Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage Empty Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage
Post by HomeSweetAudio98 Wed Dec 11, 2024 3:32 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥VERY RARE FIND at THIS CONDITION! Limited Available Globally! 🤩状况如此完好的珍稀藏品!全球限量!🤩
✅NOW ONLY RM 5980! 🤯 You CAN HAVE IT on your HIFI Rack!🤩 SHOW IT OFF ~😎
✅现在只需 RM 5980🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜😎
💎CONDITION 品像: 8/10 = Mint | 非常好
🎵LIMITED Mahogany Chassis w/ Champagne Knobs & Face Plate (限量版桃花心木机箱配香槟色旋钮和面板)
🎵MC/MM Fully Discrete Phono Stage in Pure Class A Operation (MC/MM 完全分立式唱放阶段,纯A类操作)
🎵Quad Parallel Push Pull Input Stage (四重并联推挽输入级)
🎵Transistors w/ SEPP Output Stage ( 使用晶体管的SEPP(单端推挽)输出级)
🎵Headphone Amplifier w/ 13 Transistors Per Channel (每声道配备13个晶体管的耳机放大器)
🎵Pure Japan Craftmanship (纯正日本工艺)
🎵QuarterA system (四分之一A系统)
🎵Class A to AB operation switching (纯A到AB操作切换)
🎵Push-pull DC configuration (推挽直流配置)
🎵DC-servo circuit (直流伺服电路)
🎵Low-TIM design (低瞬态失真设计)
🎵High-speed electronic switching circuit (高速电子切换电路)
🎵Ultra-low noise transistors w/ SEPP Output Stage (超低噪声晶体管)
🎵Metal-coated resistors (金属涂层电阻)
🎵44,000μF Super audio condenser (超音质电容器)
🎵Heat pipe system (热管系统)
The Marantz Esotec PM-6A amplifier delivers a rich, detailed, and well-balanced sound, characterized by a warm, natural tone with smooth mids, clear highs, and tight, controlled bass. It offers an expansive soundstage with excellent instrument separation and depth, providing a dynamic and punchy performance that handles complex musical passages with clarity. Overall, the PM-6A is highly regarded for its ability to offer an enjoyable and cohesive listening experience, making it a standout choice for audiophiles.
Marantz Esotec PM-6A 放大器提供丰富、细致且平衡的音质,具有温暖自然的音色,平滑的中频、清晰的高频以及紧凑且受控的低频。它展现出广阔的声场,乐器分离度和深度表现优秀,提供动态且富有冲击力的表现,能够清晰地处理复杂的音乐段落。总体而言,PM-6A 因其提供愉悦且和谐的聆听体验而备受推崇,是发烧友的出色选择。
💥~ audioasylum & audiokarma Reviewers
- The Marantz Esotec PM-6A amplifier is praised for its rich and detailed sound quality.
- It has a warm and natural sound signature, with a smooth midrange and clear treble.
- The bass response is tight, controlled, and deep, providing a solid foundation for music.
- Soundstage is wide, offering good separation between instruments and a sense of depth.
- The amplifier delivers good dynamics, with a responsive and punchy performance.
- It handles complex musical passages well, maintaining clarity and cohesion.
- Overall, the PM-6A is considered highly capable in delivering a balanced and enjoyable listening experience.
- Marantz Esotec PM-6A 放大器以丰富且细致的音质受到赞扬。
- 它具有温暖自然的音色,平滑的中频和清晰的高频。
- 低频响应紧凑、控制力强且深沉,为音乐提供坚实的基础。
- 声音舞台宽广,乐器之间的分离度好,具有深度感。
- 放大器的动态表现良好,反应灵敏且有冲击力。
- 它能够很好地处理复杂的音乐段落,保持清晰和一致性。
- 总体而言,PM-6A 在提供平衡且愉悦的聆听体验方面被认为非常出色。
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- QuarterA system ensures fixed bias current until 30W power level, switching to Class AB from 30W to 120W.
- Electronic switching circuit for seamless operation transition developed by Marantz.
- Power amplifier section uses a fully push-pull DC configuration with built-in DC-servo circuit.
- Low-TIM design reduces transient distortion and minimizes NFB for improved performance.
- MC cartridge dedicated headphone amplifier with 13 transistors per channel in a 4-parallel push-pull input stage and SEPP configuration output stage.
- Phono amplifier uses Marantz's unique push-pull circuit for all stages to achieve high SN and dynamic range.
- Equalizer uses metal-coated resistors (1% tolerance) and polypropylene capacitors (2% tolerance) for excellent characteristics.
- Tone switch bypasses the entire tone amplifier circuit for purer sound.
- Small large-capacity power transformer with improved heat resistance using special resin.
- Super audio condenser of 22,000 μF x2 selected for sound quality.
- Heat pipe system ensures stable operation even under the high current demands of pure Class A.
- Two phono inputs, including MM load settings (27k Ω, 47k Ω, 100k Ω) and MC head amplifier position.
- Functions include a tape copy switch for dubbing, two levels of loudness, and independent tone control on both channels.
- QuarterA 系统确保在30W功率水平下固定偏置电流,功率从30W到120W时自动切换到AB类。
- Marantz 开发的电子开关电路实现了无缝的操作切换。
- 功率放大器部分采用全推挽DC配置,内置DC伺服电路。
- 低TIM设计减少瞬态失真,最小化负反馈以提高性能。
- 为MC唱头设计的耳机放大器,每通道13个晶体管,采用4并联推挽输入级和SEPP配置输出级。
- 唱放部分采用Marantz独特的推挽电路配置,以实现高信噪比和动态范围。
- 均衡器使用金属涂层电阻(误差1%)和聚丙烯电容(误差2%)以获得优异的特性。
- 音色开关可绕过整个音色放大电路,以获得更纯净的声音。
- 小型大容量电源变压器,使用特殊树脂填充,提高耐热性。
- 22,000 μF x2 超级音频电容,精心挑选以保证音质。
- 热管系统确保在纯A类大电流需求下仍能稳定运行。
- 配备两个唱放输入,其中Phono1具有27k Ω、47k Ω和100k Ω MM负载设置,以及MC前置放大器位置。
- 具备双卡带复印开关、两档响度调节和双声道独立音调控制等功能。
✅SPECIFICATIONS 规格:🧾
- Type: Stereo pre-main amplifier
- Rated Output (20 Hz ~ 20 kHz): 120W + 120W (8 Ω)
- Total harmonic distortion rate (20 Hz to 20 kHz): 0.015% or less (at rated output)
- Intermodulation distortion factor (60 Hz : 7 kHz = 4 : 1): 0.015% or less (at rated output)
- Frequency characteristic: 5 Hz ~ 100 kHz + 0 -2 dB
- RIAA deviation: 20 Hz to 20 kHz ± 0.2 dB
- Signal-to-noise ratio (IHF-A):
  - Phono MM: 86 dB
  - Phono MC: 68 dB
  - Tape, Tuner, AUX: 110 dB
- Rated power consumption: 350W
- External dimensions: Width 416 x Height 146 x Depth 332 mm
- Weight: 16.0 kg
✅REFERENCES 根据:📑🫡
1.https://www.hifiengine.com/manual_library/marantz/pm-6a.shtml
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 43819610
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 44257910
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 43830611
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 43827110
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 43988110
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 44265910
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 44248810
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 44255410
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 44740210
Marantz Esotec LIMITED Mahogany Wood Edition Pure Class A PM-6a Integrated Amp w/ MC/MM Phono Stage 44710410
HomeSweetAudio98
Number of posts : 108
