Cyrus High-End PRE w/ Flagship XVS Tech | Class A Discrete Preamplifier w/ Headphone Amp
PM Me Directly 直接找我
🤩Made in England UK w/ High End Ultra Compact Design
🤩Cast Aluminium Chassis in Gunmetal Finish
🤩Modular & Upgradable w/ Addition of Separated Cyrus Powers Supply
🤩Pure Class A Discrete Module Input & Output Stage
🤩Solid & Packed w/ All UK HiFi Grade Components & Power Transformer (Refer Last Picture)
🤩"Virtual Servo" Technology
🤩Space Optimized & Shortest Signal Path Design
🤩 英国制造,高端超紧凑设计
🤩 枪金属饰面压铸铝制机箱
🤩 模块化设计,可通过增加独立的 Cyrus 电源进行升级
🤩 纯 A 类离散模块输入和输出级
🤩 坚固耐用,内部配备全英国产 HiFi 级元件和电源变压器(参考最后一张图片)
🤩 "虚拟伺服"技术
🤩 空间优化设计,信号路径最短化
The Cyrus Pre Xvs impresses with its exceptional sound quality, offering a dark and quiet background that enhances every listening session. It delivers a large and expansive soundstage, excelling in transparency and clarity while revealing intricate textures and details in music. Even without the PSX-R power supply, it achieves refined tonal balance, precise dynamics, and extended frequency response across highs and lows, all wrapped in a performance that far exceeds expectations for its compact size.
Cyrus Pre Xvs 的音质表现令人印象深刻,提供深邃而安静的背景,显著提升聆听体验。它呈现出宽广的声场,在透明度和清晰度方面表现卓越,同时揭示音乐中的丰富纹理和细节。即使没有 PSX-R 电源供应,它依然展现出精致的音调平衡、精准的动态表现,以及高频和低频的延展性,整体性能远超其紧凑体积所能预期。
- Cyrus Audio UK
Retails for 售价为 1995 USD$ !! Almost RM9000 !!
NOW ONLY RM 3980!🤯 You CAN HAVE IT on your HIFI RACK!🤩 SHOW IT OFF ~
现在只需 RM 3980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜
CONDITION 品像: 8.5/10 = LIKE NEW | 新品般
SOUND QUALITY REVIEW(音色评测):🤩
- Despite its small size, it delivers performance that far exceeds expectations.
- Even without the PSX-R power supply, the sound quality is impressive.
- Offers a very dark and quiet background, enhancing the listening experience.
- Produces a large and expansive soundstage and soundscape.
- Excels in transparency and clarity, revealing fine details in music and recordings.
- Brings out texture and nuances in the music with remarkable precision.
- Delivers a refined overall sound with improved tonal balance.
- Provides extended frequency response in both high and low ranges.
- 尽管体积小巧,但其性能远超预期。
- 即使没有 PSX-R 电源供应,声音表现依然令人惊艳。
- 背景非常黑暗且安静,显著提升聆听体验。
- 声场和声景宽广且规模宏大。
- 在透明度和清晰度方面表现出色,揭示音乐和录音中的细节。
- 能够精准呈现音乐中的质感和细微之处。
- 整体声音更加精致,音色均衡性得到提升。
- 高频与低频的延展性更强。
DESIGN & TECHNOLOGY 设计与科技:
- Incorporates "Virtual Servo" preamp technology, enhancing dynamics and reducing noise for a quieter playback background.
- Offers improved acoustic image size and playback clarity compared to previous models.
- Compatible with Cyrus mono and stereo power amplifiers, benefiting from a robust power supply and optimized power regulation.
- Features a PSX-R power supply connection to further enhance dynamics and liveliness.
- Equipped with a speed-sensing volume knob, individual input sensitivity adjustment, and a high-quality headphone circuit.
- Engineered with a straight-line, short-path design to minimize signal path distortion.
- Eliminates switches and contacts in the signal path to avoid distortion artifacts.
- Utilizes advanced coupling components specifically designed for high-end audio amplifiers.
- Constructed with a die-cast aluminum chassis and gunmetal silver finish for durability and aesthetics.
- 配备“虚拟伺服”前级放大技术,提升动态范围并降低噪声,实现更安静的回放背景。
- 相较于前代产品,提供更大的声场和更清晰的回放效果。
- 与 Cyrus 单声道和立体声功率放大器兼容,具备强大的电源供应和优化的电源调节。
- 支持 PSX-R 电源连接,进一步增强动态表现和声音的活力。
- 配备速度感应音量旋钮、独立输入灵敏度调节功能,以及高品质耳机电路。
- 采用直线短路径设计,最大程度减少信号路径失真。
- 消除信号路径中的开关和接点,以避免失真干扰。
- 使用专为高端音频放大器设计的先进耦合元件。
- 采用压铸铝制机箱,配以枪金属银外观,兼具耐用性与美观性。
SPECIFICATIONS 规格:🧾
Power Supply
- Voltage: As plate on rear of unit
Power Consumption
- Standby: 6W
- ON: 9W
- EMC & Safety Compliance: EN60065
Enclosure
- Dimensions (WxHxD): 215 x 75 x 365mm
- Weight: 3.7Kg
- Material: Die cast chassis
Audio Performance
- Input Sensitivity: 500mV
- Input Impedance: 100kΩ
- Output Voltage (Pre1/Pre2): 0.94V
- Max output voltage: 9V
- Output Impedance (Pre1/Pre2): 50Ω
- Frequency Response (-3dB): 0.04Hz, 700kHz
- Signal to Noise Ratio (unWTD): 105dB
- THD+N, 1kHz: <0.003%
REFERENCES 根据:🫡
1.https://www.cyrusaudio.com/products/pre-xvs
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
🤩 英国制造,高端超紧凑设计
🤩 枪金属饰面压铸铝制机箱
🤩 纯 A 类离散模块输入和输出级
🤩 "虚拟伺服"技术
🤩 空间优化设计,信号路径最短化
- Cyrus Audio UK
- 尽管体积小巧,但其性能远超预期。
- 声场和声景宽广且规模宏大。
- 高频与低频的延展性更强。
SPECIFICATIONS 规格:🧾
Power Supply
Power Consumption
- Standby: 6W
- ON: 9W
Enclosure
- Weight: 3.7Kg
Audio Performance
REFERENCES 根据:🫡
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
DISCLAIMER 免责声明:
» Class A discrete headphone AMP, tuned for hd600/650
» GUSTARD P26 Discrete Class A Balanced Preamplifier XLR RCA
» Onkyo Japan Fully Discrete Class A | Source Direct Technology R-1 P301 Preamplifier w/ Phono Stage
» ifi Zen | Class A Discrete | TDK Ceramic Capacitors | Tokyo Pots | CAN Amp Full Set w/ Box & Cables
» Naim Audio OLIVE Pure Class A Fully Discrete NAC 92 Preamp w/ Phono Stage & Remote
