Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp Empty Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp
Post by HomeSweetAudio98 Tue Nov 26, 2024 12:52 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥RARE FIND! Limited Production OLIVE Series 🤩
💥稀有珍品!限量生产的 OLIVE 系列 🤩
🎵Pure UK Craftmanship w/ ALL UK Components
🎵Naim UK Power Transformer
🎵Pure Class A Fully Discrete Input Stage
🎵Class A Biased Fully Discrete Output Stage Transistors
🎵DIN Input
🎵纯正英国工艺,全部使用英国组件
🎵Naim自制英国电源变压器
🎵纯Class A完全分立输入阶段
🎵Class A偏置完全分立输出阶段晶体管
🎵DIN输入
✅NOW ONLY RM 3980! 🤯 You CAN HAVE IT on your HIFI Rack!🤩 SHOW IT OFF ~😎
✅现在只需 RM 3980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜😎
✅PRE POWER 1 set Price at RM 7000 nett 🤝 前后级一套 RM 7000 nett 🤝
💎CONDITION 品像: 8.5/10 = LIKE NEW | 新的一样
💥The Naim NAP 90 Olive offers a dynamic and engaging sound experience, with excellent rhythmic drive and timing that brings music to life. Its natural tonal balance provides clear mids and highs, while delivering tight and controlled bass. The amplifier excels in creating a wide, immersive soundstage with precise imaging, maintaining clarity even during complex musical passages. It prioritizes emotional connection to the music, making it ideal for genres that emphasize rhythm and energy, such as rock, jazz, and classical, offering a musical, engaging performance over analytical detail.​💥~Reviewers by audioreview!
💥Naim NAP 90 Olive 提供了一种动态且富有吸引力的声音体验,出色的节奏驱动感和时间控制让音乐焕发生命力。其自然的音调平衡带来了清晰的中频和高频,同时低频紧凑且控制力强。这款放大器擅长营造宽广且沉浸感十足的声场,精准的声像定位让复杂的音乐段落依然保持清晰。它更注重与音乐的情感连接,特别适合强调节奏和能量的音乐类型,如摇滚、爵士和古典,提供富有音乐感和感染力的表现,而非过度分析的细节。💥~来自 audioreview 的评测!
- Delivers a dynamic and engaging sound signature, characteristic of Naim's house sound.
- Excellent rhythmic drive and timing, enhancing the musicality of playback.
- Produces clear, detailed mids and highs, with a natural tonal balance.
- Offers tight and controlled bass, contributing to a well-rounded audio experience.
- Maintains precision and clarity even during complex musical passages.
- Creates a wide and immersive soundstage with accurate imaging.
- Focuses on emotional connection to the music, prioritizing musical engagement over analytical detail.
- Well-suited for genres emphasizing rhythm and energy, such as rock, jazz, and classical.
- 呈现动态且富有吸引力的声音特质,体现 Naim 的经典音质风格。
- 节奏驱动感和时间控制出色,增强音乐表现力。
- 中高频清晰细腻,音调自然平衡。
- 低频紧致且控制力强,带来均衡的听觉体验。
- 即使在复杂音乐段落中,也能保持精准和清晰。
- 声场宽广且具有沉浸感,声像定位准确。
- 注重与音乐的情感连接,更倾向于音乐感染力而非纯分析细节。
- 特别适合强调节奏感和活力的音乐类型,如摇滚、爵士和古典音乐。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- Input stage features Naim’s proprietary circuit design, optimized for minimal signal degradation and enhanced musicality.
- Uses DIN connectors for inputs, aligning with Naim's standards for reduced signal loss and better shielding.
- Output stage delivers approximately 30W per channel into 8-ohm loads, capable of driving a wide range of speakers with ease.
- High-current design ensures dynamic sound and precise control over speaker drivers.
- Employs advanced thermal management systems to maintain performance consistency and reliability.
- Compact design with a robust aluminum chassis and a distinctive olive-green finish, combining durability with timeless aesthetics.
- Simplified signal paths and high-quality components reduce distortion and maintain signal purity.
- Known for rhythmic accuracy, tonal balance, and a natural, engaging sound presentation.
- Designed for seamless integration with other Naim components for optimal system performance.
- 输入级采用 Naim 专有电路设计,优化信号完整性,增强音乐表现力。
- 使用 DIN 输入接口,与 Naim 标准一致,减少信号损耗并提高屏蔽效果。
- 输出级每声道可提供约 30W(8 欧姆负载),能够轻松驱动多种扬声器。
- 高电流设计确保动态声音表现,并精准控制扬声器单元。
- 配备先进的热管理系统,保持性能一致性和可靠性。
- 紧凑设计,采用坚固的铝制外壳和标志性的橄榄绿色涂装,兼具耐用性和经典美感。
- 简化的信号路径和高品质组件,有效减少失真并保持信号纯净度。
- 以节奏精准、音调平衡和自然吸引力的声音表现而闻名。
- 设计与其他 Naim 组件无缝配合,优化系统性能。
✅SPECIFICATIONS 规格:🧾
- Power Output:
  - 30 Watts per channel into 8 ohms,
  - 45 Watts per channel into 4 ohms
- Frequency Response: 10 Hz to 50 kHz, ±0.5 dB
- Input Sensitivity: 0.5 V for rated output
- Input Impedance: 18 kΩ
- Speaker Impedance Compatibility: 4–8 ohms
- Connections:
  - Inputs: DIN socket for signal input
  - Outputs: 4mm banana plug sockets for speaker connections (Naim-style)
- Power Supply: Internal, connected directly to mains
- Construction: Fully discrete transistor design, aluminum Olive-style casing
- Dimensions:
  - Width: 432 mm (17 inches)
  - Depth: 300 mm (11.8 inches)
  - Height: 70 mm (2.75 inches)
- Weight: Approximately 5.5 kg (12 lbs)
✅REFERENCES 根据:📑🫡
1.http://www.audioreview.com/product/amplification/amplifiers/naim/nap-90.html
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46805610
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46788910
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46793910
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46715710
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46777210
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46797210
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46802610
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp 46803514
Naim Audio UK OLIVE Large Toroidal Transformer Pure Class A Biased Fully Discrete NAP 90 Power Amp Naim-n10
HomeSweetAudio98
Regular
Regular
Number of posts : 57
