Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold)
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Empty Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold)
Post by choyaudiovisual Tue Dec 17, 2024 3:37 pm
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05920
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05914
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05915
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05913
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05924
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05923
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05925
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05926
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05931
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05927
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05929
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05928
Parasound Halo A23+ Stereo Power Amplifier + Halo P6 2.1 Channel Preamplifier & DAC (Sold) Dsc05930
HALO A23+ Power Amp
Power Output – Stereo Mode (0.06% THD)
160 watts x 2, 8 Ω both channels driven
240 watts x 2, 4 Ω both channels driven
Power Output – Stereo Mode (0.9% THD)
210 watts x 2, 8 Ω both channels driven
300 watts x 2, 4 Ω both channels driven
Power Output – Bridged Mode (0.06% THD)
500 watts x 1, 8 Ω
Bridged 4 Ω operation is not recommended
Power Output – Bridged Mode (0.9% THD)
600 watts x 1, 8 Ω
*All Power measurement are at 120 VAC,
RMS continuous power, full audio band (20 Hz – 20 kHz)
Current Capacity
45 amps peak, per channel
Slew Rate
> 130 volts per microsecond
Frequency Response
5 Hz – 100 kHz, +0/-3 dB
20 Hz – 20 kHz, +0/-0.25 dB
Total Harmonic Distortion (THD)
< 0.06 % at full power
< 0.03 % at typical listening levels
IM Distortion
< 0.04 %
TIM
Unmeasurable
Inter-channel Crosstalk
> 85 dB at 1 kHz
> 70 dB at 20 kHz
Input Impedance
Unbalanced: 33 kΩ
Balanced: 66 kΩ,(33 kΩ per leg)
Total Gain
29 dB
Input Sensitivity for 28.28 V Out (8 Ω Load)
Unbalanced: 1 V
Balanced: 1 V per leg
S/N Ratio
> 112 dB, input shorted, IHF A-weighted
> 107 dB, input shorted, unweighted
Damping Factor
> 800 at 20 Hz
DC Trigger Requirements
+9 Vdc to +12 Vdc, 5 mA
Audio Trigger Requirements
2 mV – 10 mV
XLR Pin Identification
1 = Ground (Shield)
2 = Positive
3 = Negative (Return)
Dimensions
Width: 17-1/4″ (437 mm)
Depth: 15″-1/4″ (388 mm)
Depth, with cables 17″ (432 mm)
Height, with feet: 4-1/8″ (105 mm)
Height, without feet: 3-1/2″ (89 mm), 2U
Net Weight
27 lb. (12.2 kg)
Shipping Weight
34 lb. (14.4 kg)
Power Requirement
Standby: <1 Watt
Idle (no music playing): 75 Watts
Typical Listening levels: 125 Watts
Maximum: 800 Watts
110-125 VAC 60 Hz or 220-250 VAC 50 Hz
AC mains voltage is set on rear panel
HALO P6 Preamp
Frequency Response
10 Hz – 100 kHz, +0/-3 dB
20 Hz – 20 kHz, +0/-0.5 dB
< 0.01 %
Interchannel Crosstalk
> 70 dB at 20 kHz
> 78 dB at 1 kHz
Preamplifier Stage Input Sensitivity
300 mV in for 1 V
Total Gain: 10 dB
Max Output: 7.5V
S/N Ratio – Line Inputs 1- 5
> 108 dB (shorted, IHF A-weighted)
> 88 dB (shorted, unweighted)
S/N Ratio – DAC Inputs
> 108 dB (IHF A-weighted)
> 88 dB (unweighted)
S/N Ratio – Phono Input
MM > 80 dB (shorted, IHF A-weighted)
MM > 70 dB (shorted, unweighted)
MC > 67 dB (shorted, IHF A-weighted)
MC > 55 dB (shorted, unweighted)
Phono Stage Sensitivity / Input Impedance
MM: 38 dB / 47 k Ω
MC: 52 dB / 47 k Ω or 100 Ω
Input Impedance
Unbalanced: 24 k Ω
Balanced: 100 k Ω per leg
Preamplifier Output Impedance
Unbalanced: 100 Ω
Balanced: 470 Ω per leg
High & Low Pass Crossover Slope
12 dB per octave
Supported DAC Sampling Rates
USB: up to 384 kHz / 32-bit PCM
DSD Native: DSD 64, DSD 128, DSD 256
DSD over PCM (DoP) at 384 kHz
Coax/Optical: up to 192 kHz / 24-bit PCM
Digital to Analog Converter
ESS Sabre32 Reference ES9018K2M
384 kHz / 32-bit
USB 2.0 Controller
Savitech SA9227, 384 kHz / 32-bit
Headphone Amplifier
Texas Instruments TPA6120A
Output Impedance 10 ohms
1 = Ground (Shield)
2 = Positive
Dimensions
Depth: 15″ (381 mm)
Net Weight
14 lb. (6.3 kg)
Shipping Weight
21 lb. (9.5 kg)
Power Requirement
Standby: 0.5 watts
Power On: 15 watts
100-250 VAC 50/60 Hz (automatic)10 Hz – 100 kHz, +0/-3 dB
Conditions: 8/10
Price: SOLD inclusive postage to West Malaysia
Number of posts : 5975
