Paradigm Signature S6 Floorstanding Speaker (Used)
Description
DESIGN | 4-driver, 3-way floorstanding |
CROSSOVER | 3rd-order electro-acoustic at 2.0 kHz; 2nd-order electro-acoustic at 190 Hz (bass drivers) |
FREQUENCY RESPONSE ON-AXIS | ±2dB from 45 Hz – 45 kHz |
HIGH FREQUENCY DRIVER | 25-mm (1 in) P-Be dome, ferro-fluid damped / cooled, rear damping chamber with ARB fins and integrated heatsink, dual super-neodymium ring magnets, die-cast heatsink chassis, IMS/SHOCK-MOUNT |
MIDRANGE FREQUENCY DRIVER | 178-mm (7 in) Co-PAL cone, ferro-fluid damped / cooled, ATC chambers, 38-mm (1-1/2 in) dual-layer voice-coil, super-neodymium ring magnets, AVS die-cast heatsink chassis, IMS/SHOCK-MOUNT |
LOW FREQUENCY EXTENSION | 26 Hz (DIN) |
LOW FREQUENCY DRIVER | Two 178-mm (7 in) mineral-filled polypropylene cones, overmolded NLC surrounds, 38-mm (1-1/2 in) four-layer bifilar long-excursion voice-coils, massive hard ferrite magnets, AVS die-cast heatsink chassis, IMS/SHOCK-MOUNT |
SENSITIVITY ROOM / ANECHOIC | 91 dB / 88 dB |
FREQUENCY RESPONSE 30° OFF-AXIS | ±2dB from 45 Hz – 20 kHz |
SUITABLE AMPLIFIER POWER RANGE | 15 – 400 watts |
MAXIMUM INPUT POWER | 200 watts |
IMPEDANCE | Compatible with 8 ohms |
DIMENSIONS HXWXD | 43.75″ × 8.25″ × 13.5″ (111.1cm × 21.0cm × 34.3cm) |
WEIGHT | 70 lbs. (31.8 kg) |
FINISHES | , Piano Black |
(No Cover)
Conditions: 8/10
Price: RM 18,500.00 inclusive postage to West Malaysia
- Number of posts : 5927
» Paradigm Signature S6 Floorstanding Speaker (Used)
» Paradigm Signature S6 v.3 3-Way Floorstanding Speaker (Used)SOLD
» Paradigm Monitor 7 S7 Floorstanding Speaker (Used)
» Paradigm Signature S2 Bookshelf Speaker (Used)
