Exposure Limited Edition UK Transformers & Caps w/ VFET Pure Class A | XLR Super 18 XVIII Power Amp
PM Me Directly 直接找我
RARE FIND! Limited Production Edition w/ Signature Black Piano Gloss Finish Face Plate 🤩
★★★★★ SoundStage! Highly Recommended by Mike Fenech!🤩
稀有发现!限量生产版,配有签名黑色钢琴光泽面板 🤩
★★★★★ SoundStage!由Mike Fenech强力推荐!🤩
Pure UK Craftmanship w/ ALL UK Components
Quad Large PSU Capacitors
250VA Transformers
XLR Balanced Input
Pure Class A Fully Balanced Differential Discrete Input Stage
Quad VFET "Tube Sound" in Fully Balanced Differential Mode for Left & Right Channel
纯正英国工艺,采用全部英国组件
四个大型电源滤波电容
250VA变压器
XLR平衡输入
纯Class A全平衡差分输入阶段
四个VFET“管音”全平衡差分模式用于左右声道
NOW ONLY RM 4680!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~
现在只需 RM 4680🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜
CONDITION 品像: 8.5/10 = LIKE NEW Condition | 新的一样
The Exposure 18 Super power amplifier delivers a dynamic, musical sound with a smooth, detailed bass and a coherent midrange that enhances vocals and instruments. While it excels in musicality and clarity, its soundstage is slightly smaller and less fleshed out compared to other setups, and the highs aren't as detailed as some competitors. Despite these minor limitations, it provides excellent overall performance, especially when paired with the right speakers, making it a strong contender for audiophiles seeking an engaging and dynamic listening experience.
Exposure 18 Super功率放大器提供动态、富有音乐感的声音,低频平滑细腻,中频连贯,增强了人声和乐器的表现。尽管它在音乐性和清晰度方面表现出色,但与其他系统相比,其声场略显紧凑,且高频细节不如一些竞争对手。尽管存在这些小缺点,它仍然提供了出色的整体表现,尤其是与合适的扬声器搭配使用时,是寻求富有感染力和动态表现的音响爱好者的强力选择。~SoundStage! by Mike Fenech!
SOUND QUALITY REVIEW(音色评测):🤩
- The Exposure 18 Super amplifier delivers a sound that offering a dynamic, engaging listening experience.
- It has slightly more warmth in the upper bass, which can affect the lower mids, but this can be addressed with better cables.
- The amplifier excels in dynamic range, with both macro and micro dynamics well-represented.
- The highs are not as detailed as with other setups, and bass on the Epos speakers lacks some depth, but overall performance with this speaker pairing is strong.
- Matching with speakers is crucial for the best results, as the 18 Super’s performance can vary based on speaker choice.
- The amp's limitations with speaker cable compatibility (requiring high capacitance and high inductance cables) can affect performance, with supplied cables not always ideal.
- Overall, the 18 Super amplifier offers a very musical and engaging sound, though finding the right speaker and cables is key to getting the best out of it.
- Exposure 18 Super 功率放大器提供的声音具有动态、引人入胜的听感。
- 18 Super 在上低频部分稍微增加了温暖感,这可能会影响到中低频,但可以通过更换更好的线缆来解决。
- 放大器在动态范围方面表现优秀,无论是宏观还是微观动态都很到位。
- 与扬声器的搭配至关重要,18 Super 的表现会根据扬声器的不同而有所变化。
- 该放大器对扬声器线缆的兼容性有限(需要高电容和高电感的线缆),这可能会影响其表现,提供的线缆并不总是理想的。
- 总体来说,18 Super 放大器提供了非常富有音乐感和引人入胜的声音,但找到合适的扬声器和线缆是发挥其最佳表现的关键。
DESIGN & TECHNOLOGY 设计与科技:
- The Exposure 18 Super amplifier has a compact design, with dimensions of 17.25 inches wide, 3.5 inches high, and 12 inches deep.
- The front panel features a large rocker-style on/off switch and simple controls.
- The build quality is solid with a basic black finish, giving it a clean, no-frills appearance.
- The amplifier uses banana-only outputs for speaker connections, supporting easy bi-wiring if the speaker cables have compatible banana connectors.
- The 18 Super is rated at 70 watts per channel into 8 ohms and is claimed to drive most speakers effectively, excluding the most insensitive ones.
- Exposure uses RCA & XLR connectors for better connectivity, with RCA & XLR input on the amplifier.
- Speaker terminals are designed exclusively for banana plugs, which may limit cable options for some users.
- The amplifier's design prioritizes a straightforward, functional approach, with a focus on sound performance rather than extravagant styling.
- Exposure 18 Super 放大器设计紧凑,尺寸为 17.25 英寸宽,3.5 英寸高,12 英寸深。
- 前面板配有一个大型摇臂式开关和简单的控制按钮。
- 建造质量坚固,采用基本的黑色涂装,外观简洁实用。
- 放大器仅支持香蕉插头输出,用于扬声器连接,若扬声器线具有兼容的香蕉插头,则支持方便的双线连接。
- 18 Super 每声道功率为 70 瓦特(8 欧姆负载),声称可以有效驱动大多数扬声器,除了最不敏感的扬声器。
- Exposure 使用 RCA 和 XLR 连接器提供更好的连接性,放大器上同时有 RCA 和 XLR 输入。
- 扬声器端子仅支持香蕉插头,这可能会限制某些用户的电缆选择。
- 放大器设计注重简洁实用,专注于声音表现,而非奢华外观。
SPECIFICATIONS 规格:🧾
- Frequency response: 20Hz - 20kHz -/+ 0.5dB
- Input sensitivity/Impedance: 1.2V/100K ohms
- Input connections: 2 x RCA phono socket, 2 x XLR
- Outputs: 1 pair loudspeakers 4 - 16ohms, Bi-wire sockets included
- Continuous power output: 2 x 70W into 8 ohms
- Power supply: 250VA
- Dimensions: 440 x 90 x 306 (mm)
- Weight: 9.0kg
REFERENCES 根据:🫡
1. https://exposurehifi.com/archive-area/
2. https://exposurehifi.com/wp-content/uploads/2024/08/Classic_XVIII_18_Super_Amplifier_and_XIX_19_Pre_Amplifier_SoundStage_August_1997.pdf
3. https://exposurehifi.com/wp-content/uploads/2024/08/Classic-IV-XIII-XV-XVII-XVIII-XXI-XXV-Integrated-Pre-Stereo-Mono-Amplifiers.pdf
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
250VA Transformers
XLR Balanced Input
纯正英国工艺,采用全部英国组件
四个大型电源滤波电容
250VA变压器
XLR平衡输入
纯Class A全平衡差分输入阶段
SPECIFICATIONS 规格:🧾
- Weight: 9.0kg
REFERENCES 根据:🫡
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
DISCLAIMER 免责声明:
» Exposure Limited Edition UK Transformers & Capacitors Pure Class A XLR Super 19 XIX Pre Amp
» G&W w/ 600VA PSU | 8 VFET in Pure Class A | WIMA,Philips,Rubycon,BHC Caps | TW-A8SE Power Amp
» SUMO USA w/ 1400VA Power Transformer | VFET Pure Class A | 42000 uF Caps | THE NINE PLUS Power Amp
» Exposure XIX / 19 Preamp & Exposure Super XVIII / 18 Power Amp Combo
