Quad 99 stereo power amp (SOLD)
Quad 99 Stereo 2 Channel power amplifier
Condition like new, still has 6 months warranty.
Asking for SOLD
Please SMS 012-2947573
Quad power amplifiers have always been amongst the finest in the world. Over the years, they have earned a reputation for being ‘straight wires with gain’, because they neither add nor take anything away from the original music signal. The 99 stereo power amplifier maintains this tradition. It uses a dual complementary feedback circuit with exceptional stability margins to achieve exemplary performance and an output of over 90 watts per channel. Overload recovery is instantaneous and the amplifier is fully protected against over-driving or misuse, without resorting to output line fuses or relays, which degrade the quality of the signal fed to the loudspeakers. The 99 stereo power amplifier can be safely used to drive most types of loudspeaker, both Quad’s own electrostatic models and conventional models made by both Quad and other manufacturers.
Specification
Maximum Power Output 90WRMS (8ohms), 120WRMS (4ohms)
Maximum Output Current 11 Amps peak each channel
Total Harmonic Distortion 0.05% (70W into 8Ohms; 20Hz - 20kHz)
Input Sensitivity (phono) 775mV
Output Impedance 1.5uH parallel with 0.05 Ohms
DC Offset Voltage less than 10mV
Frequency Response 3Hz to 50kHz (+0dB/-3dB)
Signal to Noise ratio (70W) 110dB (20Hz to 20kHz)
Dimensions (H x W x D) 70 x 321 x 310mm
Additional info: http://www.quad-hifi.co.uk/model.php?sector_id=2&range_id=3&model_id=8
[img][/img]
[img][/img]
Asking for SOLD
Specification
[img][/img]
[img][/img]
dumpdump- New Member
- Number of posts : 7
Registration date : 2010-05-19
» Sold - Quad 306 stereo power amplifier (Used)
» Quad 306 stereo power amplifier - SOLD
» QUAD 306 Stereo Power Amplifier (Used) SOLD
» QUAD 405 Stereo Power Amplifier (sold)
» QUAD 34 Preamp and 405 Stereo Power Amplifier (Used) SOLD
