NHT 5.1 surround sound speaker package, SB1, SC1, SubOne, piano gloss
NHT (NowHearThis) are designed to deliver refined and musical sound. Our efforts are by the study of human hearing and optimized for real-world use.
Every NHT product undergoes rigorous testing and quality control at the factory to ensure you years of listening pleasure.
NHT - one of those rather obscure speaker companies that spend money more on products and practically none on advertisements.
*High price-to-performance ratio
*Build quality that lasts and sounds good
*Sounds like more expensive speakers
"The NHT system was our clear winner. These speakers combine a smooth, warm, inviting sound with solid looks."
NHT SB1
The super successor - "NHT speakers have been praised worldwide, and you'll know why when you hear this amazing bookshelf model in action!..."
2-way acoustic suspension system, sealed design.
1" Fluid cooled neodymium magnet structure tweeter with NHT’s proprietary aluminum heatsink.
5.25" polypropylene, high excursion woofer
Freq Response: 68Hz - 22kHz
Sensitivity: 86dB
Impedance : 8 Ohms nominal
5-way binding posts
Recommended Amplifier Power: 15-125 watts
Dimension: 10.25″H x 6.25″W x 6.75″D
Weight : 8 lbs. each
Black and White high gloss piano lacquer
Wall mountable.
* Precise, accurate and transparent sound that gives you a stage
* Aesthetically pleasing build with excellent build quality
* Will convince you these are more expensive speakers
"the NHT SB1 presents a mind-boggling price to performance ratio that would land my enthusiastic recommendations"
"If you are on a budget, these are definitely something you’ll want to seriously consider picking up, as their price quite far exceeds their value."
NHT SC1
Voice-matched to all other models in NHT Super Series, assuring seamless integration.
Acoustic suspension enclosure helps the SC1 achieve its musical accuracy and tight bass response.
2x 4.5" polypropylene, high excursion woofer for smooth, natural mids and lows.
Freq Response: 78Hz - 22kHz
Sensitivity: 86dB
Impedance: 8 Ohms nominal
5-way binding post
Recommended Amplifier Power: 15-150 watts
High-gloss black piano lacquer finish
Dimension: 16-9/16"W x 5-11/16"H x 6-11/16"D
Weight : 11 lbs.
NHT SubOne Active Subwoofer
Compact, versatile and powerful subwoofer for low frequency reinforcement for high-performance audio and home theater systems.
250-watt RMS amplifier using patented Sunfire technology for extraordinary dynamic high current output.
NHT Sub One features an outboard controller for convenient adjustment, provides line-level and speaker-level inputs and outputs for all type connections
Ported active subwoofer with outboard controller
12" long-throw polypropylene woofer
250 Watts RMS, under license from Sunfire Corporation
Freq Response: 25Hz - 180Hz
Controller:
Crossover - Low-pass continuously variable between 40-180Hz
Selectable high-pass at 50,75,110Hz @ 12dB/octave
Fixed high-pass at 100Hz, 6dB/octave
Phase Control - 0 and 180 degrees
Dimensions: H16" x W16" x D16" (Subwoofer); H2” x W11” x D7” (Controller)
Weight : 47 lbs. (Subwoofer); 3 lbs. (Controller)
Used, perfect working condition.
**slight crack at one of the white SB1 at the back top right corner, and torn on the top left of the white grille mesh.
Subwoofer comes with controller interconnect and power cord. (No Box)
RM1,950
Welcome for audition.
Subang Jaya ss14
**Credit cards accepted.
Contact 012-6116 917
www.facebook.com/Actsessory
» KEF Uni-Q 7.1 Surround Sound Speaker Package, Q700 Q600C Rosewood
» CAV Acoustics Speaker Stand Piano Gloss Black 24″ (Used)
» Dynaudio Focus 210C Centre Speaker - Piano Black Gloss
» Usher Transparent Midbass w/ Bullet Phase Plug S-520 Bookshelf Speaker Piano Gloss Black
