Weight Down - CD / Bluray Payer
Post by Mikapoh on Tue Oct 19, 2010 9:34 am
Ok, I have read some where that by putting some weights for eg, heavy books etc on top of a cd player will eventually make the player sounds better. Is the philosophy of weighing down the machine can mitigate the vibrations caused by the fast spinning of the cd inside so that the players itself is more stabilized?
If so, does this also applies to any Bluray players? I would like to put some weighs on my bluray player and hope that this can improves its video & audio. But, would also like to have your opinions first on this. Books look weird maybe something like heavy glass or tiles? Smile
Mikapoh
Male Number of posts: 242
Registration date: 2009-03-08
Re: Weight Down - CD / Bluray Payer
Post by wingman on Tue Oct 19, 2010 9:42 am
I utilize two sheets of "mouse pads" made out of rubber, just nice to place them on my CDP.
Also the CDP sits on 4 inch ( diameter ) rubber "O" ring washers.
cheers Very Happy
wingman
Male Number of posts: 701
Registration date: 2009-08-10
Post by bassraptor on Tue Oct 19, 2010 10:13 am
Mikapoh: It's a non-investment experiment, so why don't you try and see, and then report your findings here. Will be interesting.
bassraptor
Moderator
Moderator
Male Number of posts: 727
Registration date: 2009-01-17
Source(s): LP/CD/Streamer
Amplification: Yes
Speakers: Yes
Post by Mikapoh on Tue Oct 19, 2010 11:08 am
Sure I am going to try it and use the dictionary books first. Shall see if I could spot some differences soon.
How about anyone experiencing it before?
Mikapoh
Post by bal on Tue Oct 19, 2010 11:57 am
Try a bag full of sand, resting in the middle of where the disc spins.
Bal.
bal
Male Number of posts: 283
Registration date: 2009-03-06
Source(s): Esound cdp, mac book pro with decibel thro m2 Tech and Buffalo II dac
Amplification: home made pre, vincent 330 power
Speakers: maggie MMG, Vienna acustics Haydn, Def tech BP6
Post by vault101 on Tue Oct 19, 2010 12:27 pm
I have damped the case of one of my cd players with bitumen adhesive internally and adding diving lead weights on the top.
I do hear significant difference with the sound being more focus, bass with better definition and much 'cleaner' overall.
Works well for me, i presume....
vault101
Registration date: 2010-09-20
Post by WongKN on Tue Oct 19, 2010 12:57 pm
It's free so try it and let us know the results (as well as the brand of BR player you have). But you should also check that the player can take it. Meaning that some components get quite hot during operation and they might depend on conduction of heat off the top plate for cooling. So if you put a stack of books on top, you effectively interfere with that and it may cause your component to overheat. I am not sure if any BR player uses this feature. So check (by simply placing your hand on the top of the player after it has been played for a hour or two) first before you go ahead and do the experiment.
WongKN
Moderator
Moderator
Male Number of posts: 1774
Registration date: 2009-01-20
Post by vault101 on Tue Oct 19, 2010 1:13 pm
Rightly said, I've tried other large surface 'weights' and you'll know it starts to 'overheat' when the disc starts skipping erratically!
vault101
Post by WongKN on Tue Oct 19, 2010 1:35 pm
Thanks for verifying my experience.
lso, do check carefully about the consistency or the solidity of the structure of the player itself. For e.g. some player might have relatively thin metal sheets for the body. If we place something very heavy, it MIGHT cause the chassis to flex. The CD-tray itself is mounted onto the chassis and if the chassis flex in a bad manner, it might throw the CD-tray out of alignment, e.g. out of level (I assume everyone makes the effort to ensure your CD player is properly levelledl !). That MIGHT introduce some negative effects to the player.
WongKN
Moderator
Moderator
Post by tycham on Tue Oct 19, 2010 2:16 pm
vault101 wrote:Rightly said, I've tried other large surface 'weights' and you'll know it starts to 'overheat' when the disc starts skipping erratically!
Ooooo....could be out of focus!
tycham
Male Number of posts: 720
Registration date: 2009-02-26
Source(s): Digital
Amplification: Solid State
Speakers: Bookshelf
Post by tycham on Tue Oct 19, 2010 2:21 pm
You would do better by 'floating' the entire player by resting it on 3 or 4 spherical objects of same diameter.
tycham
Source(s): Digital
Speakers: Bookshelf
Post by wingman on Tue Oct 19, 2010 3:06 pm
try resting the CDP on a solid wood which is sitting on squash balls / tennis balls as an air cushion Question
Hmmm....food for thought Exclamation
cheers Very Happy
wingman
Post by tycham on Tue Oct 19, 2010 3:25 pm
wingman wrote:try resting the CDP on a solid wood which is sitting on squash balls / tennis balls as an air cushion Question
cheers Very Happy
Would work as well.
tycham
Source(s): Digital
Speakers: Bookshelf
Post by chenht on Tue Oct 19, 2010 11:47 pm
I just remember I have 2 dumbbell idling in my store room Smile
chenht
Regular
Regular
Male Number of posts: 94
Registration date: 2009-01-25
Source(s): Cary Audio
Amplification: Eletrocompaniet
Speakers: Sonus Faber
