Audiolab 9000A Integrated Amplifier (Used)
Audiolab 9000A
https://www.audiolab.co.uk/products/9000a
Design Philosophy and Core Technology | 2 x 100W (8 ohms) / 2 x 160W (4 ohms) Class AB ES9038Pro 32-bit DAC 4.3″ (800 x 480px) Large Size Full View IPS LCD Built-in Certified MQA Full Decoder (PC USB, Coax/Optical) Bluetooth 5.1 (aptX/aptX HD/AAC/LDAC) Support Dedicated High-performance, Low-noise MM Phono Stage Dedicated Current-Feedback Headphone AMP Integrated / PRE-POWER / PRE Only Modes USB Upgrade Support |
Inputs | 3 x Analogue, 1 x XLR, 1 x Phono (MM), 1 x Power Amplifier, 2 x SPDIF (Coax), 2 x SPDIF (Optical), 1 x PC USB (USB B – Windows / mac OS only), 1 x Bluetooth (aptX/aptX HD/LDAC), 1 x 12V Trigger |
Outputs | 1 x PRE Amplifier,1 x Stereo Speaker, 1 x Headphone, 1 x 12V Trigger |
Sampling Frequency | Optical / Coaxial: 44.1kHz-192kHz; PC USB: 44.1kHz-768kHz (PCM) / DSD64, DSD128, DSD256, DSD512 |
Preamplifier Section | |
Gain (max.) | +6dB (Line), +53dB (Phono MM) |
Input Sensitivity | 1Vrms (Line, Volume = 0dB); 2Vrms (XLR, Volume = 0dB), 4.4mV (Phono MM, Volume=0dB) |
Input Impedance | 10K (Line); 47K // 100pF (Phono MM) |
Total Harmonic Distortion (THD) | < 0.0004% (1kHz @ 2V, Volume = 0dB) |
Frequency Response | 20Hz-20kHz (+/-0.1dB) |
Output Voltage | 2.3V max. (Volume = 0dB) |
Output Impedance | 120 ohms |
Signal-to-Noise Ratio | > 110dB (Line & XLR, A-weighted); > 80dB (Phono MM, A-weighted) |
DAC | |
D to A Converter | ES9038Pro |
Total Harmonic Distortion (THD) | < 0.001% (1kHz @ 0dBFS) |
Output Level (0dBFS, 1kHz) | 2.1Vrms |
Max. Sampling Frequency | Optical, Coaxial: 192kHz; PC USB: PCM768kHz, DSD512 |
Signal-to-Noise Ratio (S/N) | > 117dB (A-weighted) |
Power Amplifier Section | |
Gain | +29dB |
Rated Power Output | 2 x 100W (8 ohms, THD<1%); 2 x 160W (4 ohms, THD<1%) |
Frequency Response | 20Hz-20kHz (+/-0.3dB) |
Total Harmonic Distortion (THD) | <0.002% (1kHz @ 50W / 8 ohms) |
Input Sensitivity | 1Vrms |
Signal-to-Noise Ratio (S/N) | > 110dB (A-weighted) |
Max. Output Current | 15A |
Headphone Amplifier | |
Total Harmonic Distortion (THD) | < 0.01% (1kHz, 50mW ) |
Output Impedance | 2.35 ohms |
Load Impedance | 20-600 ohms |
General | |
Standby Power Consumption | <0.5W |
Net Weight | 9.4kg |
Gross Weight | 11.2kg |
Dimensions (mm) (W x H x D) | 444 x 89 x 342 |
Carton Size (mm) (W x H x D) | 514 x 470 x 161 |
Conditions: 9/10
Price: RM 7,500.00 inclusive postage to West Malaysia
- Number of posts : 5975
» Audiolab 9000a integrated amplifier
» Audiolab 9000A Integrated Amplifier (Used)
» Audiolab 8000A Integrated Amplifier with MM and MC
» audiolab 8000a integrated amplifier(used)
» Audiolab 8000A Integrated Amplifier (Used)
