SOLD Luxman LR-6500 AV Receiver 6.1
Feature:
1) Full Discrete, Equal Power Six Amplifier Channels, and Wide range All-Discrete amplifier channels for maximum power of 105W x 6.
105W x 2/ 105W / 105W x 2 /105W (8 ohm EIAJ)
85W x 2 (8 ohm, 1KHz, 0.05% THD)
85W x 2 (8 ohm, 20Hz - 20K Hz, 0.07% THD)
2) 7.1 External Input
This input is not only for the existing 5.1 and 6.1 external input device like SACD. Moreover, this is for the future products as well which will have 7.1 channels output. The unit is designed for dynamic range of sources like SACD and DVD-Audio. The stereo frequency response is from 10 Hz to 100,000 Hz..
3) 7.1 Pre-out
By using Prologic IIx, it is allowing us to provide a way for customer to up-grade in order to enjoy the 7.1 theatre effect by using external amplifier.
4) 7 channels stereo
Although the speaker out put is having 6 channels, inside the unit there are needed 7 channels stereo in order to allow different sources. It is not only designed for the basic performance like stereo, Dolby 5.1, Dolby 6.1, dts 5.1 or dts 6.1 can be enjoyed by customers. It is designed ready for the enjoyment of the future device which is having 7.1 channels output.
5) Dolby Digital EX decoding
6) dts ES 6.1 discrete decoding
7) Support dts 96/24, dts NEO:6 Music Cinema
Dot Matrix Display
We are using Dot matrix Display with 3 step display Dimmer. It will be easier to read and to be used. The Dimmer is also providing different matching with different room environment in order to have maximum enjoyment for the Home Theatre setting.
9) Component Video In/Out
This in/out channels is having a wide Bandwidth which is even capable for HD TV,
10) Remote control
High end Metal Casing with pre-set remote sets which allow customer to control others frequently used brand¡¦s device like TV, VCR¡Kby one remote.
11) Frequency Synthesis Tuning
50 station AM/FM Random Preset Memory Tuning
Auto Preset Memory
RDS (European version)
12) Crossover Bass Management
For the different Subwoofer performance, our receivers have prepared a choice of 7 different steps 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz and 200Hz for the subwoofer crossover switching. These will let you have your own set-up according to your characteristic of the subwoofer and all other speakers.
13) Input/Output Terminals for Every A/V System
Audio Input
Analogue Input
DVD, Video 1, Video 2, Aux 1(front), CD, Tape
7.1 Ext Analogue Input
Front L/R, Centre, Surround L/R, Surround Back L/R, Subwoofer
Digital (Optical) Input
Optical x 2
Digital (Coaxial) Input
Coaxial x 2
Audio Output
Analogue output
Video 1, Video 2, Tape
7.1 Analogue pre-output
Digital (Optical) Output
Optical x 1
Digital (Coaxial) Output
Coaxial x 1
Headphone
Stereo Headphone jack
Video Input
Component Input
DVD, Video2,
S-Video input
DVD, Video1, Video2
Composite video input
DVD, Video1, Video2, Aux1
Video Output
Component Output
Monitor
S-Video Output
Monitor, Video1, Video2
Specification:
Analog input Frequency Response:
10Hz - 100k Hz (+0dB ~ -3dB)
Digital input Frequency Response:
8Hz - 45k Hz (+0dB ~ -3dB)
S/N Ratio:
more than 100 dB
Function Cross Talk:
(1k Hz -75dB) ( 10k Hz -65 dB)
Channel Separation:
( 1 k Hz -75dB) ( 10k Hz -65 dB)
Upgrading to new AV receiver and looking for RM700 for this fine 6.1 channel AV Receiver. Please sms -
cj.g- Frequent Contributor
- Number of posts : 868
Registration date : 2009-04-03
» Luxman R-600 Receiver Amp [used]sold
» Luxman 600 receiver - sold
» Luxman R1050 receiver (Used)(SOLD)
» Luxman R-1050 Receiver ( SOLD )
» Luxman R-1050 receiver (sold)
