Emotiva XPA-5 Five Channel Power Amplifier [SOLD]
SPECS:
Number of Channels: 5
Topology: Fully Discrete, Dual Differential, High Current, Short Signal Path Class A/B
Power output (all channels driven):
300 watts RMS @ 4 ohm (0.1% THD) per channel
200 watts RMS @ 8 ohm (0.1% THD) per channel
Power Band Response: 20 Hz to 20 kHz with less than .05db deviation at rated power
Broadband Frequency Response: (-3db): 5Hz to 150kHz
Amplifier Gain: 32db
Signal to Noise Ratio
1 watt: >97db
Full Power: >111db
Input Impedance:
Unbalanced – 23.5kohms
Balanced – 33kohm
Transformer Size: 1,200VA
Secondary Capacitance: 60,000uF
Output Devices: 6 per channel
Size: 17” W x 7.75” H x 19” D
Weight: 66 lbs (86 lbs boxed)
FEATURES:
• Fully protected from all fault conditions
• Advanced microprocessor operating system
• Soft start circuitry
• External trigger turn on
• Soft touch power switch
• 4RU chassis w/ solid milled aluminum faceplate
• IEC power inlet, 120/230 VAC configurable
• Output design: Triple Darlington with On output stages
• Differential Drive: Dual Differential input
• Types of inputs: Balanced (XLR) and Un-balanced (RCA)
• Type of outputs: Audiophile quality 5 way binding post
• Display type: Digital status indicators
Condition: 9/10 (comes with double box, manual)
Contact: Rex 012-9696181
Price: SOLD
cmliew- Dealer\Reseller\Trader\Service Provider
- Number of posts : 3299
» Emotiva XPA-5 5-Channel Power Amplifier [SOLD]
» Emotiva XPA-3 3-Channel Power Amplifier [SOLD]
» Emotiva XPA-5 Five Channel Power Amplifier [SOLD]
» Emotiva UPA-7 Seven Channel Power Amplifier [SOLD]
