(SOLD!) Original DENON DCM-420 20bit 5 Disc Changer with Ori remote 90s model
HI,
I am the original owner of this wonderful DENON 5 disc CD Changer 20Bit DLSC (Double Super Linear convertor)which is for sale.
This DENON CD player sometimes can play and sometimes it doesnt detect any CDs . However if CD is being played, you can change your 4 others CD while playing.
I would consider this item as Faulty because of this condition mentioned above . Not sure if the lens is weak, belt loosen or motor is old. If you know how to repair this unit will be a fine addition to your hifi setup. Sound smooth and bass is tight when played as compared to my Pioneer Cd player.
Please note this CD player is a roulette type CD changer and not catridge type.
When roulette system is adopted, if an OPEN/CLOSE button is pushed while performing the disc of one sheet, a tray opens, and the remaining discs of four sheets can be exchanged, with a performance continued
In the DA translation part, high precision S.L.C is carried double, and the phase difference between zero crossing distortion or a right-and-left channel is eliminated in it.
Moreover, a 20-bit digital filter is adopted as a digital filter.
I.D.S (Intelligent Disc Scan) Since the function is carried and it can be rotated by the tray of roulette in the both directions of a clockwise rotation and a counterclockwise rotation, access between discs can be performed quickly. \
The random function of three types of 3 mode random / full randomness, program randomness, and disc sequential random is carried.
At full random, a microcomputer chooses and performs music at random out of the disc of five sheets by pushing in order of a random button and play button. Moreover, in program random, if it pushes in order of a random button and play button after pushing and programming a program / direct button, out of the programmed music, a microcomputer will select a song at random and will perform.
And in disc sequential random, if a random button is pushed, a disc number is specified and a play button is pushed, a microcomputer will choose and perform music at random out of a disc in order of the specified disc. It is also possible to be able to choose a maximum of five discs and to specify the same disc 2 times or more.
Five kinds of repeat performance functions are carried, and 5way repeat / 1 music repeat, 1 disc repeat, an all-repeat, a program repeat, and a random repeat are possible.
The program performance function of 20 music is carried.
The De Dis Crebell file function is carried and the memory of the favorite level can be carried out for every disc.
Even 100 discs can carry out a memory, and a memory is held even if it turns off the power.
In addition to two analogs, one digital coaxial output is carried.
Also comes with its own built in volume control .
Item is a 100v unit and requires stepdown. Original remote with volume control is provided. Also Tested working 100% working.
Exterior condition of CD player 6/10 due to age.
Reason selling: Dont want to repair.
Price SOLD
COD PJ area.
Pls Call or SMS at 019 - 3 8 NINE NINE TWO TWO 7
Thank you for your precious time.
Price SOLD
COD PJ area.
Last edited by bcitextx on Mon Dec 13, 2010 7:14 pm; edited 3 times in total (Reason for editing : Added a Few more features that the CD player can play.)
bcitextx- Club Member
- Number of posts : 27
Registration date : 2010-09-30
» pioneer vsx-ax10 top model (with original remote)
» Arcam MCD Multi CD Changer 6-Disc (Used) SOLD
