Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker Empty Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker
Post by HomeSweetAudio98 Wed Nov 20, 2024 9:49 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥Designed by Ken lshiwata the Legend himself! 由传奇人物 Ken lshiwata 设计!🤩
🎵UK Pure Craftmanship w/ Woodgrain Finish 英国纯粹工艺,配木纹饰面
🎵19mm Mylar-Callote Soft Dome Tweeter 软圆顶高音单元
🎵160mm Translucent Polypropylene Material Midbass Driver 半透明聚丙烯材料中低音驱动单元
✅NOW ONLY RM 980 w/ Original Grilles!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~😎
✅现价仅 RM 980,附原装网罩!🤯 将它放在您的Hi-Fi音箱架上!🤩 炫耀吧 ~😎
💎CONDITION 品像: 8.5/10 = LIKE NEW | 很新
The Marantz LD-20 DMS offers a rich and natural sound profile, characterized by warm bass and detailed treble, thanks to its well-designed 2-way bass reflex system. It excels in reproducing vocals and acoustic instruments with clarity, making it ideal for audiophiles seeking balanced and immersive audio. With a frequency range of 40Hz to 30kHz and a sensitivity of 87dB, it handles diverse genres effectively, while its compatibility with standard amplifiers adds versatility. ~ Ken lshiwata
马兰士 LD-20 DMS 提供丰富而自然的声音表现,凭借其精心设计的双向低音反射系统,展现出温暖的低音和细腻的高音。它在还原人声和原声乐器方面表现出色,清晰度极高,非常适合追求平衡和沉浸式音效的音响发烧友。凭借40Hz到30kHz的频率范围和87dB的灵敏度,它能够有效处理各种音乐类型,同时其与标准功放的兼容性更增添了多功能性。~ Ken lshiwata
- The Marantz LD-20 DMS is a 2-way loudspeaker featuring a bass reflex enclosure and a frequency range of 40Hz to 22kHz, delivering a balanced and detailed sound.
- It is equipped with a 160mm cone bass/midrange driver and a 19mm dome tweeter, ensuring clarity in both low and high frequencies.
- The sensitivity of 87dB and impedance of 8Ω make it suitable for most amplifiers, with a power handling capacity of up to 60 watts.
- Known for its natural and warm sound profile, it performs especially well with vocals and instrumental music.
- Its design includes a wooden cabinet with a woodgrain finish and a detachable grille, adding to its aesthetic appeal.
- Marantz LD-20 DMS 是一款2路扬声器,采用低音反射音箱设计,频率范围为40Hz至22kHz,呈现出均衡且细腻的音质。
- 配备160mm锥形低音/中频驱动单元和19mm圆顶高音单元,确保低频和高频的清晰度。
- 灵敏度为87dB,阻抗为8Ω,适用于大多数功放,最大功率承受能力为60瓦特。
- 以自然温暖的音质而著称,特别适合人声和器乐音乐的表现。
- 设计包括木质音箱和木纹饰面,以及可拆卸的音罩,增加了其美学魅力。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- Compact, bookshelf design with a wooden case and a rosewood finish that adds a touch of elegance and durability to its appearance.
- Equipped with a detachable grille, allowing users to showcase the speakers' drivers if preferred.
- Features a two-way, two-driver system with a 160mm bass/midrange cone and a 19mm tweeter, supporting clear audio across frequencies.
- Bass reflex enclosure enhances low-frequency performance, making it suitable for diverse audio applications.
- Build dimensions of 230 x 240 x 365 mm and a modest weight ensure portability and adaptability for various spaces.
- Noted for high-quality materials and robust construction typical of Marantz products.
- 紧凑型书架设计,采用木质外壳和玫瑰木饰面,增加了外观的优雅感和耐用性。
- 配备可拆卸的音罩,允许用户根据个人喜好展示扬声器的驱动单元。
- 采用2路2驱动单元系统,配备160mm低音/中频锥形单元和19mm高音单元,支持各频段的清晰音频。
- 低音反射音箱增强了低频表现,使其适用于多种音频应用。
- 外形尺寸为230 x 240 x 365毫米,适中的重量确保了便携性,适应各种空间。
- 以高品质材料和坚固的结构著称,符合Marantz产品的一贯标准。
✅SPECIFICATIONS 规格:🧾
- Type: 2-way, 2-driver system
- Enclosure Type: Bass reflex
- Power Handling: 60W (RMS)
- Impedance: 8 ohms
- Sensitivity: 87 dB/W/m
- Frequency Response: 40 Hz to 30 kHz
- Drivers:
  - Bass/Midrange: 1 x 160 mm cone
  - Tweeter: 1 x 19 mm dome
- Grille: Detachable
- Dimensions: 230 x 240 x 365 mm (9.1 x 9.4 x 14.4 inches)
- Weight: 4.9 kg (10.8 lbs) per speaker
✅REFERENCES 根据:📑🫡
1.https://hifi-wiki.com/index.php?title=Marantz_LD_20_DMS&action=edit&redlink=1
2. https://zstereo.co.uk/2019/02/11/ken-ishiwata/
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45830910
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45813710
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45820210
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45847810
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45819910
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45830510
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45808710
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45807910
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45830511
Marantz Made in UK | Designed by Ken lshiwata | Mylar-Callote Tweeter | LD20 DMS Bookshelf Speaker 45820310
HomeSweetAudio98
Regular
Regular
Number of posts : 52
Registration date : 2024-10-30
