Cambridge Audio DacMagic DAC (SOLD)
For Sale: Cambridge Audio DacMagic DAC
Elevate your listening experience with the Cambridge Audio DacMagic, a high-performance digital-to-analog converter designed for audiophiles. Perfect for improving the sound quality of your digital audio sources, including computers, CD players, and streaming devices.
Condition:
Excellent, well-maintained, and fully functional.
Key Features:
Dual Wolfson WM8740 DACs for exceptional audio quality.
Multiple input options: USB, optical, and coaxial.
Compact design, perfect for any audio setup.
Supports up to 24-bit/192kHz resolution.
Balanced XLR and unbalanced RCA audio outputs.
ATF (Adaptive Time Filtering) up-sampling intelligently interpolates incoming audio data
(16-24 bits, 32-96kHz) to 24bit/192kHz output through the use of a 32bit Texas Instruments DSP.
Twin Wolfson WM8740 24bit DACs used in dual differential configuration.
Selectable digital filters (Linear Phase, Minimum Phase and Steep) differ slightly in optimisation and allow user to select filter of their choice.
USB audio input allows the DacMagic to act as a high quality DAC/soundcard for your computer.
Specifications:
Inputs 2 x Digital Inputs (choice of either co-axial or optical connection for each)
1 x USB PC Digital Input
Audio Outputs
1 x pair Gold Plated RCA phono outputs
1 x pair XLR balanced outputs
1 x Co-axial digital output (pass through)
1 x Optical digital output (pass through)
D/A converters Dual Wolfson WM8740 24bit DACs
Digital filter Texas Instruments TMS 320VC5501 DSP upsampling to 24bit 192kHz
Analogue filter 2-Pole Dual Differential Bessel Double Virtual Earth Balanced
Frequency response 20Hz to 20kHz (±0.1dB) *
Output level (unbalanced) 2.1V rms
Output level (balanced) 4.2V rms (2.1V per phase)
Digital input word widths supported 16-24bit**
Digital input sampling frequencies supported
32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz ***
Audio output upsampling Fixed 24bit 192kHz
Dimensions (H x W x D) 52 x 215 x 191mm (2.0 x 8.6 x 7.6”)
Weight 1.2kg/2.6lbs
* Steep filter disabled, **16bit for USB, ***48kHz for USB
What's include:
Original box, Power supply Adapter and Vertical Stand
Price:
Selling for SOLD
Contact:
Peter 012-3820333
Can audition in Bandar Sunway, Subang Jaya.
Shipping:
Available (buyer pays shipping) / Local pickup
Condition:
Key Features:
Specifications:
Audio Outputs
Weight 1.2kg/2.6lbs
What's include:
Price:
Selling for SOLD
Contact:
Peter 012-3820333
Shipping:
Last edited by peterclting on Fri Jan 17, 2025 10:53 pm; edited 1 time in total (Reason for editing : SOLD)
- Number of posts : 3076
» WTS Cambridge Audio DACmagic
» Cambridge Audio Dacmagic
» Cambridge Audio DAC Magic
» Cambridge Audio Dacmagic (Used)
» Cambridge audio DACMAGIC 1
