Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 8 Bookshelf Speaker w/ Original Grilles SOLD
PM Me Directly 直接找我
ANOTHER RARE FIND! Tannoy UK & TEAC Japan Collaboration Limited Production Unit!🤩
又一稀有珍品!英国Tannoy与日本TEAC联名合作的限量生产单元!🤩
NOW ONLY RM !🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~
现价仅 RM !🤯 将它放在您的Hi-Fi音箱架上!🤩 炫耀吧 ~
CONDITION 品像: 8.5/10 = Very Mint w/ Original Jumpers & Grilles | 非常新 ~ 有原装网罩
The ONLY Brand w/ LONGEST HISTORY that doing Dual Concentric Coaxial Speaker !!
Designed & Engineered by Tannoy UK & TEAC Japan
Pure UK Craftmanship
All new 8 inch full-range, point source, phase coherent, Dual Concentric, DMT driver
Bi-wired gold plated terminals
High quality Van den Hul internal wiring gives greater clarity and accurate image placement
User adjustable high frequency response +1.5 dB
Highest quality minimalist crossover network
Rugged cabinet styling comprising high pressure twin laminated MDF walls within a grey soft-texture space-frame.
Braced cabinet/driver energy system
Vented, die-cast drive unit chassis increases heat dissipation and power handling
Twin laminar flow port tubes
Drive unit diffraction ring ensures smooth high frequency and better imaging
由英国 Tannoy 和日本 TEAC 联合设计与制造
纯正英国工艺
全新 8 英寸全频、点声源、相位一致的 Dual Concentric(同轴单元)DMT 驱动单元
双线分音接线柱,镀金端子
高品质 Van den Hul 内部接线,提供更高的清晰度和准确的音像定位
用户可调高频响应 +1.5 dB
最高质量的极简分频网络
坚固耐用的箱体设计,由高压双层 MDF 板构成,并配有灰色软质纹理支架
加强的箱体/驱动单元能量系统
通风的压铸驱动单元底盘,提升散热与功率承受能力
双层流线型导向孔设计
驱动单元扩散环确保高频平滑及更佳的音像定位
The Tannoy System 8's are tight and full sounding in general. I was using them as a pair of mid to near field monitors, and they certainly packed enough punch for me to be able to get an accurate read on what we were recording. I remember getting a very tight kick drum sound through these monitors, as the low end is very good for a pair of medium sized monitors. After listening to the unmixed and very rough recordings that we did while monitoring through the System 8's, it was clear to see that they had steered us in the right direction as the sound translated well to my monitors at home.
Tannoy System 8 整体听感紧致且饱满。我用它们作为一对中场到近场监听音箱,确实能够提供足够的冲击力,让我准确判断我们录音的效果。我还记得通过这些音箱获得了非常紧实的底鼓声音,其低频表现对于一对中型音箱来说非常出色。在监听 System 8 时,我们听了未混音、非常粗糙的录音,但很明显,它们引导我们朝着正确的方向前进,因为音频在我家里的监听音箱上也很好地得到了还原。
~ Reviewers from Audio Forums
SOUND QUALITY REVIEW(音色评测):🤩
- Big Scale of Soundstage & Stereo Imaging
- Very Coherent & Precise Imaging
- Very Sweet Vocal, SO RACUN !!
- The Level of Detail within Vocal is AMAZING: Vocal Cord, Shape of Face, Mouth, Body, Space between me & Vocal
- U can FELT the SINGER is inside the room WITH U, KINDA SCARY & SPOOKY, it gave me GOOSEBUMPS
- U get really Life Like Vocal & Instrument Representation
- The way it present Imaging so Natural, also the same case for the Tonality
- Linear, Deep & Punchy Bass, U can Feel the Wave of Low Bass & Kick Drum
- Very Refined & Dynamic!!
- Warmth with A BIT of TRANSPARENCY
- It had Fullness & Boldness
- Well-balanced Tonality: Full-bodied Presentation w/ Smooth yet Sweet Treble
- More Solid & Densed Tone
- Micro Dynamics is VERY GOOD !
- A LOT of TEXTURE & NUANCE in the Mids & Highs Frequencies!
- 声场规模宏大,立体声成像出色
- 成像非常连贯且精准
- 人声非常甜美,简直太毒了!!
- 人声细节惊艳:声带、脸型、嘴型、身体以及我与人声之间的空间感都清晰可辨
- 感觉歌手就在房间里和你在一起,有点吓人又诡异,甚至让我起了鸡皮疙瘩
- 人声与乐器的还原非常逼真
- 成像的呈现方式非常自然,音色也是如此
- 低音线性、深沉且有力,你能感受到低频波动与底鼓的冲击
- 非常精致且充满动感!
- 温暖之中带有一丝通透感
- 拥有丰满与厚实的质感
- 音色平衡良好:饱满的呈现,伴随着顺滑而甜美的高频
- 音调更为扎实和浓郁
- 微动态表现非常出色!
- 中高频段拥有丰富的纹理与层次感!
DESIGN & TECHNOLOGY 设计与科技:
THE MONITOR SHALL BE THE TANNOY...SYSTEM 8 DMT.
Without doubt, setting new standards in this midfield/mobile monitor class.
This unique combination of high technology DMT 8 inch Dual Concentric driver and the strikingly beautiful, energy coupled/braced cabinet results in exceptional quality from this modestly sized loudspeaker system.
The MONITOR SYSTEM shall consist of a 8 inch full-range, single point source, Dual Concentric transducer and a first-order low frequency, first-order high frequency with positive acoustic polarity frequency dividing system.
Performance of the MONITOR shall meet or exceed the following criteria: frequency response 1 m on axis with swept sine wave shall be 55 Hz - 20 kHz +3 dB, sensitivity shall be at least 91 dB for 1 watt at 1 metre, nominal impedance shall be 8 ohms with a rated power capacity of at least 140watts peak.
监听音箱应选择 TANNOY...SYSTEM 8 DMT。
毫无疑问,这款监听音箱为中场/移动监听类别树立了全新标杆。
采用独特的高科技 8 英寸 Dual Concentric 同轴单元和精美且能量耦合/加强设计的箱体,这一组合使这款中等尺寸的扬声器系统提供了卓越的品质。
监听系统应包括一个 8 英寸全频、单点声源 Dual Concentric 同轴换能器,并配备正声学极性的一阶低频与一阶高频分频系统。
监听音箱的性能应满足或超出以下标准:轴向 1 米处的频率响应(扫频正弦波)为 55 Hz - 20 kHz,偏差不超过 +3 dB;灵敏度至少为 91 dB(1 瓦@1 米);标称阻抗为 8 欧姆,额定峰值功率容量至少为 140 瓦。
SPECIFICATIONS 规格:🧾
- Driver Configuration: Dual Concentric (1 x 8″ LF/MF driver with a 1″ HF driver)
- Frequency Response: 55 Hz – 20 kHz
- Crossover Frequency: 1.8 kHz
- Impedance: 6 ohms
- Sensitivity: 91 dB (1W @ 1m)
- Power Handling: 70W RMS (140W peak)
- Maximum SPL: 112 dB
- Dispersion: 90° conical
- Cabinet Construction: Sealed cabinet design
- Dimensions: 370 x 250 x 295 mm
- Weight: 9.5 kg (per speaker)
- Years of Manufacture: 1989 – 1996
REFERENCES 根据:🫡
1.https://hifivintage.co.uk/portfolio/tannoy-system-8-speakers/?srsltid=AfmBOorrVDdeq8scxKtrtKg0zsE40kllu3mYLdtNSp-rv-Me01A4JS3X
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
纯正英国工艺
双线分音接线柱,镀金端子
用户可调高频响应 +1.5 dB
最高质量的极简分频网络
加强的箱体/驱动单元能量系统
双层流线型导向孔设计
- 声场规模宏大,立体声成像出色
- 成像非常连贯且精准
- 人声非常甜美,简直太毒了!!
- 人声与乐器的还原非常逼真
- 非常精致且充满动感!
- 温暖之中带有一丝通透感
- 拥有丰满与厚实的质感
- 音调更为扎实和浓郁
- 微动态表现非常出色!
- 中高频段拥有丰富的纹理与层次感!
SPECIFICATIONS 规格:🧾
- Impedance: 6 ohms
REFERENCES 根据:🫡
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
DISCLAIMER 免责声明:
Last edited by HomeSweetAudio98 on Sat Dec 14, 2024 11:04 am; edited 1 time in total (Reason for editing : SOLD)
» Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills
» Yamaha | White Paper Cone | Acoustic Suspension | MP Caps | NS-10M Bookshelf Speaker w/ Grilles
» Tannoy 607 Speaker With matched Original Stand (sold)
» B&W w/ Yellow Woven Kevlar Driver | Vertical Bracing Cabinet | CDM1 Bookshelf Speaker in Rosewood SOLD
» Tannoy 609 speakers with original Tannoy stands(sold)
