Audio Space Houston 1998 SE ( Used )9/10
Model: Houston Mini-1998 integrated stereo amplifier,Audio Space Houston 1998 SE ( Used )9/10 ,The Mini-1998 comes in two very compact metal cases, both of which are cleverly packed into a single, vertically-standing box, with a top handle. Despite the diminutive size, the observer is assailed by the flash of steel, gold electro-plating and glass ... all very chic and rather unusual.
One box houses the power supply section--voltage selector, power switch, LED status indicator and IEC mains in/out are provided on this. The last is output, via a provided cable, to the amp itself, which has similar dimensions as the power unit, but with the tubes and twin transformers atop the chassis.
The tube array includes two 12AX7 driver valves at the preamp stage and four proprietary EL84s at the output stage. The Houston is rated at 18 watts per channel in ultralinear mode or 13 watts in push-pull mode, and will deliver into four-to-16ohm loads.
well review and famous in the tube system ...hehe
Call : 017 234 6116 Selling For Rm 1900.0o
Libertie Loi
Libertie Loi
Last edited by libertie5828 on Tue Oct 12, 2010 4:21 pm; edited 1 time in total (Reason for editing : price)
libertie5828- Dealer\Reseller\Trader\Service Provider
- Number of posts : 153
» Audio space houston mini 1998(used)all sold
» audio space mini houston(used)SOLD
» Mini Houston 2004 by Audio Space
» Audio space mini houston EL84 for sale
» Houston Mini 1998
» Houston Mini 1998
