DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker Empty DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker
Post by HomeSweetAudio98 Sun Nov 24, 2024 7:15 pm
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
🤩DALI Signature Sound, Open, Fast, Dynamic w/ Natural Tone!
🤩SUPRISED Bass & Treble! Below 40Hz of Hefty Bass & Ultra High Frequency AIRY Extension!🤩
🤩 DALI标志性音质,开放、快速、动态,音色自然!
🤩 令人惊讶的低频与高频!40Hz以下的强劲低频和超高频的空气延伸!
💥Pure Denmark Craftmanship in Cherry Finish
💥Earlier Version of Wood Fibre Cone w/ Dampening Coating Midbass Driver at 1 Pair
💥Soft Textile Dome Tweeter
💥纯正丹麦工艺,樱桃木饰面
💥1对早期版本的木纤维锥盆并带阻尼涂层的中低音驱动单元
💥软质纺织圆顶高音单元
✅NOW ONLY RM 1680 w/ Original Grilles & Jumpers!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~😎
✅现价仅 RM 1680,附原装网罩和跳片!🤯 将它放在您的Hi-Fi音箱架上!🤩 炫耀吧 ~😎
💎CONDITION 品像: 8.5/10 = Mint | 非常好
The speakers deliver clear sound with smooth treble, a neutral midrange, and fast, dynamic bass. High frequencies are crisp and well-defined, thanks to the soft textile dome tweeter. While they offer a good soundstage and imaging. Easy to drive, they are compatible with a wide range of amplifiers, making them a versatile choice for various setups. ~ Reviewers from Audio Forums
这些扬声器提供清晰的音质,具有平滑的高音、中性的中频和快速、充满活力的低频。由于采用软质纺织圆顶高音单元,高频清晰且定义明确。它们提供了不错的音场和成像效果。易于驱动,兼容多种放大器,是各种音响系统中的多功能选择。~ 来自音响论坛的评论者
- The sound is generally clear, with a smooth treble and a neutral midrange.
- Bass performance is fast & dynamic.
- High frequencies are crisp and well-defined thanks to the soft textile dome tweeter.
- The speakers provide a decent soundstage.
- Imaging is described as good, with some clarity in spatial positioning compared to higher-end models.
- They are easy to drive, making them suitable for a wide range of amplifiers.
- 音质通常清晰,具有平滑的高音和中性的人声频率。
- 低频表现快速且充满活力。
- 由于采用了软质纺织圆顶高音单元,高频清晰且定义明确。
- 这些扬声器提供了一个不错的音场。
- 成像效果较好,与更高端的型号相比,在空间定位上有一定的清晰度。
- 它们易于驱动,适用于多种放大器。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- Compact, floorstanding speaker ideal for small to medium rooms.
- Dual input terminals support bi-wiring or bi-amping setups.
- Reversible, height-adjustable spikes for flexible floor placement.
- Features a bass reflex enclosure for enhanced sound output.
- Components:
  - 1-inch soft textile dome tweeter for clear high frequencies.
  - Two 5-inch wood fiber cone drivers for mids and bass.
- Frequency range: 42 Hz to 24 kHz; suitable for detailed mids and highs.
- Sensitivity of 90.5 dB, compatible with amplifiers of 25-125 W.
- Slim design with finishes in cherry, black ash, or light beech.
- Strengths: Natural sound, easy integration into room setups.
- Limitations: Limited bass depth and room-filling ability due to small drivers.
- 紧凑型落地音箱,适合小到中等大小的房间。
- 配备双输入端子,支持双线分音或双功放设置。
- 可调节高度的可逆尖钉,适应不同地面摆放需求。
- 采用低音反射式箱体设计,增强声音表现。
- 关键组件:
  - 1英寸软纺织圆顶高音单元,提供清晰的高频。
  - 两个5英寸木纤维锥形单元,负责中低频。
- 频率范围:42 Hz 至 24 kHz,适合精细中高频。
- 灵敏度90.5 dB,兼容25-125 W功率的功放。
- 修长设计,可选樱桃木、黑灰木或浅榉木外观。
- 优点:声音自然,易于融入房间布局。
- 局限性:由于驱动单元较小,低音深度有限,房间填充能力稍弱。
✅SPECIFICATIONS 规格:🧾
- Frequency Response ±3dB: 42 Hz-24 kHz
- Crossover Frequency: 3.1 kHz
- Sensitivity (2.83V/1m): 90.5 dB
- Nominal Impedance: 4 Ohm
- Maximum SPL: 110 dB
- Recommended Amplifier Power, 8 Ohm: 25-125 Watts
- High Frequency Driver: 1"
- Low Frequency Drivers: 2x5"
- Enclosure Type: Reflex, 43.5 Hz Tuning
- Placement: Floor
- Recommended Rear Wall Distance: 10-100 cm / 4-40 in
- Dimensions (cm) (HxWxD): 75 x 17.7 x 24.9
- Dimensions (in) (HxWxD): 29.5 x 7 x 9.8
- Weight (kg/lb): 8.8 / 19.4
✅REFERENCES 根据:📑🫡
1.https://www.dali-speakers.com/media/3259/blue-series-brochure.pdf
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46797910
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46617111
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46796610
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46803511
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46728910
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46803210
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46727210
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46734610
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46802012
DALI Made in Denmark w/ Wood Fibre Midbass | Soft Textile Dome Tweeter | Blue 3003 Floorstand Speaker 46803211
HomeSweetAudio98
Regular
Regular
Number of posts : 57
