Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A DIGILOG DAC
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC Empty Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A DIGILOG DAC
Post by HomeSweetAudio98 Fri Nov 29, 2024 3:55 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥RARE FIND! Limited UK Production DAC from Musical Fidelity
💥罕见之选!Musical Fidelity 英国限量生产 DAC
🎵Pure UK Craftmanship w/ ALL UK Components
🎵Fully Discrete Circuit Pure Class A Output Stage
🎵Duo Philips TDA1541A R2R DAC Module w/ Non Oversampling in Dual Differential Balanced Mode
🎵Philips HiFi Premium Grade SAA7220P/B Filter Chip
🎵UK Made Ultra Low Noise Toroidal Transformer
🎵纯正英国工艺,全部采用英国组件
🎵全离散电路,纯A类输出级
🎵双 Philips TDA1541A R2R DAC 模块,采用非过采样双差分平衡模式
🎵Philips 高保真顶级 SAA7220P/B 滤波芯片
🎵英国制造超低噪声环形变压器
✅NOW ONLY RM 2980! 🤯 You CAN HAVE IT on your HIFI Rack!🤩 SHOW IT OFF ~😎
✅现在只需 RM 2980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜😎
💎CONDITION 品像: 8/10 = Excellent | 很好
The Digilog is certainly a notch above other CD players and decoders in its price range. The fact that I brought out the much more expensive Theta to discover its liabilities speaks highly of it. The Digilog had excellent dynamics, detailed bass articulation, uncolored midrange, spacious soundstage, and ability to resolve detail, but fell short in all these areas when put next to the Theta. My only complaints are the flimsy RCA jack mountings and slightly edgy treble presentation. However, considering its price, these caveats are minor. In short, the Digilog does everything very well, without any serious deficiencies. I highly recommend the Digilog as an inexpensive way to greatly improve the sound of your CD player.
Digilog无疑在其价位范围内领先于其他CD播放器和解码器。事实上,我拿出更昂贵的Theta来比较,发现Digilog的不足,这已经充分说明了它的实力。Digilog在动态表现、低频细节、中频的自然还原、声场的宽广以及细节解析能力方面表现出色,但与Theta相比,这些方面仍略逊一筹。我的唯一不满是它的RCA插座安装较为脆弱,以及高频表现略显尖锐。然而,考虑到它的价格,这些缺点可以说是微不足道的。总之,Digilog在各方面表现均衡,没有明显短板。我强烈推荐Digilog,它是以低成本显著提升CD播放音质的理想选择。
💥~Robert Harley | Jul 5, 2011 | Stereophile!
- Warm-up period enhances the converter's performance, ensuring optimal sound quality.
- Natural tonal balance on guitar recordings, replicating live mic feed sound.
- Midrange: warm, uncolored, and realistic representation of instruments.
- Treble: smoother and more relaxed than Arcam Black Box 2 but slightly edgy compared to Theta DS Pre.
- Bass: taut, controlled, with excellent definition; impactful dynamics surpassing Black Box 2 and DIVC-880.
- Superior resolution of subtle details, revealing previously hidden nuances in recordings.
- Deep soundstage with accurate spatial presentation, though less transparent than Theta DS Pre.
- Notable ability to separate instruments clearly within complex arrangements.
- Periodic clicking issue with DAT input due to misaligned trim pot; required manual adjustment, raising concerns about production consistency.
- 预热过程提升转换器性能,确保最佳音质。
- 吉他录音呈现自然的音调平衡,再现现场麦克风声音。
- 中频:温暖、无染色,真实再现乐器音色。
- 高频:比 Arcam Black Box 2 更平滑、放松,但相较于 Theta DS Pre 略显尖锐。
- 低频:紧致、受控,定义清晰;动态冲击力超过 Black Box 2 和 DIVC-880。
- 细节解析力极高,揭示录音中之前未曾察觉的细微之处。
- 声场深邃,空间定位准确,但透明度不及 Theta DS Pre。
- 在复杂音轨中,乐器分离清晰。
- DAT 输入出现周期性点击声,因微调电位器(RV1)失准,需要手动调整,可能存在生产一致性问题。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- Sturdy build with a heavy metal chassis and thick, machined faceplate, uncommon for this price.
- Front panel includes four pushbutton switches for input selection (DAT, CD, optical) and polarity reversal, with corresponding status LEDs.
- Additional LEDs for deemphasis and data lock (LCK), with an audible relay click upon lock.
- High-quality internal components: large ILP toroidal transformer, metal-film resistors, custom capacitors.
- Circuit design mirrors Musical Fidelity preamps, with each stage having its own regulated power supply.
- Uses Philips TDA1541A dual DAC and SAA7220P/B digital filter chip.
  - TDA1541A DAC: selected for performance despite not using the most expensive grade (S1 Crown).
  - SAA7220P/B filter: chosen for superior quality over the "A" variant.
- RCA jack mountings on the PCB are fragile, leading to flexing when cables are plugged in, a minor flaw in an otherwise robust design.
- 坚固的机身设计,采用厚重的金属底盘和厚实的机加工面板,这价位的设备中非常少见。
- 前面板包含四个按键开关,用于选择输入(DAT、CD、光纤)和信号极性反转,配有对应的状态指示 LED。
- 另有去加重和数据锁定(LCK)指示灯,数据锁定时可听到继电器点击声。
- 内部组件品质高:大尺寸 ILP 环形变压器、金属膜电阻和定制电容。
- 电路设计与 Musical Fidelity 前级放大器类似,每个级别都有独立的稳压电源。
- 采用 Philips TDA1541A 双 DAC 和 SAA7220P/B 数字滤波芯片。
  - TDA1541A DAC:尽管未采用最高级别(S1 Crown),但根据性能筛选。
  - SAA7220P/B 滤波器:优于“A”版本,因此被选用。
- RCA 插口直接安装在电路板上,导致插拔时插口松动并使电路板弯曲,这是该设备在高质量设计中的一个小缺憾。
✅SPECIFICATIONS 规格:🧾
- D/A converter with 4x-oversampling dual DACs
- Decodes 44.1kHz and 48kHz
- Polarity-inversion switch
- Inputs: Coaxial digital input (S/PDIF format), EIAJ optical input
- Outputs: Analog output
- Dimensions: 10½" (265mm) W x 10½" (265mm) D x 2½" (63.5mm) H
- Manufacturer: Musical Fidelity Ltd., 15-17 Fulton Road, Wembley, Middlesex HA9 0TF, England, UK
✅REFERENCES 根据:📑🫡
1. https://www.stereophile.com/content/musical-fidelity-digilog-da-processor
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46864110
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46863710
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46862710
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46696010
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46842510
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46848810
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46874610
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46852110
Musical Fidelity Made in UK | Duo Philips TDA1541A R2R Module | Pure Class A  DIGILOG DAC 46844310
HomeSweetAudio98
Regular
Regular
Number of posts : 66
