JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker Empty JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker
Post by HomeSweetAudio98 Tue Nov 26, 2024 10:15 pm
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
🤩JVC Wood Cone Full Range Signature Sound, Open, Natural, Airy w/ Smoothness!
🤯Don't Underestimate by its SIZE, u will SHOCKED by its LEVEL of NATURAL Tonality, Come Challenge Guitar & Violin~😎
🤩 JVC木质振盆全音域标志性音质,开放、自然、通透,音色平滑!
🤯 别小看它的体积,音质的自然音色会让你震撼,来挑战吉他和小提琴吧~😎
💥Pure Japan Craftmanship in White Woodgrain Finish
💥85mm JVC Wood Cone Full Range Driver w/ Large Motor Magnet
💥Pinewood Acoustic Anti Vibration Sheets behind Drivers Magnet
💥Ultra Compact Design
💥 纯正日本工艺,白色木纹饰面
💥 85毫米 JVC 木质音圈全频驱动单元,配大磁铁
💥 驱动单元磁铁背部使用松木声学抗震片
💥 超紧凑设计
✅NOW ONLY RM 480!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~😎
✅现价仅 RM 480!🤯 将它放在您的Hi-Fi音箱架上!🤩 炫耀吧 ~😎
💎CONDITION 品像: 8.5/10 = LIKE NEW w/ Original Grilles | 很新 ~ 有原装网罩
💥The JVC EX-S3 speaker offers a truly natural and immersive sound experience, with its wooden diaphragm enhancing clarity and depth across the frequency range. Its design delivers clear mid-high frequencies, with exceptional vocal and solo instrument performance, while low frequencies are extended and well-controlled thanks to the use of pinewood acoustic sheets. The speaker creates a warm, soothing listening environment, delivering high sound resolution and a refined soundstage, making it an ideal choice for those seeking a pure, balanced audio experience in a stylish, compact form.
JVC EX-S3 扬声器提供了一种自然且沉浸的音质体验,其木质振盆提升了全频段的清晰度和深度。设计上,扬声器在中高频表现清晰,人声和器乐独奏的表现尤为出色,同时通过松木声学木片延伸和控制低频。它营造出温暖、舒缓的听音环境,提供高分辨率的声音和精致的声场,是追求纯净平衡音质的理想选择,同时兼具时尚、紧凑的外形设计。
💥~ Reviewers in Audio Forum
- The JVC EX-S3 speaker delivers a natural, deep, and pure sound.
- The use of wood for the diaphragm enhances sound transmission and minimizes resonance.
- The speaker produces clear mid-high frequencies, with improved vocal and solo instrument performance.
- Low-frequency extension is enhanced through the use of pinewood acoustic sheets that reduce vibrations and absorb sound.
- The speaker's design helps create a comfortable and immersive listening experience, with a warm and soothing sound akin to being in a "coffee world."
- The speaker achieves high sound resolution and better soundstage due to the advanced materials and vibration control.
- JVC EX-S3 扬声器提供自然、深沉且纯净的音质。
- 采用木材作为振盆材料,提升声音传导效果,减少谐振。
- 中高频表现清晰,人声和器乐独奏的表现得到了显著提升。
- 低频延伸得到改善,松木声学木片有效抑制震动并吸收声音。
- 扬声器设计营造出舒适的听音体验,音质温暖、宁静,如同置身“咖啡世界”般的感觉。
- 通过先进材料和振动控制,扬声器实现了更高的声音分辨率和更好的声场表现。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- EX-S3 features a wooden diaphragm speaker technology developed by JVC after 20 years of research and development.
- Wood is used for the diaphragm due to its fast sound transmission and natural texture, which minimizes resonance and standing waves.
- JVC’s unique molding technology ensures that the wood does not warp or crack, maintaining durability.
- The speaker produces natural, deep, and pure sound, ideal for creating a relaxing listening environment.
- Pinewood acoustic sheets are added to suppress speaker unit vibrations and provide sound absorption, enhancing low-frequency performance.
- The base and bottom of the main unit use a combination of different metals to disperse resonance, improving the soundstage and counteracting vibrations.
- The 85mm wood diaphragm full-range speaker uses a “point source” design, improving mid-high frequencies, vocals, and solo instrument performance.
- Designed to blend with modern home interiors, the speaker is about 12 cm in height and comes in black or white wood grain colors.
- EX-S3 采用JVC经过20年研发的木质振盆扬声器技术。
- 木材作为扬声器振盆的材料,因其声音传导快和天然纹理结构,有效减少谐振和驻波。
- JVC独特的成型技术确保木材不会变形或破裂,保持其耐用性。
- 扬声器能够演奏出自然、深沉且纯净的音质,适合打造轻松的听音环境。
- 加入松木声学木片可抑制扬声器单元震动,并起到吸音作用,改善低频性能。
- 主机底盘及底部使用异种金属组合来分散共振,改善声场空间并抵抗振动。
- 85mm木质振盆全音域扬声器采用“点音源”设计,提升中高频、人声和器乐独奏表现。
- 设计上与现代家居风格相协调,扬声器高度约为12cm,提供黑白两种木纹色可选。
✅SPECIFICATIONS 规格:🧾
- Type: 1-way bass reflex type, Magnetically shielded type
- Speaker driver: 8.5 cm (3 3/8") wood cone
- Power handling capacity: 40 W
- Impedance: 4 Ω
- Frequency range: 55 Hz – 20 kHz
- Sound pressure level: 83 dB/W · m
- Dimensions (W x H x D): 120 mm x 161 mm x 266.5 mm (4 3/4" x 6 3/8" x 10 1/2") including projecting parts
- Weight (1 unit): 1.8 kg (4.0 lbs)
✅REFERENCES 根据:📑🫡
1.https://www.jvc.com.cn/audio/ex-s3/index.html
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46815010
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46816410
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46817510
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46829710
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46821910
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46826410
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46828610
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46829711
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46836710
JVC Victor w/ Wood Cone Full Range Driver w/ Big Magnet & Anti Vibration SP-EX53 Bookshelf Speaker 46840410
HomeSweetAudio98
Regular
Regular
Number of posts : 52
Registration date : 2024-10-30
