Marantz SM-6 Esotec Series Power Amp (Used)- SOLD
Up for sale is a stereo power amplifier which can change a pure Class-A and AB class- Marantz SM-6.
The pure Class-A operation is adopted and the output at the time of a pure Class-A serves as @30 W/ch RMS. Moreover, it can be used also as AB class operation @120 W/ch RMS by switchpoint change.
Please note that this set is made in Japan and it's working condition, asking for S$450, self collection@AMK, Singapore.
Quick Spec:
Output power: 20Hz - 20kHz, both channel drive @120W+120W (AB class), @30W+30W (Class-A)
THD: 0.015% (at 20Hz - 20kHz, the time of an effective output 8-ohm load intensity)
Cross modulation distortion: 0.015% (at the time of 60Hz:70kHz=4:1 and an effective output)
Frequency characteristic: 20Hz-20kHz(+0, -0.2dB), 5Hz-100kHz(+0, -5dB)
Input sensitivity/impedance: 1.5V/47kohms
Dumping factor: 100 (1kHz, 8-ohm load intensity)
S/N ratio: 118dB (IHF-A curve)
Universal Voltage: 110-240V, 50/60Hz
Dimensions: Width 416x height 146x depth of 332mm
Weight: 14.5kg
Quick Spec:
Weight: 14.5kg
Last edited by sms@+65~93203900 on Mon Sep 27, 2010 4:51 pm; edited 1 time in total (Reason for editing : item sold)
sms@+65~93203900- Club Member
- Number of posts : 33
Registration date : 2010-09-16
» Marantz ST5 Esotec Series Tuner & 1152DC amp- (SOLD)
» Marantz CD63 MkII KI Series (used) SOLD
» Marantz Esotec SM-6
» Marantz SM-6 Esotec
» Marantz esotec SC 6 stereo pre amp (used)
