Klipsch R-41SA Dolby Atmos Elevation Surround Speaker (Used)
Description
Original Price RM2599Now Price RM1790 1Pair / RM3350 2Pair
Description:
R-41SA DOLBY ATMOS SPEAKER
Enhance your home theater system with the incredible, overhead sound effects of the Klipsch R-41SA Dolby Atmos speaker. By leveraging Klipsch proprietary horn-loaded controlled directivity technology, the R-41SA bounces sound off the ceiling to create an astonishing, immersive listening experience. The R-41SA can also be utilized as an on-wall elevation or surround speaker via its easy-to-use keyhole mounting system – delivering the perfect angle for enhanced sound effects.
Features:
Dolby Atmos Overhead Sound Effects
Keyhole Mounting for On-Wall Elevation/Surround Sound Use
1″ Linear Travel Suspension Aluminum Tweeters
4″ Spun-Copper IMG Woofers
Strong, Flexible Removable Grille
Black Textured Wood Grain Vinyl
Dimensions: 7″ x 5.75″ x 13″
Specification:
Power Handling:
50 W RMS
100 W Peak
Drivers :
1x 1″ / 25.4 mm Aluminum Tweeter
1x 4″ / 101.6 mm Copper-Spun Graphite Woofer
Inputs/Outputs: 1x Binding Post Pair
(Speaker System)
Power Handling:
50 W RMS
100 W Peak
Drivers :
Enclosure Type: Sealed
Impedance: 8 Ohms
Crossover: 4237 Hz
(Physical)
Cabinet Material: MDF
Dimensions: 5.8 x 7 x 13″ / 146 x 180 x 331 mm
Weight :6.0 lb / 2.7 kg
(Packaging Info)
Package Weight: 15.5 In
Box Dimensions (LxWxH): 14.9 x 14.55 x 10″
Price: 1 Pair RM 1,790.00 / 2 Pair RM 3,350.00 inclusive postage to West Malaysia
- Number of posts : 5981
» Klipsch R-41SA Dolby Atmos® Elevation / Surround Speaker
» Klipsch R-41SA Atmos Enabled Elevation Speaker
» KLIPSCH Reference Premiere RP-140SA Dolby Atmos® enabled elevation speaker
» ELAC Debut 3.0 DA43 Dolby Atmos Enabled Elevation Speaker
» Klipsch RP-500SA Atmos Enabled Elevation Speaker
