Denon AVC-X3700H 9.2ch 8K Ultra HD AV Receiver
Condition: 9/10 Excellent Full Set with Original Box
Selling at RM3900/=
Contact : 0174365998
Postage can be arrange....
Specification
Number of Power Amps
9
Power Output
180 watts per channel (6 ohms, 1 kHz, THD: 1%, 1 ch driven)
105 watts per channel (8 ohms, 20Hz–20kHz, THD: 0.08%, 2 ch driven
Speaker Impedance
4-16Ω/ohms
Preamplifier Section
Input Sensitivity/ Impedance
200 mV/47k kohms
Frequency Response
10Hz–100kHz – +1, -3 dB (Direct Mode)
S/N Ratio
100 dB (IHF-A weighted, Direct Mode)
General
Power Supply
230V / 50/60Hz
Power Consumption
660W (Standby 0.1W, CEC standby 0.5W)
Power Consumption (No Sound)
45W (ECO Mode On)
80W (ECO Mode Off)
Maximum Dimensions (WxDxH)
Antenna:Horizontal (mm) – 434 x 389 x 167
Antenna:Vertical (mm) – 434 x 389 x 236
w/o Antenna: (mm) 434 x 379 x 167
Carton Dimensions (Packaging) (WxDxH) (mm)
519 x 478 x 242
Weight (kg)
12.5
Weight (Packaging) (kg)
15.1
Overview
Immerse yourself in high-power home theatre entertainment. With 180W per channel the Denon AVC-X3700H delivers a truly immersive 3D
audio experience through Dolby Atmos, DTS:X, and IMAX Enhanced. The discretely built 9 channel amplifier section features two heat sinks
and a strong power supply to deliver the renowned powerful, dynamic and precise Denon sound. The AVC-X3700H supports the latest HDMI
video technologies such as 8K/60Hz and 4K/120Hz pass-through, Dolby Vision, HDR10, HDR10+, Dynamic HDR, HLG, as well as 8K upscaling
and HDCP 2.3 support on all HDMI inputs (7 in/3 out).
Stream popular music services like Spotify, TuneIn Internet Radio, Amazon Music HD, TIDAL and more wirelessly via Bluetooth,
Apple AirPlay 2 and Wi-Fi with HEOS Built-in. Enjoy your MP3 collection and even Hi-Res audio formats (WAV, FLAC, ALAC and DSD 2.8/5.6 MHz
files) via USB or Network. The Denon AVC-X3700H works with Amazon Alexa, Google Assistant and Apple Siri for effortless voice control.
By visually guiding you through each step in the setup process, the award-winning Denon Setup Assistant ensures you get set up right the
first time. Every home theatre is different — that’s why Denon uses the premium Audyssey MultEQ XT32 room calibration technology from Audyssey
that automatically measures and optimizes your AV amplifier to provide a truly immersive 3D audio experience custom-tailored to your unique listening environment.
Features
High-performance discrete 9-channel amplifier: Delivers a powerful 180W per channel to provide a trusted, precise and dynamic Denon sound experience.
Full 8K/60Hz and 4K/120Hz support and upscaling: With the latest HDMI support, enjoy 8K quality video from your 8K source devices.
One 8K input and two outputs allow for 8K/60Hz and 4K/120Hz pass-through. 8K upscaling is available on all 7 HDMI inputs.
The latest in HDMI support: With 7 advanced HDMI inputs and 3 HDMI outputs with full HDCP 2.3 support, connect to all your favourite
media devices and output up to three displays.
Enjoy your favourite 3D audio formats: Enjoy immersive, 3D audio from sources like Dolby Atmos, Dolby Atmos Height Virtualization,
DTS:X, and DTS Virtual:X.
IMAX Enhanced Technology: Deliver a true IMAX theatre experience at home.
Enhanced Audio Return Channel (eARC) HDMI support: Through the main HDMI output, connect your TV with eARC HDMI support to allow
uncompressed and object-based audio formats like Dolby Atmos and DTS:X directly from your smart TV app to your AV amplifier.
The latest in video compatibility: The latest HDR format support including HDR10, HDR10+ (New in 2020), HLG, Dolby Vision,
as well as Dynamic HDR (New in 2020) to provide the greatest picture quality for brightness, clarity and contrast.
The next generation in movie immersion: With 8K/60Hz pass-through and upscaling, Dynamic HDR and Quick Media Switching (QMS),
enjoy crystal clear and smoothest picture in the highest quality available.
The latest in gaming experiences: With 4K/120Hz pass-through, Variable Refresh Rate (VRR), Auto Low Latency Mode (ALLM) and Quick
Frame Transport (QFT), enjoy your gaming experience with amazing imaging, as well as reduced lag and latency.
Works with your favourite voice services: Use your voice to control the AVC-X3700H and wireless music services hands-free with
Amazon Alexa, Google Assistant and Apple Siri.
New DSP for more processing power: With 11.2ch max audio processing, connect an external power amplifier to the AVC-X3700H to
power two extra channels to enjoy a 11.2ch home theatre setup.
Wireless streaming from the most popular music services: Enjoy all of your favourite music services like Spotify, TuneIn Internet Radio,
Amazon Music HD, TIDAL, Deezer and more. The AVC-X3700H also lets you enjoy your music via AirPlay 2, letting you stream your favourite
tracks from Apple Music.
“Roon Tested” Certified: Get more out of your digital music library with searchable, surfable information about your favourite artists
and songs. Find lyrics, concert dates, photos, bios, reviews and more. Subscription required.
Phono input: With the included phono input, the AVC-X3700H lets you connect your turntable and play vinyl records. Enjoy your collection
with exceptional quality and sound.
Dual subwoofer outputs: Smooths out low frequencies for better bass dispersion.
HEOS Built-in wireless multi-room music streaming technology: Listen from any room for a connected, whole-home audio experience.
The AVC-X3700H also works with the newly introduced Denon Home speakers to let you enjoy a whole-home audio experience.
High-resolution audio streaming for Hi-Fi enthusiasts: Enjoy your favourite Hi-Res quality file playback with FLAC, ALAC, and WAV support,
as well as DSD 2.8/5.6MHz.
All Zone TV audio: Play the audio from your TV to another zone, without losing fully discrete surround sound in the main zone.
Built-in Bluetooth and Wi-Fi with 2.4GHz/5GHz dual band support: Solid wireless network connectivity even in congested environments.
Bluetooth audio transmitter: Enjoy your favourite audio through your Bluetooth headphones late at night or with your family member
who is hearing impaired. This feature supports Bluetooth-only playback as well as simultaneous playback with connected speakers.
Award-winning Denon Setup Assistant and graphical user interface: Easy and intuitive out-of-box setup experience.
Audyssey MultEQ XT32, Dynamic Volume, Dynamic EQ, LFC and Sub EQ HT: Delivers the ultimate equalization for your individual
room including subwoofer EQ.
Smart TV connectivity: Control the Denon AVC-X3700H with your TV remote via HDMI CEC.
Custom install ready: The Denon AVC-X3700H features external control and IP control capabilities for easy customization and
compatibility with third-party integration solutions.
12V Trigger output: Connect a device such as a projector and operate on standby power.
Amazing audio built on 110-years of innovation: Denon is the defining audio company of Japan. Founded in 1910, we enable the
moments that matter through the relentless pursuit of quality, innovation and audio performance.
https://www.cmy.com.my/shop-online/denon-avc-x3700h-7-2ch-8k-ultra-hd-av-receiver/
https://www.whathifi.com/reviews/denon-avc-x3700h
https://www.t3.com/reviews/denon-avc-x3700h-review
Selling at RM3900/=
Specification
9
Power Output
Speaker Impedance
4-16Ω/ohms
200 mV/47k kohms
Frequency Response
S/N Ratio
General
Power Supply
230V / 50/60Hz
Power Consumption
45W (ECO Mode On)
80W (ECO Mode Off)
519 x 478 x 242
Weight (kg)
12.5
15.1
Overview
Features
Jason Eng- Frequent Contributor
- Number of posts : 147
Registration date : 2020-09-09
» Denon AVC-X3700H 9.2ch 8K Ultra HD AV Receiver
» Denon AVC-X3700H 9.2Channel 8K Ultra HD AV Receiver (Used)
» Denon AVC-X3700H 8K AV Receiver
» Denon AVC-X3700H AV Receiver (SOLD)
