Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp Empty Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp
Post by HomeSweetAudio98 Thu Dec 05, 2024 1:00 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥RARE FIND at THIS CONDITION! Limited Production Globally 🤩
💥这样完美的稀有珍品!限量生产🤩
✅NOW ONLY RM 3980! 🤯 You CAN HAVE IT on your HIFI Rack!🤩 SHOW IT OFF ~😎
✅现在只需 RM 3980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜😎
💎CONDITION 品像: 8.5/10 = Mint | 很新
🎵Pure UK Craftmanship
🎵XLR Fully Balanced Input & Output
🎵Fully Discrete Pure Class A Input & Output Stage Preamp w/ MOSFET in Dual Differential Balanced Mode
🎵16 VFET Output Transistors in Class A Biased Operation
🎵纯正英国工艺
🎵全平衡XLR输入和输出
🎵全离散纯Class A输入和输出阶段前级放大器,采用MOSFET双差分平衡模式
🎵16个VFET输出晶体管,Class A偏置操作
The Musical Fidelity Preamp and Typhoon combination delivers exceptional sound quality, offering a clear, focused, and musical performance free from harshness or sibilance. In its standard form, it provides a rich and engaging listening experience, while the bridged configuration enhances bass control, stereo imaging, and overall detail, making the sound more authoritative and refined. Although sensitive speakers may introduce slight background noise in bridged mode, for most setups, the sound remains effortlessly high-quality, with the design prioritizing performance over aesthetics, ensuring that the money spent goes directly into delivering extraordinary audio.
Musical Fidelity的前置放大器和Typhoon组合提供了卓越的音质,表现出清晰、专注且富有音乐感的表现,完全没有尖锐或刺耳的音效。在标准模式下,它提供了一种丰富且引人入胜的听觉体验,而桥接模式则增强了低频控制、立体声成像和整体细节,使声音更加有力和细腻。尽管对一些敏感扬声器来说,桥接模式可能会引入轻微的背景噪音,但对于大多数音响系统来说,声音始终保持极高的质量,设计上优先考虑性能而非外观,确保所投入的资金直接用于提供非凡的音频表现。
💥~ by Rachel Cramond - Gramophone UK!
- Clear, focused sound with no hardness or sibilant emphasis.
- Produces a very musical and comfortable listening experience.
- Excellent bass weight, control, and headroom in bridged mode, enhancing authority and detail.
- Superb stereo imaging and finesse in fine details.
- High compatibility with a variety of loudspeakers, delivering consistently high-quality sound.
- Luxurious recordings feel lifelike, with clean and engaging reproduction of close recordings.
- Slight increase in background noise during bridged operation with sensitive loudspeakers.
- Prioritizes sound quality over flashy design, with well-conceived engineering focused on performance.
- 清晰、专注的音质,没有硬度或刺耳的高频强调。
- 提供非常音乐感和舒适的听音体验。
- 在桥接模式下,低频重量、控制力和功率储备表现出色,增强了声音的权威感和细节。
- 极佳的立体声成像和细节表现,精致细腻。
- 与各种扬声器兼容性强,持续提供高质量的音质。
- 豪华的录音呈现出逼真的效果,清晰且引人入胜地再现近距离录音。
- 在桥接操作时,敏感扬声器可能会略微增加背景噪音。
- 优先考虑音质而非炫目的设计,工程设计精巧,专注于性能表现。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- **Input and Output Stage**
  - The Preamp features six line-level inputs: CD, Tuner, CDV, Aux, Tape 1, and Tape 2.
  - Balanced output stage with XLR connectors for professional-grade noise rejection, especially useful for long cable runs.
  - Unbalanced connections are standard for inputs and tape output.
  - Output is muted via a relay to prevent switch-on thumps.
- **Technology**
  - The Typhoon employs 16 power transistors (8 per channel) for high current delivery.
  - Continuous power output: 45 watts per channel into 8 ohms; peak current capacity of 60 amps.
  - Fully discrete transistor design for gain and pre-driver stages; operational amplifiers handle balanced input processing.
  - Independent stereo channels with separate rectifiers and reservoir capacitors; only the mains transformer is shared.
  - Bridged operation doubles power output to 150 watts into 4 ohms, requiring additional units and adapters.
- **Design**
  - Minimalist front panel controls: power switch, input selector, tape monitor, tape output routing, and volume control.
  - No tone or balance adjustments, filters, or headphone output to ensure simplicity and signal purity.
  - Compact and efficient internal layout: signal routing kept short with PCB-mounted gold-plated sockets and Alps volume control.
  - High-quality materials: glass-fiber PCB, toroidal transformer, and robust casing with perforated sections for cooling in the Typhoon.
  - Modular and understated aesthetic with durable construction focused on function over luxury presentation.
- **输入和输出阶段**
  - 前级放大器提供六个线路电平输入:CD、调谐器(Tuner)、CDV、辅助输入(Aux)、磁带1(Tape 1)和磁带2(Tape 2)。
  - 平衡输出级配备XLR连接器,提供专业级的抗噪能力,特别适合长距离线缆连接。
  - 非平衡连接为输入和磁带输出的标准配置。
  - 通过继电器静音输出,防止开机时的“砰”声。
- **技术**
  - Typhoon使用16个功率晶体管(每通道8个),以提供高电流输出。
  - 持续功率输出:每通道45瓦(8欧姆负载);峰值电流能力为60安培。
  - 增益和预驱动阶段采用全离散晶体管设计;平衡输入处理由运算放大器完成。
  - 独立的立体声通道设计,配备独立的整流器和滤波电容;仅共享主变压器。
  - 桥接模式可将功率输出翻倍至150瓦(4欧姆负载),需额外单元和适配器。
- **设计**
  - 简约的前面板控制:电源开关、输入选择、磁带监控、磁带输出路由和音量控制。
  - 无音调或平衡调节、滤波器或耳机输出,确保简洁和信号纯净。
  - 内部布局紧凑高效:信号路径尽可能短,PCB上安装镀金插座和Alps音量控制器。
  - 使用高质量材料:玻璃纤维PCB、环形变压器,以及带有通风孔的坚固机壳(用于Typhoon散热)。
  - 模块化和低调的外观设计,注重功能而非奢华外观,结构耐用。
✅SPECIFICATIONS 规格:🧾
🎵THE PREAMP:
- 4 linear RCA inputs (CD, Tuner, AUX, Tape)
- 1 input from a vinyl player (MM and MC - switchable on the back panel)
- Outputs of the preamplifier are balanced XLR and unbalanced RCA
- TAPE/MONITOR function
- Dimensions (W x H x D): 440 x 75 x 305 mm
- Frequency response: 10-60,000Hz ±1 dB
- Input sensitivity for 775mV output: all inputs 250mV
- Output: balanced line via XLR connectors
- Output impedance: 700 ohms
- Dimensions (W x H x D): 440 x 45 x 165 mm
- Weight: 5kg
🎵TYPHOON Power Amp
- Power rating:
  - 2 speakers output: 8ohm RMS @ 60W per channel (for bi-amp/bi-input speakers)
  - Bridged mono single output: 8ohm RMS @ 150W and 4ohm RMS @ 300W
- Balanced XLR input
- Includes XLR cable
- Weight: 5kg
✅REFERENCES 根据:📑🫡
1. https://tersaudio.com/musical-fidelity-the-preamp-typhoon-review/
2.https://www.gramophone.co.uk/features/article/review-musical-fidelity-the-preamp-and-typhoon-power-amplifier
3.https://www.hifinews.com/content/transistors-versus-tubes-page-2
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 44147910
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 44535511
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 44157310
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 43815510
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 43812010
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 43811510
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 43813110
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 43830610
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 44146410
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 20200410
Musical Fidelity UK XLR Pure Class A THE PREAMP | 16 Unit VFET Transistor TYPHOON Power Amp 913
HomeSweetAudio98
Number of posts : 109
