Hz–20kHz (-3dB)
- Sensitivity: 87dB/W/m (2.83V)
- Nominal impedance: 8 ohms (5.6 ohms minimum at 10kHz)
- Power handling: 60W continuous, 120W peak
- Dimensions: 21.25" (540mm) H x 11.5" (292mm) W x 10.5" (267mm) D
- Weight: 26 lbs (11.8kg) each
- Finishes available: Natural wood veneers
- Matching "Gravity" stands: $250/pair
- Approximate number of dealers: 75 (Dec. 1994)
✅REFERENCES 根据:📑🫡
1.https://www.stereophile.com/standloudspeakers/1294spica/index.html
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
🎵HiFi Tweaking 调音
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46617110
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46725610
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46726710
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46699210
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46728810
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46727910
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46730810
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46724011
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46727510
Spica | Coherent Angled Baffle | VIFA Tweeter Peerless Woofer | Triangular TC-60 Bookshelf Speaker 46726610
HomeSweetAudio98
Regular
Regular
Number of posts : 66
