ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage Empty ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage
Post by HomeSweetAudio98 Wed Nov 27, 2024 1:52 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥CLASSIC Silver Knobs & Faceplate Vintage ROTEL w/ Real Wood Enclosure🤩
💥银色面板复古NIKKO,配有实木外壳 🤩
🎵Pure Japan Craftmanship w/ ALL Japan Components
🎵Pure Class A Fully Discrete SANYO LA-3133 Phono Stage
🎵Pure Class A Fully Discrete Nippon Electric NEC 2SC1222 Input Stage
🎵Class A Biased Fully Discrete SANYO STK015 Output Transistors
🎵Multi Voltage Power Transformer from Japan
🎵纯正日本工艺,所有组件均为日本制造
🎵纯甲类全分立式 SANYO LA-3133 唱放电路
🎵纯甲类全分立式日本电气 (NEC) 2SC1222 输入级
🎵甲类偏置全分立式 SANYO STK015 输出晶体管
🎵多电压日本制造的电源变压器
✅NOW ONLY RM 980! 🤯 You CAN HAVE IT on your HIFI RACK!🤩 SHOW IT OFF ~😎
✅现在只需 RM 980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜😎
💎CONDITION 品像: 8/10 = Excellent | 非常好
The ROTEL RA-212 delivers a classic vintage sound characterized by warmth, natural balance, and rich musicality. Its clear midrange excels in vocal and instrumental reproduction, while the smooth treble and tight, controlled bass ensure a well-rounded listening experience. With a high-quality phono stage and Class A design, it offers exceptional clarity and tonal refinement, making it equally suited for critical audiophile listening and casual enjoyment across various music genres.
ROTEL RA-212 具有经典的复古音质,表现出温暖、自然平衡和丰富的音乐性。清晰的中频在人声和器乐重现方面表现出色,顺滑的高音和紧致、控制良好的低音确保了全面的聆听体验。配备高品质唱放级和甲类设计,它提供了卓越的清晰度和音色细腻度,适合挑剔的发烧友聆听以及多种音乐风格的日常享受。
💥~Reviewers by Audio Forums!
- Delivers warm, natural, and balanced sound, characteristic of vintage amplifiers.
- Clear and detailed midrange, making it ideal for vocal and instrumental music.
- Smooth and refined treble without harshness, providing an enjoyable listening experience.
- Tight and controlled bass response, though not overly pronounced, suitable for various music genres.
- High-quality phono stage ensures excellent sound reproduction for vinyl playback.
- Class A design contributes to its rich tonal character and musicality.
- Maintains low distortion levels, ensuring clarity even at higher volumes.
- Well-suited for critical listening as well as casual enjoyment.
- 提供温暖、自然且均衡的音质,具有复古功放的典型特点。
- 中频清晰细腻,非常适合人声和器乐音乐。
- 高音顺滑细腻,无刺耳感,带来愉悦的听感体验。
- 低音紧致且控制力强,但不过于突出,适合多种音乐风格。
- 高品质的唱放级确保黑胶播放时的卓越音质。
- 甲类设计增强了其丰富的音色和音乐性。
- 保持低失真水平,即使在高音量下也能保证清晰度。
- 适合严谨的音质欣赏,同时也适用于日常听音享受。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
🎵Input Stage:
  - Uses NEC 2SC1222 transistors in the pre-amplifier section for Class A operation.
  - Incorporates the SANYO LA-3133 integrated circuit for the phono stage.
🎵输入级:
  - 使用日本电气 (NEC) 2SC1222 晶体管用于前置放大器部分,支持甲类工作模式。
  - 集成三洋 (SANYO) LA-3133 集成电路用于唱放级。
🎵Output Stage:
  - Equipped with SANYO STK015 transistors for the power amplifier section, operating in Class A biased mode.
🎵输出级:
  - 配备三洋 (SANYO) STK015 晶体管,用于功率放大器部分,采用甲类偏置模式。
🎵Technology and Design:
  - Full discrete Class A circuitry for input and phono stages, ensuring high audio fidelity.
  - Features multi-voltage transformers for power adaptability.
  - Uses high-quality components like 1S1850 rectifiers for power stability.
  - Includes variable resistors for balance, volume, treble, and bass adjustments.
  - Integrated safety components such as fuses and circuit protectors.
  - User-friendly design with switches for phono input selection, function selection, and power.
🎵技术与设计:
  - 输入级和唱放级采用全分立式甲类电路,确保高音质表现。
  - 配备多电压变压器,适应不同电源需求。
  - 使用高品质组件,例如 1S1850 整流器,保证电源稳定性。
  - 包括可调电阻,用于调节平衡、音量、高音和低音。
  - 集成安全组件,如保险丝和电路保护器。
  - 人性化设计,配有唱放输入选择开关、功能选择开关和电源开关。
✅SPECIFICATIONS 规格:🧾
- Continuous Power Output: 10 watts per channel, min. RMS, both channels driven into 8 ohms from 50 to 20,000 Hz with no more than 1% total harmonic distortion
- IM Distortion: not more than 0.2% at rated output, ±1 dB
- Frequency Response: 15 to 50,000 Hz, ±3 dB at 1 watt per channel
- Damping Factor: 40 at 1 kHz
- Signal to Noise Ratio:
  - Phono: more than 65 dB
  - Tape, Aux, Tuner: more than 80 dB
  - Residual: less than 1 mV
- Input Sensitivity/Impedance (at rated output, 1 kHz):
  - Phono (magnetic): 2.8 mV/47 kohms
  - Phono (ceramic): 150 mV/100 kohms
  - Tuner: 150 mV/50 kohms
  - Aux, Tape: 150 mV/50 kohms
- Output Level (Tape Out): 350 mV/3.3 kohms (5 mV input)
- Phono Overload: more than 90 mV
- Phono Equalization: RIAA standard ±1.5 dB
- Crosstalk: 50 dB (overall at 10 kHz)
- Bass Control: ±10 dB at 100 Hz
- Treble Control: ±10 dB at 10 kHz
- Loudness: +7 dB/100 Hz, +3 dB/10 kHz
- General:
  - Power Consumption: 100 watts
  - Dimensions: 335 mm x 240 mm x 115 mm (W x D x H)
  - Weight: 4 kg/8.8 lbs
✅REFERENCES 根据:📑🫡
1.https://www.hifiengine.com/manual_library/rotel/ra-212.shtml
2.https://rotel.com/sites/default/files/product/manuals/RA-212-OM.pdf
3.https://www.hifiengine.info/rotel/ra-212-tm.pdf
4.https://www.radiomuseum.org/r/rotel_integrated_stereo_amplifier_ra_212.html
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46797914
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46801710
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46802110
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46803426
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46803425
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46803427
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46844510
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46725810
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage 46735910
ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage Screen17
HomeSweetAudio98
Regular
Regular
Number of posts : 52
