Cary Audio SLI-80 Signature Integrated Amplifier
In good condition, 8.5/10
With beefed-up transformers and output tubes, the SLI-80 runs at 80 watts ultralinear and 50 watts in triode mode using 6550/KT88 output tubes.
The 6550/KT88 is a pentode tube that can give higher output and lower total distortion than a triode tube. So why run it in triode?? The reason is that the Cary runs in class AB and will operate in pure class A longer in triode mode than when it is set up to run in strict ultralinear.
The Triode mode emulates the operation of a 300B triode tube which is the sweetest-sounding tube on the market
Comes with Electro Harmonix tubes
EH6550 x 4,
EH6922 x 2
EH6SN7 x 2,
EH5U4G x 2.
Original Remote control
Complete unit with shipping box.
Selling for RM12800
Contact Peter 012-3820333
Welcome to audition
Contact Audio Alchemy, Peter 012-3820333
Whatsapp me https://wa.me/message/DPSIPO7MHBUPA1
Weight: 42 lbs.
Dimensions: 7" H x 17" W x 16" D
Circuit Type: Push-Pull Ultra-Linear Pure Class AB-1
Power Output: 40 watts - Triode, 80 watts - Ultra-Linear
Input Sensitivity: .45 Volt for full output
Noise and Hum: -82 dB below full output
Frequency Response: 19 Hz to 23 kHz +/- .5dB
Gain: Ultra-Linear: 32dB, Triode: 31dB
Inputs: CD, AUX 1, AUX 2
Tubes: 2 ea. - 6922 Input Buffer Preamp, 2 ea. - 6SN7 Pre Driver/Phase Inverter, 4 ea. - 6550 Output Tubes, 2 ea. - 5U4 Rectifiers
Tube Sockets: Ceramic w/ silver pins
Speaker Posts: 5 way, gold-plated
Power Transformer(s): 1 ea. - EI Laminate, Silicon Impregnated
Output Transformer(s): 2 ea. - EI Laminate, Silicon Impregnated
Resistors: 1% Metal Film
Coupling Capacitors: Oil filled coupling capacitors (Copper oil filled capacitors, optional)
Power Supply Capacitors: 2 ea. - 1200µF@450 VDC, 6 ea. - 10µF@400 VDC Film & Foil
EH6550 x 4,
EH6922 x 2
EH6SN7 x 2,
EH5U4G x 2.
Selling for RM12800
Welcome to audition
Weight: 42 lbs.
- Number of posts : 3076
» Cary Audio SLI-80 Signature Integrated Amplifier (SOLD)
» Cary Audio Design SLI-80 Signature Vacuum Tube Integrated Amplifier (Used) SOLD
» SOLD Cary Audio CAD-300SE Signature Monoblock SET Tube Power Amplifier - Price Reduced
» Cary Audio Design CAD-300SEI Integrated Amplifier
» cary audio CAD-300sei integrated tube amplifier
