Rotel RMB-1555 Power Amplifier
Rotel RMB-1555 Power Amplifier Brand New. Now Selling At RM 9,219. Free Shipping Within West Malaysia.
With only slightly less power than its big brother, the RMB-1555 retains a very robust power supply to deliver 5 x 120 Watts per channel to medium and large home theaters.
As well-received as Rotel's CD players have been over the decades, the company's power amplifiers have been perhaps even more admired and critically acclaimed. That's due to Rotel's insistence that “less is more” and proof that the company's renowned Balanced Design Concept, which emphasizes simplicity and precise execution of proven engineering principles, honors its commitment to accurate and enjoyable musical reproduction.
Now this same attention to detail – and the same vitality in sonic reproduction – is available for multichannel music aficionados as well as videophiles searching for the best in movie soundtrack recreation.
Case in point: the remarkable RMB-1555 multichannel power amplifier. Whether used in a powerhouse home theater system, as a distribution amplifier for several independent zones in your home, or as the foundation of a remarkably flexible multichannel music system, the RMB-1555 fulfills the promise of Rotel's heritage.
Power output is conservatively rated at 120 watts per channel into 8 ohms and this is with all channels driven to full output. With all but the most demanding speakers located in extraordinarily large rooms, the RMB-1555 exerts the kind of precise control that presents both nuance and bombast correctly from the faintest flute overtones to the subterranean rumble of an approaching apocalypse.
Its capability comes from a remarkably stable power supply based on a Rotel-designed and Rotel-built toroidal transformer that provides precise voltages at high current to subsequent circuit stages. In addition, the toroid shape itself reduces stray emissions that might otherwise interfere with signal transfer.
Other internal components are of equally high caliber. They're sourced from Rotel's global supply network only after detailed examination and exhaustive listening tests that separate “good enough” from the truly superlative.
The RMB-1555 uses only discrete output transistors with their higher thermal stability and freedom from the designed-in compromises that characterize their integrated circuit cousins. The Class AB amplifier configuration ensures the best balance between power output and thermal efficiency for exceptional MTBF (mean time between failure).
Heavy duty speaker terminals complement the RMB-1555's 12-volt remote control trigger, single-ended RCA inputs, and detachable IEC-type AC cord.
Truly an amplifier for all uses, the RMB-1555 combines superb execution with maximum reliability to demonstrate Rotel's long devotion to satisfying consumer needs.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
CONTINUOUS POWER OUTPUT
120W/Ch (All channels driven, 8Ω)
TOTAL HARMONIC DISTORTION (THD)
(20Hz–20kHz) <0.03%
FREQUENCY RESPONSE
10Hz - 100kHz +0.5, -3dB
S/N RATIO (IHF “A” Weighted)
116dB
GAIN
26.5dB
DIMENSIONS (W × H × D)
431 × 188 × 454mm
17" × 7.5" × 17.9"
FRONT PANEL HEIGHT
4U / 176.8mm (7")
POWER REQUIREMENTS
230V, 50Hz
POWER CONSUMPTION
650W
STANDBY POWER CONSUMPTION
0.5W
NET WEIGHT
21.8kg (48lbs.)
BTU RATING (4Ω, 1/8th power)
1683 BTU/h
INTERMODULATION DISTORTION (60Hz:7kHz, 4:1)
<0.03%
DAMPING FACTOR
180
SPEAKER IMPEDANCE
4Ω minimum
INPUT SENSITIVITY
1.5V
INPUT IMPEDANCE
12kΩ
Rotel RMB-1555
MULTICHANNEL AMPLIFIERWith only slightly less power than its big brother, the RMB-1555 retains a very robust power supply to deliver 5 x 120 Watts per channel to medium and large home theaters.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
(20Hz–20kHz) <0.03%
FREQUENCY RESPONSE
116dB
GAIN
26.5dB
431 × 188 × 454mm
17" × 7.5" × 17.9"
FRONT PANEL HEIGHT
4U / 176.8mm (7")
POWER REQUIREMENTS
230V, 50Hz
POWER CONSUMPTION
650W
0.5W
NET WEIGHT
21.8kg (48lbs.)
1683 BTU/h
<0.03%
DAMPING FACTOR
180
SPEAKER IMPEDANCE
4Ω minimum
INPUT SENSITIVITY
1.5V
INPUT IMPEDANCE
12kΩ
- Number of posts : 1516
» Rotel RMB-1585MKII Power Amplifier
» Rotel Power Amplifier (Used)
» Rotel RMB-1587MKII Power Amplifier
» Rotel Pre and Power Amplifier
» Rotel Pre/Power Amplifier (Used)*SOLD*
