NAD UK 600VA Large Power Transformer | 200W MAX Power PER Channel | AV716 Stereo Amplifier Capable
PM Me Directly 直接找我
1st NAD Audio Visual Product 🤩
Designed & Engineered from UK England
200 Watts MAX Power PER Channel in Stereo
Subwoofer Output
Biwire Speaker Terminal
NOW ONLY RM 980! 🤯 You CAN HAVE IT on your HIFI RACK!🤩 SHOW IT OFF ~
现在只需 RM 980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜
Retails for 售价 RM3300++ (750 USD$)!🤯
CONDITION 品像: 8.5/10 = LIKE NEW | 新品般
The sound quality of this amp is exceptional, offering a warm, clear, and highly musical presentation that excels in 2-channel stereo. It provides impressive stereo separation, depth, and tight, smooth bass with excellent rhythm and timing, rivaling amplifiers priced above $5,000. Its ability to perform well with a variety of speakers, from neutral to revealing models, ensures a rich, emotional listening experience. Many users consider it near-perfect for stereo use, and its sound quality remains outstanding even at higher volume levels, outperforming high-end brands like Luxman, Yamaha, Rotel, and Pioneer.
这款功放的音质非常出色,提供温暖、清晰且富有音乐感的表现,在2通道立体声方面表现尤为突出。它具有令人印象深刻的立体声分离、深度和紧凑平滑的低音,节奏感和时间感极佳,可与价格超过5000美元的功放媲美。它在各种扬声器上都能表现出色,无论是中性还是表现力强的扬声器,都能确保丰富而富有情感的聆听体验。许多用户认为它在立体声使用上几乎完美,即使在较高音量下,音质也依然出色,超越了像Luxman、Yamaha、Rotel和Pioneer等高端品牌。
~Reviewers by audioreview !
SOUND QUALITY REVIEW(音色评测):🤩
Stereo Use:
- Excellent sound quality for 2-channel stereo, with a warm, clear, and musical presentation
- High-quality stereo separation, imaging, and depth
- Rich bass, tight and smooth, with great rhythm and timing
- Comparable to amps in the $5,000+ range
- Performs well with different types of speakers, including neutral and revealing models
- Very musical sound that brings out emotion and allows listeners to enjoy the music without over-analyzing it
- Better than many high-end brands like Luxman, Yamaha, Rotel, and Pioneer
- Sound quality excels even at higher volume levels
- For 2-channel stereo, considered near-perfect by many users
立体声使用:
- 2通道立体声的音质极好,呈现出温暖、清晰和富有音乐感的声音
- 高质量的立体声分离、成像和深度
- 丰富的低音,紧凑平滑,节奏感和时间感出色
- 可与价值超过5000美元的功放媲美
- 在不同类型的扬声器上表现良好,包括中性和表现力强的型号
- 非常具有音乐感的声音,能够引发情感,让听众享受音乐而非过度分析
- 比许多高端品牌如Luxman、Yamaha、Rotel和Pioneer更好
- 即使在较高音量下,音质也表现优异
- 对于2通道立体声来说,被许多人认为几乎完美
Audio Visual Use:
- The AV-716 delivers excellent Dolby Pro Logic decoding with high-quality sound separation, frequency response, and low distortion, especially in the surround channels.
- The surround output is clean with low noise, ideal for soundtracks with wide dynamic ranges.
- Hall mode enhances spatiality without compromising vocal clarity, offering adjustable settings to optimize sound.
- Tone controls allow for subtle tonal adjustments without going to extremes, preserving balance.
- The Selective Tone button's boosts can be too imposing and should be used cautiously.
- Overall, sound performance is solid with impressive clarity, low noise, and a high dynamic range, making it a strong performer for its price.
视听使用:
- AV-716 提供出色的杜比Pro Logic解码,具有高质量的声音分离、频响和低失真,尤其是在环绕声道中。
- 环绕输出清晰,噪声低,适合具有宽动态范围的音轨。
- Hall模式增强了空间感,而不会损害人声的清晰度,提供可调节设置以优化声音。
- 音调控制允许进行微妙的音调调整而不会过度,保持平衡。
- 选择性音调按钮的增益可能过于强烈,应该谨慎使用。
- 总体而言,音质表现坚实,清晰度高,噪声低,动态范围广,性价比出色,是一款表现强劲的产品。
DESIGN & TECHNOLOGY 设计与科技:
- The NAD AV-716 is NAD's first A/V receiver, focusing on essential features and high performance.
- The core technology includes a Dolby Pro Logic decoder using a "latest-generation" analog decoding chip for low-noise outputs.
- It features a Hall mode for music enhancement, providing delayed reflections through surround speakers to improve spaciousness.
- Rated power is 80 watts per channel into 8 ohms in stereo mode, with 55 watts to front speakers and 20 watts to surround speakers in surround mode.
- The receiver includes a multi-tuning AM/FM stereo tuner with 40 presets, 6 preset banks, and good selectivity, distortion, and noise performance.
- Inputs are provided for a phono cartridge, CD player, two tape decks, two VCRs, and a playback-only video source.
- Tone controls are gradually variable, with a Selective Tone button for boosting low- and high-frequencies.
- The rear panel has a simple layout with easy-to-use connectors for main and remote speakers, along with snap clips for surround and center speakers.
- A mono line-level subwoofer output is included for an external crossover.
- The front panel is minimalist, with a central fluorescent display and smaller indicators for various settings.
- The remote control is well-organized, with clearly separated button clusters.
- FM performance is excellent, especially in separation and selectivity, though stereo sensitivity is only good.
- The amplifier delivers output levels higher than its ratings, with good dynamic power, especially into 4-ohm loads.
- Dolby Pro Logic decoding shows outstanding performance, with excellent noise and distortion control, particularly for the surround channel.
- The Hall mode’s sound can be adjusted via delay time and surround-speaker levels to improve spaciousness without distorting clarity.
- Tone controls are delicate in their adjustments, but the Selective Tone button offers strong boosts that can sound unnatural.
- Overall, the AV-716 provides a clean, dynamic surround decoding and ample power reserves for high playback levels, offering simplicity with high-quality performance.
- NAD AV-716 是 NAD 的第一款 A/V 接收器,专注于基本功能和高性能。
- 核心技术包括使用“最新一代”模拟解码芯片的杜比 Pro Logic 解码器,提供低噪声输出。
- 它具有 Hall 模式,用于音乐增强,通过环绕扬声器提供延迟的反射,改善空间感。
- 在立体声模式下额定功率为 80 瓦特每通道(8 欧姆),在环绕模式下前置扬声器为 55 瓦特,环绕扬声器为 20 瓦特每个。
- 接收器配备有 40 个预设、6 个预设组的 AM/FM 立体声调谐器,具有良好的选择性、失真和噪声表现。
- 输入包括唱盘盒、CD 播放器、两个磁带录音机、两个录像机和一个仅播放视频源。
- 音调控制可逐渐调节,带有选择性音调按钮,用于增强低频和高频。
- 后面板采用简洁布局,便于使用的主扬声器和遥控扬声器连接器,环绕和中置扬声器使用卡接连接器。
- 包含一个单声道低电平超低音输出,用于外部分频器。
- 前面板简洁,中央荧光显示屏显示选定的源或环绕模式扬声器平衡设置,较小的指示灯显示其他设置。
- 遥控器布局合理,按钮分组清晰。
- FM 性能出色,尤其在分离度和选择性方面,立体声灵敏度一般。
- 放大器提供高于额定值的输出功率,在 4 欧姆负载下特别具备良好的动态功率。
- 杜比 Pro Logic 解码表现出色,噪声和失真控制非常好,尤其是环绕声道。
- Hall 模式的声音可以通过延迟时间和环绕扬声器级别调节,以改善空间感,同时不失去清晰度。
- 音调控制可以精细调整,但选择性音调按钮提供的强力提升可能听起来不自然。
- 总体而言,AV-716 提供干净、动态的环绕解码和足够的功率储备,适合高播放音量,提供简单的操作与高品质的性能。
SPECIFICATIONS 规格:🧾
- Designed & Engineered in England
- Tuning range: FM, MW
- Power output: 80 watts per channel into 8Ω (stereo)
- Surround output: 55W (front), 55W (center), 20W (rear)
- Frequency response: 20Hz to 30kHz
- Total harmonic distortion: 0.08%
- Damping factor: 60
- Input sensitivity: 2.5mV (MM), 150mV (line)
- Signal to noise ratio: 80dB (MM), 100dB (line)
- Speaker load impedance: 4Ω (minimum)
- Video Connections: composite
- Dimensions: 455 x 168 x 375mm
- Weight: 13.2kg
- 230v
REFERENCES 根据:🫡
1.https://www.audiogon.com/bluebook/brands/nad/products/nad-av-716?srsltid=AfmBOopTQsmmK0iJeEi8yDh54DEFXztow0Xum75AyNnMd82d98xnE6Z4
2.https://www.hifiengine.com/manual_library/nad/av716.shtml
3.https://www.hifi-review.com/153344-nad-av-716.html
4.http://www.audioreview.com/product/amplification/amplifiers/nad/av716.html
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
Subwoofer Output
Stereo Use:
立体声使用:
- 高质量的立体声分离、成像和深度
- 可与价值超过5000美元的功放媲美
- 即使在较高音量下,音质也表现优异
Audio Visual Use:
视听使用:
- 遥控器布局合理,按钮分组清晰。
SPECIFICATIONS 规格:🧾
- Weight: 13.2kg
- 230v
REFERENCES 根据:🫡
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
DISCLAIMER 免责声明:
» Rotel RA-1592 Integrated Amplifier with DAC, Bluetooth, DSD capable PC-USB, USB iPod input, phono (MM), 2 subwoofer outputs, 200W/8ohms.
» Adcom GFA 555 MK2 Power Amplifier @ 200W per channel
» Emotiva XPA-5 5-Channel Power Amplifier (200w)
» Harman Kardon PA2400 Stereo Power Amplifier - 200W@8ohms
» AudioControl Savoy G3 Multi Channel Power Amp ( 7 Channel x 200w ) ( sold)
