Analysis Plus Oval 1 RCA interconnect 1m (Used)SOLD
Analysis Plus Oval 1 RCA interconnect 1m (Used)SOLD Empty Analysis Plus Oval 1 RCA interconnect 1m (Used)SOLD
Post by raymond88 Wed Oct 06, 2010 10:07 pm
Item: Analysis Plus Oval 1 RCA interconnect 1m
Condition: 8.5/10. This is a demo unit in MINT condition.
Price: SOLD
Contact: Raymond 012-3816611
Analysis Plus Oval 1 RCA interconnect 1m (Used)SOLD Analys10
Analysis Plus Oval 1 RCA interconnect 1m (Used)SOLD Analys11
Analysis Plus Oval 1 RCA interconnect 1m (Used)SOLD Analys12
Some information:
For audiophiles who don't need XLR connections, we developed the superb-value Oval One interconnect.
It uses a braided signal conductor in our proprietary hollow oval design along with a braided outer shield mated to a true 75 ohm RCA connector with a low-loss dielectric.
Because Oval One is handmade using first-rate materials, it will outperform other cables costing many times more.
The 100-percent shield coverage ensures the very low noise floor that's essential to experiencing the entire dynamic range of symphonic music.
The RCA connection is solder-less, using a compression contact technique that spares the dielectric from damage that heat from soldering can cause. This technique also eliminates the poor signal transfer that results from a cold solder joint.
Our fussiness adds to the cost of the cable, but the performance increase is worth the added care.
http://www.audioreview.com/cat/cables/interconnect-cables/analysis-plus/oval-one-interconnect/PRD_411879_5827crx.aspx
Last edited by raymond88 on Fri Oct 08, 2010 9:05 pm; edited 1 time in total (Reason for editing : SOLD)
Number of posts : 10058
