YAMAHA Pure Class A w/ OCL Circuit Duo V-FET "Tube Sound" & SEPP CA-1000 ii Amp w/ Phono Stage
PM Me Directly 直接找我
For ANYONE who wanted to try the Pure Class A "Tube" Sound from Yamaha!NOW This is ur Chances! 对于任何想尝试雅马哈纯A类“管”音的人!现在是你的机会!🤩
Pure Class A Discrete MM/MC Phono Stage Preamp | 纯A类分立MM/MC唱放前置放大器
Pure Class A Dual FET differential Circuit Input Stage | 纯A类双FET差分电路输入级
Pure Class A SEPP Output Stage | 纯A类SEPP输出级
Switchable Class A/AB Operation | 可切换A类/AB类操作
Separated Channel Circuity w/ Duo V-FET “Tube” Transistor | 独立通道电路,配备双V-FET“管”晶体管
Single Huge Homemade Yamaha 350VA Transformer | 单个自制雅马哈350VA变压器
Total Capacitance 36,000 uF (16000uF * 2 PSU Filter Capacitor) | 总电容36,000uF(16000uF * 2电源滤波电容)
2 Units of 18,000uF NIPPON CHEMICON Japan Capacitors | 2个18,000uF NIPPON CHEMICON日本电容
Bi-Amp/Bi-Wire (Speaker A + B) | 双功放/双线分频(A+B扬声器)
Protection Circuitry | 保护电路
Headphone Output | 耳机输出
NOW ONLY RM 2380! 🤯 You CAN HAVE IT on your HIFI Rack!🤩 SHOW IT OFF ~
现在只需 RM 2380🤯! 你就可以拥有它,放在你的音响架子上🤩!炫一炫它〜
CONDITION 品像: 8.5/10 = Mint | 非常好
The Yamaha CA-1000 MK2 integrated amplifier delivers a rich and immersive sound experience, blending the warmth and weighty mid-bass of Class AB with the clarity and transparency of Class A. Its high frequencies are smooth and airy, while the mids are textured, open, and full, providing a lush and clean sound. The lows are deep, controlled, and punchy, offering powerful bass. The soundstage is expansive, with excellent instrument separation and a sense of space around the singer and instruments, creating an intimate, dynamic, and detailed listening experience that captures both depth and texture.
雅马哈CA-1000 MK2集成功放提供了丰富且沉浸的声音体验,将Class AB的温暖和有力中低音与Class A的清晰度和透明度完美结合。高频平滑且充满空气感,中频有质感、开放且饱满,呈现出丰富且清晰的声音。低频深沉、控制力强且有力,带来强劲的低音。音场宽广,乐器分离度极佳,歌手和乐器周围充满空间,创造出既亲密又充满活力的听感体验,捕捉了深度与质感的细节。
~ Personal Experience
SOUND QUALITY REVIEW(音色评测):🤩
Class AB experience:
- Weighty mid-bass.
- A lot of warmth.
- Full and lush sound.
- Powerful bass.
- Very lively and dynamic.
Class A experience:
- Tube sound feeling.
- Space and air around the singer and instruments.
- Well-represented vocal cords, enhancing the singer’s presence.
- Immersive feeling as if the singer is in the room.
- Immediate increase in detail and texture.
- Open and rich sound.
- Deeper and wider soundstage.
- Better instrument separation.
- Clean and clear mid-range.
- More transparent.
- Spacious and airy.
- Relaxing and cozy listening experience.
Sound quality:
- Highs: Smooth, sweet, spacious, extended, and airy.
- Mids: Textured, open, rich, full, warm, lush, clean, and clear.
- Lows: Weighty, authoritative, controlled, deep, and punchy.
Class AB体验:
- 有力的中低音。
- 丰富的暖感。
- 饱满且丰富的声音。
- 强劲的低频。
- 非常生动且动态感强。
Class A体验:
- 有管音的感觉。
- 歌手和乐器周围充满空间和空气感。
- 声音表现出色,增强了歌手的存在感。
- 仿佛歌手就在你身边,带来沉浸感。
- 细节和质感立即提升。
- 开放且丰富的声音。
- 更深更宽的音场。
- 更好的乐器分离度。
- 清晰明了的中频。
- 更加透明。
- 宽敞且充满空气感。
- 放松且舒适的听感体验。
声音质量:
- 高频:平滑、甜美、宽广、延展、空气感十足。
- 中频:有质感、开放、丰富、饱满、温暖、柔和、清晰明了。
- 低频:有重量感、权威感、控制力强、深沉且有力。
DESIGN & TECHNOLOGY 设计与科技:
- The power amplifier section uses a pure complimentary service OCL circuit connected to all stages.
- The equalizer amplifier has an input stage with Yamaha's original dual FET and a class A SEPP output stage with a transistor.
- Built-in class-A / class-B switching circuit provides high output for class-B and high transparency for class-A.
- Circuits are analyzed using CAD methods.
- Focus on returning to basics with Class A after the dominance of Class B solid-state amplifiers.
- The CA-1000ii became a long line of successful, reliable, and heavy amplifiers.
- Unique features include two-sided circuit boards, low-noise MC preamp, variable loudness control, and switchable Class A / Class AB modes.
- Advanced chassis construction with components carefully placed to minimize interference.
- Features include a huge 350VA transformer, large 18,000µF capacitors, 1% tolerance metal film and styrol resistors, and 3-stage DC shelving tone controls.
- Fully differential power stage driver with a current-mirror configuration.
- Class A mode outputs 2x 15W at 8 Ohms; Class AB mode up to 2x 80W.
- The "current steering" circuit maintains Class A operation for currents up to twice the bias current, with a bias current of 0.5A.
- Phono stage has two inputs with selectable MC/MM settings and a semi-floating ground for MC cartridges.
- Sturdy chassis with different wood enclosure colors for domestic and export models.
- The CA-1000ii was followed by the CA-1010 and CA-2010, with high bias current and heat generation requiring ample ventilation.
- 功率放大器部分使用纯互补服务OCL电路,连接所有阶段。
- 均衡放大器具有Yamaha独创的双FET输入级和使用晶体管的A类SEPP输出级。
- 内置A类/B类切换电路,提供高输出的B类和高透明度的A类。
- 所有电路均通过CAD方法进行分析。
- 在早期固态B类放大器占主导地位的时期,专注于回归A类设计。
- CA-1000ii成为一系列成功、可靠且重量重的放大器。
- 独特功能包括双面电路板、低噪声MC前置放大器、可调响度控制和可切换的A类/B类模式。
- 先进的机箱构造,精心布置的组件以最小化干扰。
- 主要特点包括350VA变压器、大型18,000µF电容器、1%容差金属膜电阻和3级直流调音控制。
- 完全差分功率级驱动器,采用电流镜配置。
- A类模式下,输出2x 15W,8欧姆;B类模式下输出最高2x 80W。
- “电流引导”电路在电流高达偏置电流的两倍时保持A类工作,偏置电流为0.5A。
- 唱放具有两个输入,并可选择MC/MM设置,MC唱头使用半浮地电路。
- 坚固的机箱,国内和出口型号的木质外壳颜色不同。
- CA-1000ii后继型号为CA-1010和CA-2010,因高偏置电流和热量产生,需要充足的通风。
SPECIFICATIONS 规格:🧾
General:
- Type Pre-main amplifier
- Effective output (1 kHz, both channel drive):
- Class B Operation : 80W + 80W (8 Ω)
- Class A Operation : 15W + 15W (8 Ω)
- Dynamic Power (IHF) 200W (Class B)
- Total harmonic distortion factor (20 Hz to 20 kHz, 1 kHz):
- Class B operation : 0.04%
- Class A operation : 0.02%
- Power bandwidth (IHF) 5 Hz ~ 50 kHz (Class B)
- Damping factor 70 or More (1 kHz, 8 Ω)
- Phono circuit 2 Systems, 3 mv, 200 μ V (MC)
- Phono maximum allowable input (1 kHz) 310mVrms
- RIAA deviation + / - 0.2 dB
- Tone control:
- Bass : 50 Hz ± 15 dB
- Treble : 10 kHz ± 10 dB
- Low filter 20Hz/70Hz, 12dB/oct.
- High filter 6kHz/12kHz, 6dB/oct.
- Loudness Continuous loudness
- Power supply voltage 100 VAC, 50Hz/60Hz
- Power consumption 195W
- External dimensions Width 436x Height 144x Depth 323 mm
- Weight 15.5kg
REFERENCES 根据:🫡
1.https://reverb.com/item/36630717-yamaha-ca-1000-ii-stereo-amplifier-in-very-good-condition-japanese-vintage
2.http://www.thevintageknob.org/yamaha-CA-1000.html
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
- Weighty mid-bass.
- A lot of warmth.
- Powerful bass.
Class A experience:
- More transparent.
Sound quality:
Class AB体验:
- 有力的中低音。
- 丰富的暖感。
- 饱满且丰富的声音。
- 强劲的低频。
- 非常生动且动态感强。
Class A体验:
- 有管音的感觉。
- 歌手和乐器周围充满空间和空气感。
- 声音表现出色,增强了歌手的存在感。
- 仿佛歌手就在你身边,带来沉浸感。
- 细节和质感立即提升。
- 开放且丰富的声音。
- 更深更宽的音场。
- 更好的乐器分离度。
- 清晰明了的中频。
- 更加透明。
- 宽敞且充满空气感。
- 放松且舒适的听感体验。
声音质量:
- 所有电路均通过CAD方法进行分析。
SPECIFICATIONS 规格:🧾
General:
- Tone control:
- Weight 15.5kg
REFERENCES 根据:🫡
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
DISCLAIMER 免责声明:
» Sansui MOSFET Class A | Duo Stage NF Circuit Quad/Stereo Channel QRX-3000 Amplifier w/ Phono Stage SOLD
» Sansui Japan RARE Earliest Batch Pure Class A Model 220 Tube Amplifier w/ MM Phono Stage in 240v
» ROTEL w/ ALL Japan Parts | Pure Class A Input Stage | RA-212 Integrated Amp w/ Phono Stage
» Marantz Flagship Pure Class A Input Stage | Model 1250 Console Stereo Amplifier w/ Phono Stage
» Pure Sound P10 phono stage (used)
