ATC SCM20PSL Pro Speaker
ATC SCM20PSL Pro Speaker Empty ATC SCM20PSL Pro Speaker
Post by peterclting Tue Dec 17, 2024 7:14 am
For sale : ATC SCM20PSL Pro Bookshelf Speaker
The ATC SCM20PSL Pro is a passive, high-performance studio monitor tailored for critical listening and professional mixing applications.
Here are the key highlights:
1. Drivers:
• 6.5” Super Linear Mid/Bass Driver: Minimizes distortion for clear, uncolored low and mid frequencies.
• 1” Dual-Suspension S-Spec Tweeter: Delivers precise, extended high frequencies with minimal distortion.
2. Sealed Cabinet Design:
• Provides tight, accurate bass response without the phase distortion of ported designs. Ideal for small-to-medium control rooms or as surround speakers in larger setups.
3. Performance:
• Frequency response of 80Hz – 20kHz (+/-2dB) ensures accurate reproduction of critical audio ranges.
• High SPL capability (108dB per pair) allows for dynamic playback without distortion.
4. Build Quality:
• Sturdy and compact design (17.7” x 9.8” x 11.6”, 18kg per cabinet) for flexibility in placement.
• Bi-wirable terminals allow optimized connections with professional amplifiers.
5. Applications:
• Ideal for nearfield monitoring, LCR surround monitoring, and critical audio work, making it a favorite in professional studios.
Specifications :
Drivers: LF 6.5”/150mm Super Linear, HF 1”/25mm Dual-Suspension ‘S-Spec’ Tweeter
Amplitude linearity : 80Hz – 20kHz (+/-2dB)
Cut-off frequencies : 55Hz – 25kHz (-6dB freestanding)
Dispersion : +/-80° coherent horizontal, +/-10° coherent vertical
Maximum continuous SPL : 108dB (per pair @ 1m)
Crossover frequency : 2.5kHz
Recommended Amplifier Power: 75 to 300 Watts
Nominal Impedance : 8 Ohm
Connectors : 2 x Pairs Binding Posts/4mm Plugs – Bi-Wireable
Cabinet Dimensions (HxWxD) : 450x250x294mm (17.7″x9.8″x11.6″)
Weight : 18kg/39.7lbs (per cabinet)
The SCM20PSL Pro is especially valued for its accurate, uncolored sound, making it ideal for precise mixing and monitoring tasks. Its sealed box design ensures a natural bass response without the phase distortion common in ported designs. Users often pair these monitors with a high-quality amplifier for optimal performance .
Condition:
In good working condition 8/10
What's included:
Metal speaker stand not included
Price:
Selling for RM13,800
Trade in / swap available
Contact:
Peter 0 1 2 - 3 8 2 0 3 3 3
Whatsapp me https://wa.me/message/DPSIPO7MHBUPA1
Welcome to audition in Bandar Sunway
Local pickup or buyer pays shipping
ATC SCM20PSL Pro Speaker Img_1950
ATC SCM20PSL Pro Speaker Img_1949
ATC SCM20PSL Pro Speaker Img_1944
ATC SCM20PSL Pro Speaker Img_1947
ATC SCM20PSL Pro Speaker Img_1946
Last edited by peterclting on Mon Jan 13, 2025 7:04 pm; edited 2 times in total (Reason for editing : update info)
peterclting
Number of posts : 3077
ATC SCM20PSL Pro Speaker Empty Re: ATC SCM20PSL Pro Speaker
Post by peterclting Fri Jan 17, 2025 8:23 pm
peterclting
