Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Empty Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills
Post by HomeSweetAudio98 Sat Dec 21, 2024 1:51 am
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥ANOTHER RARE FIND! Tannoy UK & TEAC Japan Collaboration Limited Production Unit!🤩
💥又一稀有珍品!英国Tannoy与日本TEAC联名合作的限量生产单元!🤩
 😎The ONLY Brand w/ LONGEST HISTORY that doing Dual Concentric Coaxial Speaker! | 唯一拥有最长历史的双同轴同心扬声器品牌!😎
🎵Designed & Engineered by Tannoy UK & TEAC Japan
🎵Pure UK Craftmanship
🎵All new 10 inch full-range, point source, phase coherent, Dual Concentric, DMT driver
🎵 Bi-wired gold plated terminals
🎵 High quality Van den Hul internal wiring gives greater clarity and accurate image placement
🎵 User adjustable high frequency response +1.5 dB
🎵 Highest quality minimalist crossover network
🎵 Rugged cabinet styling comprising high pressure twin laminated MDF walls within a grey soft-texture space-frame.
🎵 Braced cabinet/driver energy system
🎵 Vented, die-cast drive unit chassis increases heat dissipation and power handling
🎵 Twin laminar flow port tubes
🎵  Drive unit diffraction ring ensures smooth high frequency and better imaging
🎵 由英国 Tannoy 和日本 TEAC 联合设计与制造
🎵 纯正英国工艺
🎵 全新 10 英寸全频、点声源、相位一致的 Dual Concentric(同轴单元)DMT 驱动单元
🎵 双线分音接线柱,镀金端子
🎵 高品质 Van den Hul 内部接线,提供更高的清晰度和准确的音像定位
🎵 用户可调高频响应 +1.5 dB
🎵 最高质量的极简分频网络
🎵 坚固耐用的箱体设计,由高压双层 MDF 板构成,并配有灰色软质纹理支架
🎵 加强的箱体/驱动单元能量系统
🎵 通风的压铸驱动单元底盘,提升散热与功率承受能力
🎵 双层流线型导向孔设计
🎵 驱动单元扩散环确保高频平滑及更佳的音像定位
✅NOW ONLY RM 5680!🤯 You CAN HAVE IT at your home!🤩 SHOW IT OFF ~😎
✅现在只需 RM 5680🤯! 你就可以拥有它,放在你的家里🤩!炫一炫它〜😎
💎CONDITION 品像: 8.5/10 = Very Mint w/ Original Grilles & Stands | 非常新 ~ 有原装网罩和喇叭脚架
💥The Tannoy System 10's are tight and full sounding in general. I was using them as a pair of mid to near field monitors, and they certainly packed enough punch for me to be able to get an accurate read on what we were recording. I remember getting a very tight kick drum sound through these monitors, as the low end is very good for a pair of medium sized monitors. After listening to the unmixed and very rough recordings that we did while monitoring through the System 10's, it was clear to see that they had steered us in the right direction as the sound translated well to my monitors at home.
Tannoy System 10 整体听感紧致且饱满。我用它们作为一对中场到近场监听音箱,确实能够提供足够的冲击力,让我准确判断我们录音的效果。我还记得通过这些音箱获得了非常紧实的底鼓声音,其低频表现对于一对中型音箱来说非常出色。在监听 System 10 时,我们听了未混音、非常粗糙的录音,但很明显,它们引导我们朝着正确的方向前进,因为音频在我家里的监听音箱上也很好地得到了还原。💥~ Reviewers from Audio Forums
- Big soundstage and precise stereo imaging
- Coherent and accurate imaging
- Sweet and engaging vocals
- Exceptional vocal detail, including vocal cords, facial features, mouth, and body
- Realistic experience of the singer being in the room, creating an immersive and emotional feeling
- Life-like representation of vocals and instruments
- Natural presentation of imaging and tonality
- Linear, deep, and punchy bass with noticeable low bass and kick drum impact
- Refined and dynamic sound
- Warmth with a slight transparency
- Full and bold sound
- Well-balanced tonality with full-bodied presentation and smooth, sweet treble
- Solid and dense tone
- Excellent micro dynamics
- Rich texture and nuance in mid and high frequencies
- 宽广的音场和精确的立体声成像
- 连贯且准确的成像
- 甜美且引人入胜的嗓音
- 卓越的嗓音细节,包括声带、面部特征、嘴巴和身体
- 逼真地感受到歌手仿佛就在房间里,带来身临其境和情感上的冲击
- 逼真的人声和乐器呈现
- 成像和音色表现自然
- 线性、深沉且有力的低音,低频和踢鼓的冲击力明显
- 精致且富有动态感的声音
- 温暖且略带透明感
- 音色饱满且大胆
- 均衡的音色,呈现饱满的音质和平滑甜美的高频
- 声音更为凝实和密集
- 微动态表现极好
- 中频和高频丰富的纹理和细节
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- 10-inch Dual Concentric driver with high-tech design
- First-order crossover for both low and high frequencies with positive acoustic polarity
- Frequency-independent time delay behavior for phase response
- MDF cabinet with energy-absorbing bracing matrix and BPF acoustic wadding
- Cabinet finish: Velti shadow grey with soft-texture, high-pressure twin laminate in shadow grey and metallic speckled finish
- Acoustically transparent black grille on wooden frame
- Compact, yet high-performance mobile/monitor speaker system with exceptional sound quality
- 10英寸双同轴驱动单元,采用高科技设计
- 低频和高频均采用一阶分频器,正向声学极性
- 频率独立的时间延迟特性,具有相位响应
- MDF箱体,带有能量吸收加固矩阵和BPF声学填充材料
- 箱体表面:Velti阴影灰色软纹理,高压双层层压板,阴影灰色和金属闪光效果
- 木质框架上的黑色声学透明网罩
- 紧凑而高性能的移动/监控音响系统,具有卓越的音质
✅SPECIFICATIONS 规格:🧾
- Recommended Amplifier Power: 30 to 150 watts
- Peak Power Handling: 250 watts
- Nominal Impedance: 8 ohms
- Sensitivity (2.83 volts @ 1m): 94 dB
- Distortion: Less than 0.5% 46 Hz - 25 kHz
- Phase Response: System behaves substantially as a frequency-independent time delay
- Dispersion: 90 degrees conical
- Crossover Frequency: 2.3 kHz
- Crossover Type: First-order low frequency; first-order high frequency. Positive acoustic polarity
- Crossover Controls: Treble energy range 2 kHz - 25 kHz +1.5 dB, level, -1.5 dB
- Frequency Response (±3dB): 46 Hz - 25 kHz
- Drive Unit Type: 10 inch 2525GG Dual Concentric
- Cabinet Internal Volume: 35 litres
- Cabinet Material: MDF (30mm front and back; 20.6mm top, bottom, and sides) with energy-absorbing bracing matrix and BPF acoustic wadding
- Cabinet Finish: Velti shadow grey soft-texture finish. High-pressure twin laminate in shadow grey with metallic speckled finish on top, bottom, and sides
- Grille: Single piece, black acoustically transparent material on a wooden frame
- Cabinet Dimensions (HxWxD): 560 x 365 x 290mm (22.0 x 14.3 x 11.4 inches)
- Cabinet Weight: 19 kg (41.9 lbs)
- Shipping Dimensions (HxWxD): Approximately 660 x 465 x 390mm (25.9 x 18.3 x 15.3 inches)
- Shipping Weight: Approximately 21 kg (46.3 lbs)
✅REFERENCES 根据:📑🫡
1.https://coax.pin2.me/speaker/System_10_DMT/System_10_DMT-Product_Information.pdf
2.https://www.hifiengine.com/manual_library/tannoy/system_10_dmt.shtml
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy21
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy20
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy24
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy23
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy22
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy26
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy25
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy27
Tannoy DMT | Van den Hul Wiring | Braced Cabinet | System 10 Bookshelf Speaker w/ Stand & Grills Tannoy28
HomeSweetAudio98
Number of posts : 108
