Cyrus LinkPower - Stereo power amplifier (Used)
Cyrus LinkPower - Stereo power amplifier (Used) Empty Cyrus LinkPower - Stereo power amplifier (Used)
Post by raymond88 Thu Nov 04, 2010 11:51 am
Item: Cyrus LinkPower - Stereo power amplifier
Condition: 8.9/10. This is in mint condition complete with the original
packaging, power cord and MC-Bus cable.
This is a 50w per channel high quality power amp. It would be equally at home being the main or bi-amp power amp in a stereo set-up, a bi-amp for a centre channel, or hidden away for multi-room/location systems using the automated function.
Cyrus LinkPower - Stereo power amplifier (Used) Cyrusp10
Cyrus LinkPower - Stereo power amplifier (Used) Cyrusp11
Cyrus LinkPower - Stereo power amplifier (Used) Cyrusp12
Cyrus LinkPower - Stereo power amplifier (Used) Cyrusp13
Technical information -
Electrical
Inputs - Phono sockets
Outputs - Bi-wirable Loudspeakers, Chain out
Power Supply - 180VA Toroidal transformer
Communications - MC-BUS™ System BUS
Power output - Stereo 50W/CH (both driven into 8 Ohms) 80W/CH (both driven into 4 Ohms)
Distortion - <0.004%, (1kHz into 8 Ohms) <0.01%, (20Hz-20kHz into 8 Ohms)
Frequency Response - -3 dB at 0.2Hz and 100kHz
Output Current - 15A peak
Sensitivity (RCA input) - 381mV (for 50W stereo into 8 Ohms)
Input impedance - 20Kohm
S/N Ratio - 111dBA (ref 50W)
Dimensions - (H x W x D) 73 x 215 x 360 (mm)
Weight - 4.6kg
Finish - Brushed Black
More info:
http://www.cyrusaudio.com/product-archive/power-amplifiers/linkpower
Price: RM1750
Contact: Raymond 012-3816611
www.mudah.my/hifi-junction
Thank you.
Number of posts : 10093
