Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker Empty Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker
Post by HomeSweetAudio98 Thu Jan 02, 2025 6:12 pm
📱:0⃣1⃣6⃣2⃣8⃣9⃣3⃣2⃣2⃣6⃣
👇PM Me Directly 直接找我👇
💥Handcrafted in Italy w/ Real Wood Veneer in Walnut Finish! | 意大利手工制作,采用真木胡桃木饰面!🤩
🎵Chario's "Frequency Shifting" Principle Technology | Chario的“频率移位”原理技术
🎵Soft Cloth Dome Tweeter w/ Rigid Hemispherical Pad | 软布圆顶高音单元配有坚硬的半球形垫片
🎵Stochastic Cellulose Fibers Paper Midbass Driver | 随机纤维素纸中低音驱动单元
🎵Down Firing Bass Port (Unique Bass Sea Wave Effect) | 向下发射低音端口(独特的低音海浪效应)
🎵Acoustic Dampening & Braced Cabinet | 声学阻尼和加固箱体
💥HELP FRIEND to SALE 帮朋友卖🤝
💥零售价 Retails for ALMOST RM 5000! (999€ EURO)🤯
✅NOW ONLY RM 2780!🤯 You CAN HAVE IT at your home!🤩 SHOW IT OFF ~😎
✅现在只需 RM 2780🤯! 你就可以拥有它,放在你的家里🤩!炫一炫它〜😎
💎CONDITION 品像: 8.5/10 = Very Mint | 非常新
💥The sound quality is characterized by effortless, uncolored lower midrange that creates a silky, enveloping texture, coupled with excellent detail retrieval that brings out subtle dynamics in male choirs and delicate piano performances. Orchestral passages are rendered with clear separation and no compression, while transient response is fast and clean, enhancing realism, especially in percussive elements. High frequencies are sweet and naturally clear, though not excessively extended, offering an immersive experience without extreme sparkle. The bass is crisp and quick, with natural warmth in the midbass, and while it lacks extreme low-end thunder, it remains solid for jazz and rock. Overall, the sound impresses with dynamic capability, clarity across the frequency spectrum, and superb transient handling, making it well-suited for both rock and jazz performances.
声音质量表现为轻松、无色的中低频,创造出丝滑、包围感十足的质感,细节提取出色,能展现男声合唱和精致钢琴演奏中的微妙动态。管弦乐段落清晰分离,不存在压缩,即使在密集或强音的片段中也能保持清晰。瞬态响应快速、干净,特别是在打击乐元素中,增强了真实感。高频甜美而自然清晰,尽管不特别延伸,但提供了沉浸感,没有极端的亮度。低频清晰、快速,具有自然的中低频温暖,尽管缺乏极端的低端震撼力,但在爵士和摇滚音乐中依然稳固。总体而言,声音在动态能力、频率范围的清晰度和瞬态响应方面令人印象深刻,非常适合演绎摇滚和爵士乐。
💥~ Stereophile
- Lower midrange: Effortless, uncolored, and bloom-like, creating a silky, enveloping quality.
- Detail retrieval: Excellent articulation of low-level dynamics, bringing out subtleties in male choir and delicate piano performances.
- Orchestral reproduction: Clear separation and no compression, even during dense or fortissimo passages.
- Transient response: Fast, clean articulation, with percussive elements coming through sharply, enhancing realism.
- High-frequency performance: Sweet but not extremely extended, with natural clarity just below the top end. Lacked extreme sparkle but still immersive and natural.
- Bass: Clear, quick, and crisp transient handling, with natural warmth in the midbass. Low-end thunder was absent but solid for jazz and rock bass.
- Midbass: Impressive clarity, contributing to coherent pacing and solid rhythm sections, suitable for both jazz and rock.
- Rock and jazz performance: Able to handle wide dynamic ranges with ease, maintaining clarity and power even at high volumes.
- Overall: Impressive dynamic capabilities, clear articulation across frequency ranges, natural bass, and excellent transient response.
✅DESIGN & TECHNOLOGY 设计与科技:⚙🛠
- Chario offers a range of loudspeakers, with the Premium 2000 being the entry model in their Premium line
- The Premium 2000 features Chario's "frequency shifting" principle, which aims to achieve good energy linearity and dispersion.
- The design includes a long-throw 6.7" woofer with a radiating diameter under 8", crossing over at 1500Hz, and a 1" soft-dome tweeter derived from Chario’s Constellation series.
- The tweeter has a rigid hemispherical pad to distribute air pressure behind the diaphragm and reduce acoustic resonances. Its aluminum front plate helps dissipate heat.
- The woofer’s cone is made from "stochastic cellulose fibers," and the driver has an extra magnet to reduce Q and enhance acceleration.
- The speaker features a port mounted at the base, with four rubber feet raising the enclosure slightly to allow the port to breathe.
- Chario recommends toed-in positioning of the speakers for optimal sound, which enhances depth. Straight-ahead positioning increases the width of the soundstage.
- Chario 提供一系列扬声器,其中 Premium 2000 是其 Premium 系列中的入门级型号。
- Premium 2000 采用了 Chario 的“频率偏移”原理,旨在实现良好的能量线性和扩散性。
- 该设计包括一个长冲程的 6.7 英寸低音单元,辐射直径不到 8 英寸,交叉频率为 1500Hz,采用 Chario 的 Constellation 系列衍生的 1 英寸软球顶高音单元。
- 高音单元配备一个坚固的半球形垫片,用于分布振膜背后的空气压力,并减少声学共振。其铝制前板有助于散热。
- 低音单元的振膜由“随机纤维素纤维”制成,并且驱动单元配备了额外的磁铁,以降低 Q 值并增强加速度。
- 扬声器的端口位于底部,配有四个橡胶脚垫,将音箱略微抬高以使端口能够呼吸。
- Chario 推荐将扬声器微微朝内摆放,以获得最佳的音效,这样可以增强深度。而直线摆放则会增加声场的宽度。
✅SPECIFICATIONS 规格:🧾
- Stereo / Front
- Recommended usage: Vented (bass reflex)
- Enclosure type: 55Hz (measured at -3dB)
- Frequency range: 89dB at 2.83V/1m
- Sensitivity: 8 ohms
- Nominal impedance: 2-way
- Number of frequency bands: 1500Hz
- Crossover frequencies:
- Drivers information:
  - Woofer / Midbass, Tweeter
  - 1 x 6.7 inch Woofer/Midbass
  - 1 x 25mm Tweeter (Soft Cloth dome)
- Other features: No built-in amplifier
- Body dimensions (WxHxD): 8.27 in x 16.54 in x 12.6 in
- Weight: 24.25 lb (10.5Kg EACH)
✅REFERENCES 根据:📑🫡
1.https://www.hifi-guide.com/loudspeaker/chario-premium-2000/
2.https://www.meetgadget.com/gadget/19827/Chario+Premium+2000
🤩Can HELP U do 我们可以帮您:
🎵HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
🎵Speaker 喇叭
🎵CD Player 光盘播放器
🎵Turntable 唱盘
🎵Streamer 串流机
🎵Power Cord & Cables 电源线
✅ DISCLAIMER 免责声明:⚠
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47193010
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47189411
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47188410
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47228410
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47234910
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47196810
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47194110
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47198210
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47227310
Chario Italy Handcrafted| Stochastic Cellulose Fibers Driver |Down Firing Port Premium 2000 Speaker 47223510
HomeSweetAudio98
Number of posts : 108
