Naim Audio OLIVE Pure Class A Fully Discrete NAC 92 Preamp w/ Phono Stage & Remote
PM Me Directly 直接找我
RARE FIND! Limited Production OLIVE Series 🤩
稀有珍品!限量生产的 OLIVE 系列 🤩
Pure UK Craftmanship w/ ALL UK Components
Phono Stage Discrete Module in Class A Operation
DIN & RCA Input & Output
Pure Class A Input & Output Stage
Original Naim Remote
纯正英国工艺,全部使用英国原装组件
唱放级采用离散模块,工作于 A 类模式
DIN 和 RCA 输入输出接口
纯 A 类输入输出级
原装 Naim 遥控器
NOW ONLY RM 3980! 🤯 You CAN HAVE IT on your HIFI Rack!🤩 SHOW IT OFF ~
现在只需 RM 3980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜
PRE POWER 1 set Price at RM 7000 nett 前后级一套 RM 7000 nett
CONDITION 品像: 7.5/10 = Great | 很好
w/ Original Remote 有原装遥控器
"The Naim NAC 92/90 system may not be the most celebrated among Naim enthusiasts, but it delivers engaging, dynamic sound quality with clear separation between lows, mids, and highs, and tight bass. It handles a variety of music genres with finesse, from classical to electronica, making it a versatile and enjoyable system. While its build quality could be improved, it offers great musicality and precision when paired with the right components and setup, proving to be a solid entry-level option for many listeners."~Reviewers by audioreview!
“Naim NAC 92/90 系统可能不是 Naim 爱好者中最受推崇的型号,但它提供了引人入胜且充满活力的声音表现,低音、中音和高音之间的分离清晰,低音紧致。它能以优雅的方式处理多种音乐类型,从古典到电子音乐,展现出其多功能性和令人愉悦的聆听体验。尽管其做工还有改进空间,但当与合适的组件和设置搭配时,它展现出极佳的音乐性和精准度,是许多听众的可靠入门选择。”~来自 Audioreview 的评论!
SOUND QUALITY REVIEW(音色评测):🤩
- The Naim NAC 92/90 combo offers good sound quality, with realistic separation across lows, mids, and highs, and a tight bass. Users report that it handles a wide range of musical genres effectively, from classical to world music to electronica.
- The sound is engaging and dynamic, with strong musicality and clarity, making it enjoyable despite its status as an entry-level system.
- Proper system integration, including upgrade power supply or high-quality speaker cables, can further enhance its tonal richness and precision.
- When paired with well-matched components and positioned correctly, the system provides excellent rhythm and tonal balance, offering a fulfilling listening experience.
- Naim NAC 92/90 组合提供了良好的音质,低音、中音和高音的分离感真实自然,低音紧致有力。用户反馈它在处理从古典音乐到世界音乐再到电子音乐等广泛音乐类型方面表现出色。
- 声音表现引人入胜且充满活力,具有很强的音乐性和清晰度,使其尽管是入门级系统,但依然令人愉悦。
- 通过正确的系统整合,包括升级电源或使用高质量的音箱线,可以进一步提升其音色的丰富性和精准度。
- 当与匹配良好的组件搭配并正确摆放时,该系统能提供出色的节奏感和音色平衡,为听众带来令人满意的聆听体验。
DESIGN & TECHNOLOGY 设计与科技:
- The Naim NAC 92 preamplifier features a compact, minimalist design typical of Naim's "Olive Series," offering a durable and practical build.
- Solid metal casing minimizes interference and vibration, ensuring consistent performance.
- Comprehensive input facilities include Input 1 with RCA sockets, compatible with various source components, configurable for moving magnet or moving coil cartridges.
- Four additional inputs use high-quality lockable DIN sockets, ensuring a common signal ground for both channels to optimize performance.
- Two of these inputs provide full tape output and monitoring facilities.
- Carefully designed circuit topology results in a low noise floor and minimal distortion.
- The preamp handles the full output of any source without overloading, maintaining versatility across setups.
- It allows for the addition of external power supplies, enhancing its performance and reflecting Naim’s modular approach.
- Naim NAC 92 前级放大器采用紧凑且简约的设计,延续了 Naim “Olive 系列”的典型风格,具有耐用且实用的外观。
- 坚固的金属外壳可有效减少干扰和震动,确保性能的稳定性。
- 输入功能全面,包括带有 RCA 插口的输入 1,可兼容各种音源组件,并可配置为动磁(MM)或动圈(MC)唱头。
- 另外四个输入采用高质量的可锁定 DIN 插口,确保两个声道共用信号接地以优化性能。
- 其中两个输入提供完整的录音输出和监听功能。
- 精心设计的电路拓扑结构实现了低噪声底和极小的失真。
- 前级能够处理任何音源的完整输出而不失真,保持了在不同系统中的通用性。
- 它支持外部电源的接入,可进一步提升性能,体现了 Naim 模块化设计的理念。
SPECIFICATIONS 规格:🧾
General
- Manufacturer: Naim
- Model: NAC 92
- Years of manufacture: 1993 - 2000
- Manufactured in: Salisbury, England
- Colour: olive/black
- Type: Analogue
- Remote control: no
- Power consumption:
- Dimensions: 56 x 430 x 300 mm (H x W x D)
Connections
- Number of inputs: 5x Line In: 75 mV / 100 kOhm
- 1 input can be converted to a phono input by plug-in cards
Technical Data
- Frequency response:
- Distortion factor:
- Signal-to-noise ratio:
- Stereo channel separation:
- Tone control:
- Bass: no
- Treble: no
- Loudness: no
- High Filter: no
- Low Filter (Subsonic): no
- Mute: yes
- Direct/Line-Straight: no
Special Features
- Optional phono cards:
- 523 N (MM) 2 mV, 47 kΩ
- 523 S (MC) 100 µV, 470 Ω
- 523 K (MC) 100 µV, 560 Ω
- 523 E (MC) 400 µV, 560 Ω
REFERENCES 根据:🫡
1. https://www.avoptions.com/downloads/manuals/Naim-Audio-Preamplifiers-Manual-early-2000s.pdf
2. https://hifi-wiki.com/index.php/Naim_NAC_92
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
纯正英国工艺,全部使用英国原装组件
唱放级采用离散模块,工作于 A 类模式
DIN 和 RCA 输入输出接口
纯 A 类输入输出级
原装 Naim 遥控器
SPECIFICATIONS 规格:🧾
General
- Model: NAC 92
- Type: Analogue
Connections
Technical Data
- Tone control:
- Bass: no
- Treble: no
- Loudness: no
- High Filter: no
- Mute: yes
Special Features
REFERENCES 根据:🫡
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
DISCLAIMER 免责声明:
» Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp
» CHORD w/ XLR | UK Transformer & Caps | Pure Class A Fully Discrete CPA2200 Preamp Gold Black
» Onkyo Japan Fully Discrete Class A | Source Direct Technology R-1 P301 Preamplifier w/ Phono Stage
» NIKKO Japan w/ Phono Stage | Class A Biased Fully Discrete TRM-210 Integrated Amp in Real Wood Case
» LEAK Audio UK w/ Pure Class A Quad EF86 Tube Stage | VARISLOPE 2 STEREO Preamp w/ Separated PSU
