Topping E70 Audio DAC (Used)
Topping E70 Audio DAC (Used) Empty Topping E70 Audio DAC (Used)
Post by choyaudiovisual Tue Dec 17, 2024 9:39 am
Topping E70 Audio DAC (Used) 19668910
Topping E70 Audio DAC (Used) 7a08b010
Topping E70 Audio DAC (Used) 26a33710
Topping E70 Audio DAC (Used) 505b8f10
Topping E70 Audio DAC (Used) 45382110
Topping E70 Audio DAC (Used) Cf4b7710
Topping E70 Audio DAC (Used) Image231
Description
TOPPING has been the pioneer in producing some of the cleanest and distortion-free DACs. Their line-up of DACs like the E30, E30 II, D50S, D30 Pro, and E50 have all been well-received and widely accepted in the audiophile community. Their entire line-up of DACs is clean and precise, with spectacular digital to-analogue conversion capabilities. To improve “TOPPING” wanted; to create something incredibly sensational while maintaining the characteristics of their earlier generations of DACs. This design aspect led to the birth of the TOPPING E70, a fully balanced and Hi-Res certified Desktop DAC. The E70 expands on its predecessors’ strengths while retaining all their positive qualities to raise the bar for audio performance. The E70 hosts an ES9028PRO flagship-grade DAC chipset in its circuitry. It also hosts an XMOS XU316 USB processor that allows you to play Hi-Res files and supports decoding up to 32-bit/768kHz PCM and Native DSD512 audio signals. The E70 also includes Bluetooth 5.1 support to save you from the inconvenience of cables. When used wirelessly or “wired,” the TOPPING E70 is a versatile, Hi-Res-certified device that offers clean audio reproduction.
SPECIFICATION:
USB IN PCM: 44.1kHz-768kHz/ 16bit-32bit
DSD(Native): DSD64-DSD512
DSD(DoP): DSD64-DSD256
COAX/OPT IN:
PCM: 44.1kHz-192kHz/ 16bit-24bit
DSD(DoP): DSD64
BT IN: AAC/SBC/APTX/ APTX LL/ APTX HD/ APTX-Adaptive/LDAC
RCA (LINE OUT/ USB IN @96KHZ):
THD+N @1KHZ (A-WT):<0.00008%
THD+N @20-20KHZ 90KBW (NO-WT):<0.0007%
SNR @1KHZ (A-WT):126dB
DYNAMIC RANGE @1KHZ (A-WT):126dB
FREQUENCY RESPONSE:20Hz-20kHz(±0.2db)
20Hz-40kHz(±0.4dB)
OUTPUT LEVEL:2.1Vrms @0dBFS (4V Mode)
2.5Vrms @0dBFS (5V Mode)
NOISE (A-WT) :<1.3uVrms
CHANNEL CROSSTALK -133dB @1kHz
CHANNEL BALANCE:0.3dB
OUTPUT IMPEDANCE :50Ω
XLR (LINE OUT/ USB IN @96KHZ):
THD+N @1KHZ (A-WT) <0.00006%
THD+N @20-20KHZ 90KBW (NO-WT) <0.0002%
SNR @1KHZ (A-WT) 132db
DYNAMIC RANGE @1KHZ (A-WT) 132dB
FREQUENCY RESPONSE:20Hz-20kHz(±0.2dB)
20Hz-40kHz(±0.4dB)
OUTPUT LEVEL:4.2Vrms @0dBFS (4V Mode)
5.0Vrms @0dBFS (5V Mode)
NOISE (A-WT) <1.3uVrms
CHANNEL CROSSTALK:-149dB @1kHz
OUTPUT IMPEDANCE :100Ω
Price: RM 1,190.00 inclusive postage to West Malaysia
Number of posts : 5975
