Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker Empty Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker
Post by HomeSweetAudio98 Fri Nov 29, 2024 5:19 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
🤩EXTINCT FIND! Sony ES Series Original Signature Sound, Balanced, Accurate, Rich w/ Airy Highs!🤩
💥Pure Japan Craftmanship in Dark Ebony Finish
💥12" 30cm H. S. P. (High Stiffness Polyolefine) Diaphragm Bass Driver w/ Strontium Ferrite Magnet & Large 65 mm Diameter Voice Coil
💥5" 12cm H. S. P. (High Stiffness Polyolefine) Diaphragm Midrange Driver
💥1" 25mm 99,9% Pure Alumina Crystals Tweeter (lighter and faster than titanium)
💥Non Resonant Enclosures & R-shaped Front Baffle
💥Curved Baffle Surface
💥Die-Cast Frame w/ Acoustic Form
💥Crossover w/ European Metallized Polypropylene Film Capacitors & 15 mm Coils
🤩绝版发现!索尼ES系列原创签名声音,平衡、准确、丰富,且高音清澈!🤩
💥纯正日本工艺,深色乌木饰面
💥12英寸30cm H.S.P.(高刚性聚烯烃)振膜低音驱动单元,配有钡铁氧体磁铁和大直径65mm音圈
💥5英寸12cm H.S.P.(高刚性聚烯烃)振膜中音驱动单元
💥1英寸25mm 99.9%纯铝土矿晶体高音单元(比钛金属更轻、更快)
💥无共振外壳与R形前面板
💥曲面前面板
💥铸造框架与声学结构
💥交叉网络采用欧洲金属化聚丙烯膜电容器和15mm音圈
✅NOW ONLY RM 5980!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~😎
✅现价仅 RM 5980!🤯 将它放在您的Hi-Fi音箱架上!🤩 炫耀吧 ~😎
💎CONDITION 品像: 8.5/10 = Mint w/ Original Grilles | 非常好 ~ 有原装网罩
The Sony SS-G333ES delivers a well-balanced, clear, and precise sound with exceptional bass performance, making it superior to the Yamaha NS1000 in terms of low-end impact. Its deep and powerful bass is complemented by articulate mids that highlight natural vocals, ideal for genres like jazz and classical music. The treble is sharp and crisp, enhancing detailed sound reproduction without introducing harshness. Overall, the speaker offers a neutral sound profile with excellent tonal balance, excelling across various music styles, particularly vocal and large-scale classical music. Its versatility and refined clarity make it an outstanding choice for audiophiles seeking a dynamic and balanced listening experience.
索尼 SS-G333ES 提供了一个平衡、清晰且精准的音质,尤其在低频表现上优于雅马哈 NS1000。它的低频深沉且有力,与清晰的中频相得益彰,展现出自然的声音,特别适合爵士和古典音乐等类型。高频部分锐利且清脆,增强了细节的声音重现,但不会引入刺耳感。总体而言,这款音响具备中性音效配置,频率平衡出色,适用于多种音乐风格,尤其在人声和大规模古典音乐的表现上表现尤为出色。其多才多艺和精细的清晰度使其成为追求动态和平衡音质的音响发烧友的理想选择。
💥~ Reviewers in Audio Forum
- The sound is balanced, delivering clear and articulate highs, mids, and bass across a wide frequency range.
- Bass is considered deep and powerful, handling low-end frequencies effortlessly, but not overly dominant.
- The midrange provides rich, natural vocals and is effective for genres like jazz and classical music.
- Treble is sharp and crisp, contributing to detailed sound reproduction without harshness.
- The speakers are versatile, performing well across various music styles, especially vocal and large-scale classical music.
-Excellent bass performance, superior to the Yamaha NS1000
- Neutral sound profile, well-balanced across frequencies
- Clear and precise sound, with good overall tonal balance
- Sounds better than the Yamaha NS1000/M in personal preference
- 声音平衡,清晰而明晰地呈现高音、中音和低音,覆盖广泛的频率范围。
- 低音深沉有力,能够轻松处理低频,但不会过于突出。
- 中音提供丰富自然的声乐表现,适合爵士和古典音乐等风格。
- 高音锐利清晰,细致的声音再现而不刺耳。
- 扬声器通用性强,适应各种音乐风格,尤其是在声乐和大规模古典音乐中表现优秀。
- 优异的低音表现,优于雅马哈NS1000
- 中立的声音特征,频率之间平衡良好
- 清晰而精确的声音,整体音色平衡良好
- 在个人偏好上,声音优于雅马哈NS1000/M
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
 - 3-way speaker system designed to enhance sound beauty and dynamic range.
- 31 cm cone type woofer with H. S. P. (High Stiffness Polyolefine) diaphragm for improved sound expression.
- Woofer magnetic circuit utilizes a strontium ferrite magnet with a flux density of 9,000 gauss and a large 65 mm diameter voice coil.
- Die-cast frame with an acoustic form and R-shaped front baffle for improved sound quality.
- 12 cm balance drive midrange unit with H. S. P. diaphragm and a strontium ferrite magnet with 13,000 gauss flux density.
- Midrange magnetic circuit uses a 50 mm diameter voice coil and an acoustic form frame.
- 2.5 cm dome-shaped tweeter with polycrystalline alumina ceramic diaphragm for high rigidity and sound clarity.
- Tweeter magnetic circuit with a strontium ferrite magnet with 18,000 gauss flux density.
- Network design minimizes interference and magnetic field influences, with a compact electrical loop and concentrated earth.
- High-quality components like European metallized polypropylene film capacitors and 1.5 mm φ woofer coils reduce signal interference.
- Enclosure made from high-density perticboard, tuned for sound quality, with a 40 mm thick baffle and base plate.
- Baffle surface is curved with a taper to reduce diffraction, enhance frequency response, and improve directional characteristics for a better spread of sound.
- 这款三分频扬声器系统旨在提升声音的美感和动态范围。
- 低音单元采用31厘米圆锥型设计,使用H.S.P.(高刚性聚烯烃)振膜,以提高声音表现力。
- 低音单元磁路使用钡铁氧体磁铁,磁通密度为9000高斯,配备65毫米大直径音圈。
- 采用铸造框架,前面板附有R形声学结构,提升声音质量。
- 中音单元采用12厘米平衡驱动设计,使用与低音单元相同的H.S.P.振膜,并使用磁通密度为13000高斯的钡铁氧体磁铁。
- 中音单元磁路配有50毫米大直径音圈和类似低音单元的声学框架。
- 高音单元采用2.5厘米圆顶形设计,使用聚晶铝土矿陶瓷振膜,具有高刚性和出色的声音清晰度。
- 高音单元磁路采用钡铁氧体磁铁,磁通密度为18000高斯。
- 网络设计最大程度地减少了电路和部件之间的干扰,尽量减少来自扬声器单元的静态和动态磁场影响。
- 通过缩小电气回路并使用集中接地,显著减少了各单元之间的信号干扰。
- 使用高品质组件,如欧洲金属化聚丙烯膜电容器和1.5毫米音圈,有效降低信号干扰。
- 外壳采用高密度颗粒板,经过调音以优化声音质量,40毫米厚的前面板和底板增强了结构强度。
- 前面板表面曲线和大倾角设计,减少声波衍射现象,改善频率响应和定向特性,提升声音的扩散感。
✅SPECIFICATIONS 规格:🧾
- Method: 3-Way, 3-Speaker, Bass reflex system, Bookshelf Type
- Unit:
  - For low band: 31 cm cone type
  - For Middle Range: 12 cm Balance Drive Type
  - For high-pass: 2.5 cm dome type
- Playback frequency band: 30 Hz to 25000 Hz
- Output sound pressure level: 91 dB/W/m
- Impedance: 6 Ω
- Rated maximum input: 100 W
- Instantaneous maximum input: 200 W
- Crossover frequency: 500 Hz, 4000 Hz
- External dimensions: Width 400 x Height 695 x Depth 350 mm
- Weight: 32 kg
✅REFERENCES 根据:📑🫡
1.http://www.thevintageknob.org/sony-SS-G333ES.html
2.https://www.stereonet.com/forums/topic/526057-fs-sony-g333es-vintage-speaker-pair-very-rare-speakers-in-oz/
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46825710
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46843510
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46823010
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46829810
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46853511
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46823210
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46789510
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46816510
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46846911
Sony ES Limited RARE in Dark Ebony w/ Crystals Tweeter 12” Bass | 3 way SS-G333ES Big Speaker 46811311
HomeSweetAudio98
Regular
Regular
Number of posts : 52
